OCCRA
Go to Post I don't care if my team wins. I care if they try their hardest to win. - pfreivald [more]
Unread 08-14-2018, 02:11 PM
Zem's Avatar
Zem Zem is offline
AKA: Braeden (I speak for myself, not for my team)
FRC #3461 (Operation P.E.A.C.C.E.)
Rookie Year: 2010
Zem will become famous soon enough
Pressure not rising smoothly
Hello CD
My air system is not building pressure smoothly. The needle on the stored pressure gauge shakes back and forth about 15 to 20psi as it goes up. This worries me because my pressure switch now does not read 120psi until the true pressure in the tanks it about 135 to 140psi.
Can anyone please help me? Is there something wrong with my compressor?
By the way I am using this compressor from amazon: https://www.amazon.com/Viair-90-Comp...dp/B002A65JR6/
Unread 08-14-2018, 03:16 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Mentor
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Pressure not rising smoothly
Are the compressor and tank connected by a long thin tube, and is the gauge at the compressor end? If so, this is probably just the regular cycle of the compressor; like all displacement pumps, it generates surges of pressure. (E.g. a heart beat). To get a more even measurement, locate the gauge (and pressure switch, BTW) as close to the tank as possible. If you don't have an accumulator tank at all, you should.
[Quoting brennonbrimhall]: We design a new robot every year, but we can't forget that we also design a new team every year as folks come and go.
Unread 08-14-2018, 03:57 PM
Unsung FIRST Hero
Chief Robot Inspector
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Braeden,
This is normal behavior while the compressor is running. However, it is unusual for the system to shut off using the pressure switch above 120 PSI. It is possible for there to be a restriction between the stored pressure gauge and the pressure switch that would delay the turn off of the compressor. If you use teflon tape (I hope you do) then it is possible for the tape to have blocked the entrance to the pressure switch. Most teams will place the pressure switch and the stored pressure gauge very near each other. Failure for the pressure switch normally occurs when the diaphragm in the switch has a leak. This leak can be heard near the switch when there is pressure in the system and the robot has been disabled. When in doubt try another switch.
Al
WB9UVJ
www.wildstang.org
________________________
Knowledge is power. Power UP!
Unread 08-14-2018, 03:58 PM
Tom Line's Avatar
Tom Line Tom Line is offline
Don't lay blame. Fix probems.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
These pumps are piston pumps. The gage needle shaking is normal.
Unread 08-14-2018, 10:16 PM
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
My personal preference on locating the gauge is at the far end of the high-pressure side of the system from the compressor: just before the regulator to low pressure. Then a second gauge on the regulator (for the low-pressure side). Takes all the shaking out, and also puts the gauges closer together so it's easy to check both at inspection. Some vibration is normal, but it should slow down as the system pressurizes.
Past teams:
2003-2007: FRC0330 BeachBots; 2008: FRC1135 Shmoebotics; 2012: FRC4046 Schroedinger's Dragons
Unread 08-15-2018, 05:53 PM
Zem's Avatar
Zem Zem is offline
Rookie Year: 2010
This has helped thank you. I moved my gauge and pressure switch behind the tanks and it works great now.
Thank you.
Unread 08-15-2018, 09:13 PM
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Originally Posted by Zem View Post
Hello CD
For others that may come across this thread in the future... I've seen bad gauges cause confusion in the past. I had a team whose compressor "never" shut off - aka the high pressure gauge read 140+ and we stopped it. We confirmed correct working of code by manually triggering it by shorting and opening the wires, we replaced the pressure switch, and finally when we replaced the gauge we got different readings that showed everything was working correctly. So, if you see a discrepancy between the pressure switch and the pressure gauge, remember that either one could actually be the problem!
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016-2018; Iowa 2017; Northern Lights 2018; Great Northern 2018
Division LRI: Galileo 2016; Tesla 2017; Archimedes 2018
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
