Go to Post Just remember to be as transparent and inclusive as you can. - DonRotolo [more]
Unread 09-13-2017, 07:55 PM
dardeshna's Avatar
dardeshna dardeshna is online now
Team Captain
AKA: Devin Ardeshna
FRC #0008 (Paly Robotics | Team 8)
Rookie Year: 2015
dardeshna is a splendid one to beholddardeshna is a splendid one to beholddardeshna is a splendid one to beholddardeshna is a splendid one to beholddardeshna is a splendid one to beholddardeshna is a splendid one to behold
Tuning a PIDF follower on a robot with high gearing
One of the problems we have been encountering during the off-season is tuning a PIDF follower reliably on our 2017 robot. It is geared with a fairly high theoretical top speed (~17fps), and our autonomous trajectories are generated with a maximum velocity of about 5fps. This means there isn't much torque at the wheels compared to resistive forces.
Without feedback terms, velocity does not track well. Generally a kV and kA value that work at faster speeds (4-6fps) are inadequate for slower speeds (2-3fps). We can add in feedback, but a few things happen:
1) The Kp term does more corrective work than it should be doing
2) Because of the large error, following is inconsistent between different trajectories
How do teams overcome this inconsistency at lower torque and get better tracking with feed-forward terms before moving on to adding feedback terms?
Devin Ardeshna
Team Captain (Paly Robotics FRC #8)
2017 Ventura Regional Quarterfinalist, Entrepreneurship Award, and Creativity Award, Silicon Valley Regional Finalist, Entrepreneurship Award, and Wildcard, Roebling Division Semifinalist, Chezy Champs Quarterfinalist, Capital City Classic Semifinalist
2016 Central Valley Regional Finalist and Wildcard, Silicon Valley Regional Quarterfinalist, Curie Division, CalGames Quarterfinalist and Entrepreneurship Award, Capital City Classic Quarterfinalist
2015 Central Valley Regional Entrepreneurship Award, Silicon Valley Regional Entrepreneurship Award, Capital City Classic Semifinalist and Judges' Award
Unread 09-13-2017, 10:56 PM
Jared Russell's Avatar
Powered Up
Re: Tuning a PIDF follower on a robot with high gearing
PID(F) assumes linear dynamics; the high voltage and low voltage operating points of DC motors attached to a substantial load behave quite differently.
You will have the best luck if you tune the feedforward terms near the setpoints you care about (or if you want, gain schedule so that no matter what the velocity setpoint, you have a suitable set of feedforward gains).
On 254 we typically tune around a "nominal" speed and accept that at very low speeds, the feedback part of the controller is doing more of the work (which for us usually only occurs briefly at the beginning or end of a motion profile). If we had to spend a large amount of time cruising at a different speed, we would probably gain schedule.
Unread 09-14-2017, 12:35 AM
Oblarg Oblarg is offline
AKA: Eli Barnett
We noticed this as well, after implementing acceleration feedforward on our practice bot (thanks a bunch for the Talon workaround you posted!). The Ka value that worked for our rather tame profile (max acceleration ~3.5 ft/sec^2) corresponded to a theoretical maximum robot acceleration of ~15 ft/sec^2, which is well below what we know the value to be.
Could you provide any insight into why motors so nonlinearly under these conditions? It doesn't seem clear to me from the state equations.
"The breakfast of champions!"
FRC Drivetrain Characterization
Unread 09-14-2017, 01:10 AM
It's the friction that isn't linear, not the motors. Rolling resistance, scrub forces, and static friction are a bear.
Unread 09-14-2017, 12:04 PM
AKA: Eli Barnett
Yeah, I expected that friction would have some nonlinearity, but nowhere near the magnitude of the effect I observed.
This is one of the reasons I wish that the Talon's configNominalOutputVoltage setting rescaled the output to be linear between the nominal output and the maximum output (the current functionality merely promotes the value to the nominal output when it is too low), which it seems to me would do at least a somewhat better job of properly accounting for the effect of friction. I suppose, upon reflection, that we could implement this via. workaround the same way we implement our acceleration feedforward, i.e. by adding the constant value to our velocity setpoints (we'd have to adjust our Kv to account for this, though).
I confess, though, that I'm pretty ignorant of the specific details of the frictional losses - what I suggest above would be akin to assuming that the frictional losses (in terms of extra torque required by the motor) are constant at all speeds. I have no idea how close (or far) this is from the truth. Given the relatively gigantic size of the Ka gain (something like a factor of 6.5 higher than the "theoretical" frictionless value) that we found to work at low speeds/accelerations, I suspect it's pretty far - but I still don't know why the discrepancy is so huge.
Unread 09-14-2017, 12:46 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
.... but I still don't know why the discrepancy is so huge.
The biggest reason is the carpet. Almost any surface pair will have a larger coefficient of static friction than of dynamic friction due to developing bonds between the two surfaces. In the case of carpet, it deforms relatively slowly and rebounds inelastically, so the net friction rises as speeds decrease. I suspect that carpet fibers also work their way into any crevices in the wheels over time, furthering this effect.
