Go to Post "Find a problem? Think of the three I's: Invent and Innovate to Improve!" - yash101 [more]
Unread 01-10-2018, 08:13 PM
nullmainmethod's Avatar
nullmainmethod nullmainmethod is offline
FRC #6502 (DARC Side)
Rookie Year: 2017
nullmainmethod is just really nicenullmainmethod is just really nicenullmainmethod is just really nicenullmainmethod is just really nice
High Flow Solenoids Question
Hi CD,
I've been searching for legal high-flow solenoid valves. I found this old thread, which pointed me to this McMaster Carr page.
Would part #6124K275 be legal, by chance? Would it be a good choice for a very quick and powerful cylinder actuation? I can't find much information about high flow double solenoid valves online...
Thanks!
Edit: What does spring return mean? They seem to be cheaper than the ones which don't have that. Do I need spring return/should I go with non spring-return?
Edit 2: Just found this: https://www.andymark.com/mead-double...-p/am-3324.htm
It has a higher Cv than the McMaster Carr ones, and is cheaper. Is there something I'm missing?
"Remember to hacksaw off the rest of the quick grips to give yourself more room" - /u/Tapego
Unread 01-11-2018, 07:15 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: High Flow Solenoids Question
The primary thing in the rules is:
Originally Posted by 2018 R83
D. Solenoid valves with a maximum ⅛ in. (nominal) NPT, BSPP, or BSPT port diameter,
Which this seems to meet.
The secondary is its ability to comply with
R95. Any pressure vent plug must be:
  • A. connected to the pneumatic circuit such that, when manually operated, it will vent to the atmosphere to relieve all stored pressure in a reasonable amount of time, and
  • B. placed on the ROBOT so that it is visible and easily accessible.
    If the compressor is not used on the ROBOT, then an additional pressure vent plug must be connected to the high-pressure portion of the pneumatic circuit off-board the ROBOT with the compressor (see R87).
Which requires a relieving solenoid valve - when the supply pressure is removed, the pressure down all outputs is vented. I don't see this one way or the other on the page you linked; you'll need to dig to find out.
Finally, spring return is a perfectly valid option, particularly if you have a "default" state for the valve which it will be in most of the time. You must apply voltage to the solenoid for the valve to remain in the activated position with this sort, where a double-acting solenoid will remain in either position when there is no voltage applied to either solenoid.
Note that the McMaster valve you have selected has a 24V solenoid valve. Be sure to move the jumper on the PCM to the 24V position, and do not use any 12V valves on that PCM.
The Mead from AM looks good. I don't see whether it vents in the specs, but it's been on AM for well over a year with no reviews warning that it doesn't, so I'm confident that it complies with the rules. (It looks like these specific rules haven't effectively changed this year).
Unread 01-11-2018, 09:43 AM
SpruceyBrucey's Avatar
SpruceyBrucey SpruceyBrucey is offline
FRC #0885 (Bruce Force Trauma)
Rookie Year: 2015
SpruceyBrucey is an unknown quantity at this point
Originally Posted by nullmainmethod View Post
Hi CD,
The AndyMark solenoid you mentioned maybe what you are looking for, I know we bought that to use on our summer bot last year. Our gear placer was just a piston to punch it out on to the peg. When we first tested it, the piston pushed the gear through our spring loaded doors and shot it on to the peg almost 2 feet away. The flow rate on that thing is crazy compared to anything else we've used. Would recommend if you want higher flow rate solenoid.
Unread 01-11-2018, 10:02 AM
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond repute
Those valves are also available from AutomationDirect and are almost free if you use the $35 voucher from AutomationDirect.
Unread 01-11-2018, 08:05 PM
Rookie Year: 2017
Awesome, thanks. This may or may not be used to push a power cube, depending on prototyping results.
Unread 01-11-2018, 08:08 PM
Rookie Year: 2017
The Mead valves are available? I don't see them or the ones I linked from McMaster.
I did find these, though: https://www.automationdirect.com/adc...)/AVS-5221-24D
Not sure exactly how they compare to the Andymark ones... Cv looks good, but I don't know if there's something I'm missing
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
