OCCRA
Go to Post Hearing about the beginnings of 842 was truly inspirational and has really stuck with me through the years. After following you guys for so long it was crazy for me to play with you. Thank you for all that you have done for FIRST in Arizona. - Saberbot [more]
Unread 09-28-2017, 06:43 PM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
pic: 5987 Octocanum CAD
Unread 09-29-2017, 08:59 AM
philso philso is offline
FRC #2882 (Nuts n Boltz)
Re: pic: 5987 Octocanum CAD
Some practical considerations:
Are the octocanum modules designed to be assembled outside of your robot and pre-tested so they can be easily and quickly installed in the robot? It would be a total pain in the neck if you had to assemble it in the robot.
You may want to consider using a separate pneumatic circuit with it's own regulator to run the four cylinders. This would allow you to adjust the "stiffness of the suspension" to get the optimal traction in mecanum mode.
The "L" and "T" shaped gussets would be stiffer if you added a triangular part in the corners. It may be difficult with the L's due to the wheels though.
Unread 09-29-2017, 03:35 PM
AriMB's Avatar
FRC #5987 (Galaxia)
Thanks for the suggestions! They all sound like good ideas. To address your suggestions:
1. One of the reasons we chose to put the motors in the modules instead of driving the traction wheel shaft from inside the chassis is so that we could assemble and test the modules outside of the chassis. The idea is that the outside tube can be removed with a few bolts, and then the module simply slides out and we can easily repair or replace it.
2. We designed the modules so that they would work with as low as 30psi, rather than the 60psi max. The reason behind this was that if we designed for 60psi and we use more than half of our stored air, we will no longer have enough force. Whereas with 30psi we can use up to 3/4 of our air and still have enough force. It also gives us the wiggle room to stiffen or soften the suspension.
3. I made those gussets quickly just to hold the tubes together for the render; they likely won't be what we implement (certainly not without bolt holes as they are now). They were modeled after VexPro's gussets, which don't have the triangular part.
2017-present: Technical Mentor FRC 5987
2017-present: CSA for FIRST Israel
2012-2016: Member FRC 423 Captian, Programmer (LabVIEW), Electrical, CAD, Manipulator, Chassis, Business, Outreach (everything)
Unread 10-09-2017, 10:22 AM
Volpidash2770's Avatar
Volpidash2770 Volpidash2770 is offline
I Indentify as a Tote
AKA: Ryan Downs
FRC #1018 (Pike RoboDevils)
Team Role: Electrical
Rookie Year: 2016
Volpidash2770 is an unknown quantity at this point
Hey, I'm curious as to whether or not it is safe for the belt to rub against the cim as you have done? I don't personally have any experience in this subject so I am wondering if anyone with more experience has some input or clarification that could help me understand.
Unread 10-09-2017, 12:05 PM
firecrafty's Avatar
firecrafty firecrafty is offline
AKA: Ryan Blue
Rookie Year: 2016
firecrafty will become famous soon enoughfirecrafty will become famous soon enough
+1
"Programming is a science. Writing beautiful code is an art."
Any views I express are my own and do not necessarily reflect those of my team.
Unread 10-09-2017, 12:12 PM
AdamHeard's Avatar
Lead Mentor
Originally Posted by firecrafty View Post
+1
This is a bad idea for sure.
At best it'll merely be an appreciable source of friction.
At worst the belt will fail quickly and/or the robot will barely drive under load.
973 shirts for sale!
2x1 and 2x2 1/16" wall tubing for sale!
Need help? Check out 973 Remote Assistance and Mentorship Program.
Like our Robots? Check out the CAD files of MOST of our robots!
2017 "World Champions"
2014 Galileo Champions
2011 World Champions
Unread 10-09-2017, 12:15 PM
Chris is me's Avatar
AKA: Pinecone
no team (Looking For A New Team); formerly FRC #228 & 2170)
Just want to further emphasize that you definitely, absolutely should not use a CIM as an idler for a timing belt like that. Just don't. It will not work out in your favor, trust me.
Moved to Philadelphia - Now Accepting Free Agent Contract Offers
Mentor / Drive Coach: 228 (2016-2017) - 2017 Waterbury SFs (with 195, 558) & Industrial Design, 2017 Hartford SFs (with 5422, 236)
2016 Waterbury SFs (with 3314, 3719), 2016 Rhode Island #2 Seed / Winners (with 1058, 6153), 2016 Carver QFs (with 503, 359, 4607)
Consultant Person: 2170 (2017) - Waterbury Judge's Award, Hartford Creativity Award
College Mentor: 2791 (2010-2015) Build Photos - 2015 TVR Quality, 2015 FLR Industrial Design,
2014 FLR Quality / SFs (with 341, 4930), 2013 BAE Quality, 2013 WPI Regional #1 Seed / Excellence in Engineering / Finalists (with 20, 3182),
2012 BAE Imagery / Finalists (with 1519, 885), 2012 CT Xerox Creativity / SFs (with 2168, 118)
Unread 10-09-2017, 12:34 PM
AriMB's Avatar
FRC #5987 (Galaxia)
I've never done this exactly, but I have run a belt with a small indent in the path from some all-thread with electrical tape over it. It just barely deflected the belt, and the belt wasn't under a lot of tension.
