OCCRA
Go to Post You can learn just as much from building a small robot as you can from a large bot because all of the key concepts are the same. - Greg Needel [more]
  #16   Spotlight this post!
Unread 02-22-2018, 04:44 PM
Daleolgren Daleolgren is offline
FRC #4375
Daleolgren is an unknown quantity at this point
Re: Brownouts , PDP and roborio
We are using 8 inch inch wheels with 4 to 1 direct drive planetary gear boxes on each of of our 4 cims .. so we have no chain or sprockets.... previously I miss stated the ratio and wheel size..... we do plan to order add on reduction to actually make it 8 to 1 ratio.... the wheels are softer rubber ( grey ) smooth
  #17   Spotlight this post!
Unread 02-22-2018, 05:04 PM
pkrishna3082's Avatar
pkrishna3082 pkrishna3082 is offline
love/hate relationship with swerve
AKA: Parthiv Krishna
FRC #3082 (Chicken Bot Pie) and FTC #13471 Mentor (Minnetonka)
Team Role: Leadership
Rookie Year: 2016
pkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond repute
Yeah, it makes sense that you are browning out. That's 46.5 ft/sec free speed. Waaaaaayyyy too high for the CIMs, they don't have enough torque to handle that. Even 8:1 on 8inch wheels is pushing it if that's your only speed. You probably want to go for 12:1 or so.
My posts constitute my opinions, and mine alone, and are not representative of the views held by my team.
2010-2011: FLL 11083, 13873 (Minnetonka Silver) - Programmer
2016-: FRC 3082 (Chicken Bot Pie) - Engineering Captain, fmr. Programming Lead, 2017&2018 Dean's List Finalist
2017-: FTC 13471 (Minnetonka) - Founding Mentor
  #18   Spotlight this post!
Unread 02-22-2018, 05:07 PM
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
4:1 with 8'' wheels will not move at all, with 6'' wheels is still almost guaranteed to cause constant brownouts, and with 4'' wheels it will likely do so while turning or accelerating at low speeds unless the drivetrain is exceptionally efficient or other precautions are taken.
I would not recommend gearing for above ~14 ft/sec (theoretical no-loss speed at 12v) unless you absolutely know what you are doing.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
FRC Drivetrain Characterization
  #19   Spotlight this post!
Unread 02-22-2018, 05:16 PM
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Direct drive to each wheel with 4 CIMs sounds like you're either running 4 wheel drive with sticky wheels or mecanum. Once you get the gear ratio down to something sane like 12:1, mecanums should turn fine no matter where the wheels are, unless you have them installed backwards. 4 sticky wheels will need a wide wheelbase to turn well, though.
Can you post a picture of the bottom side of your robot for us to look at? Don't open the bag, though. Even a picture through a bag will probably work since we just need the approximate wheelbase aspect ratio.
  #20   Spotlight this post!
Unread 02-22-2018, 07:50 PM
RoboAlum RoboAlum is offline
Mickey D's
FRC #7214 (TigerOps)
RoboAlum is a splendid one to beholdRoboAlum is a splendid one to beholdRoboAlum is a splendid one to beholdRoboAlum is a splendid one to beholdRoboAlum is a splendid one to beholdRoboAlum is a splendid one to beholdRoboAlum is a splendid one to beholdRoboAlum is a splendid one to behold
So we use 6"omni in each corner we have the versa clamping style gear boxes and we do 5.14:1 reduction so far we haven't browned out at all. But will we be seeing brownouts later in the season
Co-Founder and Director
RASA (Robotics.Alliance.of Southern Arizona) 501c3
Mentor
FRC 4841 2013-2017
FRC 7214 2017-
VEX 4874 2013-2017
Student
FRC 71 2009-2012
  #21   Spotlight this post!
Unread 02-22-2018, 07:55 PM
AKA: Eli Barnett
That gearing is quite a bit more aggressive than anything I would consider in a single-speed, and probably even in a shifting drive. Even if you don't have brownout problems (you almost certainly will if you try to go full forward to full reverse without some sort of ramping), you're going to be crippling your acceleration and moving more slowly than you want to.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
