Go to Post Everyone here inspires each other and helps them out. That's why FIRST is amazing. - tiffany34990 [more]
Unread 04-23-2017, 08:17 AM
CSQ6375's Avatar
CSQ6375 CSQ6375 is offline
AKA: SIQI CHAI
FRC #6375 (MC^2)
Rookie Year: 2017
CSQ6375 is an unknown quantity at this point
How to use a bag motor or a 775 pro motor?
I'm really confused by the round shafts of these motors. I tried the FTC motor hub(http://www.tetrixrobotics.com/TETRIX_Motor_Shaft_Hubs) but it just came of as soon as the motor started spinning. What is the correct way of using these motors?
Unread 04-23-2017, 08:18 AM
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Pick and Place FTW
FRC #2826 (Wave Robotics)
Re: How to use a bag motor or a 775 pro motor?
Use vexpro versaplanatary gearboxes.
2012-Present Wave Robotics Team 2826
Unread 04-23-2017, 08:19 AM
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
press fit a pinion like this on the 775 motor
http://www.wcproducts.net/wcp-0002
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 04-23-2017, 08:25 AM
FrisbeeFunTime's Avatar
FrisbeeFunTime FrisbeeFunTime is offline
AKA: Erik Yngstrom
FRC #1768
Rookie Year: 2015
FrisbeeFunTime will become famous soon enoughFrisbeeFunTime will become famous soon enough
The way motors like the bag or 775 work is that as opposed to using a keyway in the shaft they either have you attach something to the shaft with a setscrew or by pres fitting. The versaplanetaries above mentioned use pressfiting which if you are new to it may seem weird that it actually stays on. Basically the hole on the pinion gear or pulley is just a tad bit smaller than the diameter of the shaft.
Unread 04-23-2017, 08:41 AM
CSQ6375's Avatar
AKA: SIQI CHAI
FRC #6375 (MC^2)
Rookie Year: 2017
@rsisk To use this gear I need to design an additional gearbox right?
Unread 04-23-2017, 08:45 AM
CSQ6375's Avatar
AKA: SIQI CHAI
FRC #6375 (MC^2)
Rookie Year: 2017
Thanks. I've never tried press fitting before, indeed weird for me. Are there any tutorial?
Unread 04-23-2017, 08:48 AM
CSQ6375's Avatar
AKA: SIQI CHAI
FRC #6375 (MC^2)
Rookie Year: 2017
Thanks, but I think the versaplanatary gear box simply takes up too much space.
Unread 04-23-2017, 09:04 AM
Valkonn's Avatar
Valkonn Valkonn is offline
AKA: Paulo Garcia
Valkonn is a splendid one to beholdValkonn is a splendid one to beholdValkonn is a splendid one to beholdValkonn is a splendid one to beholdValkonn is a splendid one to beholdValkonn is a splendid one to behold
You're either going to have to press fit a WCP gear, press fit a WCP pulley, or use a versa planetary gearbox. The first two options require you to make a gearbox.
Do you have a picture of the specific application you need this motor for?
FRC Team ????: (Looking to Mentor)
FRC Team 3495: (Student) 2014-2017
Unread 04-23-2017, 09:19 AM
CSQ6375's Avatar
AKA: SIQI CHAI
FRC #6375 (MC^2)
Rookie Year: 2017
Thanks. I'm thinking about using two RS775 to power the ball shooter in this year's CRC. I've just checked the WCP gear and pulley you mentioned but found them both out of stock. In this case I think I should better design a press fitting pulley instead.
Unread 04-23-2017, 09:45 AM
Valkonn's Avatar
AKA: Paulo Garcia
The easiest way to do that would be to use one of those https://www.vexrobotics.com/vexpro/motion/217-3141.html
Here's an imgur album of how I've seen it being done; http://m.imgur.com/a/w2TvR
Unread 04-23-2017, 10:01 AM
Mitch Stokes's Avatar
Mitch Stokes Mitch Stokes is offline
Berkeley Engineering
AKA: Mitchel Stokes
FRC #5817
Mitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond repute
Another option is to press fit a hex shaft adapter with a set screw onto the motor shaft. We used this on out updated 775pro shooter and it worked well.
Catch me at 5817's pit at Houston!
Unread 04-23-2017, 10:56 AM
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
If you are at the point where you are learning how to attach motor outputs to a system, you should probably be buying a gearbox. The simplify in mounting and use of an off the shelf gearbox is what you want. Designing your own gearbox or power transmission system is going to be a huge waste of time for you.
2018 | Gracious Professionalism x3, Asheville Winners, NCCMP Finalists, NC District - 3rd Rank
2017 | Industrial Design, Gracious Professionalism, NCCMP Winners, NC District - 1st Rank
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Rank
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