Unread 09-14-2017, 03:41 PM
AKA: Eli Barnett
Well, our current plan is to attempt to better-account for the effect of friction by, rather than computing Kv from a single data point (measured max speed), run the robot at a variety of voltages, measure steady-state speed at each, and perform a linear regression. The reciprocal of the slope will become Kv, and the negation of the intercept will become a constant "friction compensation term" that we will add to all of our velocity setpoints. This should, in theory, accurately account for any frictional effect that is itself linear with velocity (and a glance at the residuals from the regression should give us some insight into the degree to which it is nonlinear).
We will document how well this works, and probably write a short whitepaper on it. Hopefully, it will go some ways towards allowing us to have a single Ka gain work reasonably well over a wider range of accelerations.
Unread 09-14-2017, 05:11 PM
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond repute
I'm very interested in the answers to this, because it also applies to a differential swerve with too-high a turning gear ratio. Can someone post an example of gain scheduling or some other non-linear feedback control of turning for my non-coder brain to absorb?
Unread 09-15-2017, 12:00 AM
dardeshna's Avatar
Team Captain
AKA: Devin Ardeshna
Rookie Year: 2015
Our current (post Chezy Champs) plan is to gather several kV values for speeds ranging from 0.5 fps to 10 fps and then write a class (or probably just grab 254's InterpolatingTreeMap) to do linear interpolation for kV values given a velocity target.
Devin Ardeshna
Unread 09-15-2017, 12:07 AM
Here's a simple one.
  const double kP = ::std::abs(velocity) < 1.0 ? 5.0 : 4.0;
  voltage = kP * error;
If you want to hurt your head some, look at our 2016 drivetrain code. We gain schedule all 4 shifter combinations. ({left low, left high} x {right low, right high}).
Practically speaking, gain scheduling means picking a different set of gains at different points in the state space. It's harder to guarantee stability mathematically, so I like to avoid it if possible, or constrain its use such that it's driven by something like gear ratio that doesn't have as much interaction with the loop.
Unread 10-02-2017, 12:04 AM
AKA: Eli Barnett
Sorry to semi-necro the thread, but we just ran the velocity-versus-voltage tests and it turns out that the behavior is linear as heck:
So, our proposed fix should work - I will report back next weekend when we've finished testing it.
This also suggests that our feedforwards, in general, should include an intercept to help account for friction. It would be nice if both WPILib and CTRE would support this - I have sent an email to the latter requesting it.
Edit: If anyone is wondering, the intercept there is approximately -1.55 ft/sec, which corresponds to an output voltage of ~1.24 volts, which in turn corresponds to a torque of about .75 Nm per side of the drive. It would be interesting to see how closely this matches the actual "torque required to move the wheels of the robot at rest" as measured directly with a torque wrench or whatever. Something to put on our list, I suppose.
Unread 10-02-2017, 02:02 AM
dardeshna's Avatar
Team Captain
AKA: Devin Ardeshna
Rookie Year: 2015
Interesting. We will try something similar on our bot and report results.
Devin Ardeshna
Unread 10-02-2017, 10:40 PM
AKA: Eli Barnett
So, I did a bit more investigation today, and it appears that the net friction does indeed decrease as velocity increases, however this decrease appears to be very nearly linear (as can be inferred from the near-perfect linearity of the earlier plot).
To be more specific, assuming the CIM specs used in the WCP drivetrain calculator are correct, the voltage required to overcome frictional losses on our practice bot drops from ~1.2V at velocities near 0, to ~.8V at velocities near max speed.
I will report back on how well our calculated "1.2V" figure corresponds to the actual torque required to move the wheels of the robot at rest once I get my hands on a torque wrench. Unfortunately, I can't think of any way to directly measure this value at speed, so I'm not sure how to test if this decrease is actually a decrease in the friction forces, or rather is simply a result of the CIM specs not being quite right. If anyone has a clever idea for this, let me know. The good news is, well, it really doesn't matter, pragmatically, which it is - since everything appears to be linear, we can easily just roll everything into the feedforward regardless of where it comes from.
It will be interesting to test this on other robots, and see if we obtain similar results.
Unread 10-02-2017, 11:04 PM
Powered Up
Velocity is very linear except very close to the zero point (with the current generation of speed controllers). Acceleration vs. voltage is often not as nice due to friction, battery voltage sag, inductance, etc.
Unread 10-02-2017, 11:11 PM
AKA: Eli Barnett
If you want to be a bit more accurate, you can compute a feed forward acceleration term for your profile that takes this into account, and apply a gain to that instead.
Assuming that you're tracking your profiles well enough that actual speed is sufficiently close to desired speed at any given point in time, then wouldn't a feedforward structure of "intercept + Kv*velocity setpoint + Ka*acceleration setpoint" properly account for this? Unless I fundamentally misunderstand brushed DC motors, torque depends only on the difference between applied voltage and back-EMF. The "intercept + Kv*vel" portion of the FF should account for back-EMF plus the voltage required to overcome frictional forces, leaving the "Ka*acc" term to account (hopefully correctly) for your desired acceleration on top of that.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