I wouldn't do it for a real robot though. With the model my students are designing (the one they are actually building), they are putting the CIM higher so it won't interfere with the belt. I had already designed the plates and was too lazy to change them, so I just did that for my model to give them a 3D example of what we were designing on paper.
edit: nice catch by the way, none of my students caught that
Unread 10-09-2017, 08:40 PM
s-neff's Avatar
s-neff s-neff is offline
AKA: Sam
FRC #0841 (Biomechs)
s-neff has a brilliant futures-neff has a brilliant futures-neff has a brilliant futures-neff has a brilliant futures-neff has a brilliant futures-neff has a brilliant futures-neff has a brilliant futures-neff has a brilliant futures-neff has a brilliant futures-neff has a brilliant futures-neff has a brilliant future
Those pistons look enormous and expensive. Also, expensive.
Are you sure you actually need to size to 30psi? Putting on the 4lbs of air compressor to maintain your reserve pressure will probably save you 4lbs of piston & rod-end steel, plus your peace of mind. All you need is to save 1lb at each corner...
Fun:
Mentor - Team 841 (2015 - ? )
Mentor - Team 4 (2013 - 2014)
Student - Team 192 (2009 - 2010)
Work:
SunPower Systems, Product Engineering - Utility Power Plants (2015 - ? )
BSci, Mechanical Engineering, UCLA (2010-2015)
Unread 10-09-2017, 10:17 PM
Oblarg Oblarg is offline
AKA: Eli Barnett
16.7 fps mecanum with only one CIM per wheel? You'll likely have some real trouble strafing in that configuration.
"The breakfast of champions!"
Unread 10-19-2017, 10:55 AM
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a reputation beyond reputeBrandon Zalinsky has a reputation beyond reputeBrandon Zalinsky has a reputation beyond reputeBrandon Zalinsky has a reputation beyond reputeBrandon Zalinsky has a reputation beyond reputeBrandon Zalinsky has a reputation beyond reputeBrandon Zalinsky has a reputation beyond reputeBrandon Zalinsky has a reputation beyond reputeBrandon Zalinsky has a reputation beyond reputeBrandon Zalinsky has a reputation beyond reputeBrandon Zalinsky has a reputation beyond repute
A quick note on the pivoting mechanism:
You might be able to drop a considerable amount of weight by losing the (usually steel) eye bolts for some aluminum clevises, like these:
They're easy to make as well if you can't find one of the correct size. This will also allow you to drop the size of the 'axle' they pivot around to a ~1/4" bolt.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Winner (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 10-19-2017, 10:57 AM
AdamHeard's Avatar
Lead Mentor
Where are you buying these?
Unread 10-19-2017, 11:42 AM
pfreivald's Avatar
AKA: Patrick Freivald
Consider a spring pulling up on the traction wheel so if you lose air altogether you still have an unobstructed mecanum drive.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 10-19-2017, 04:49 PM
AriMB's Avatar
FRC #5987 (Galaxia)
I had considered using clevises, but for some reason decided not to. I don't remember what the reason was anymore. We might need to revisit that when the students make their version.
The traction wheel stays in the same place; the mecanum wheel pivots around the traction wheel axle. We debated adding a spring, but decided the extra parts and complexity isn't worth it. We figure in the rare case that we lose air pressure, having the mecanum wheel floating isn't the end of the world. Unless someone has some experience that would argue with that line of thinking.
Unread 10-19-2017, 06:53 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We usually buy these with the cylinders. Bimba offers these as a standard option on many (if not all) of their lines. We typically buy these even if we don't anticipate using them right now, because those cylinders last a long time, and we just keep the clevises in the pneumatics parts box.
Edit:
I was actually thinking the other way - put the spring so that if you lose air altogether you have a traction drive. Either way, it is definitely better to make sure that your system fails in a direction you DECIDE, not just however, and not to put all the wheels on the floor. If you did want mecanum as your "failsafe", you would probably do better having that as the fixed axis, and rotating the solid wheel into the carpet. Actually, this is really a better option anyway, because mecanum wheels inherently produce strafing forces, so mecanums are (IMO) better placed on the fixed axle. In any case, if you have the "fixed axle" wheel as the failsafe, this spring does not have to be (and should not be) really stiff, just enough to pull the other wheel off the carpet in the absence of pneumatic force. If you do it this way, you do not even need to pressurize the opposite side of the cylinder, saving a bunch of air.
