OCCRA
Go to Post If your heart is racing and you feel a little nervous, then you're on the right side of the alliance station wall!;) - David Brinza [more]
Unread 03-13-2018, 12:40 PM
Maxcr1's Avatar
Maxcr1 Maxcr1 is offline
AKA: Max D "Code Boy"
FRC #2169 (KING TeC)
Rookie Year: 2016
Maxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant future
Massive Pathfinder issues
This year, our team is using Pathfinder for autonomous driving. However, we are facing some serious issues.
We are using meters everywhere, the wheelbase, the wheel diameter, etc, and have set up our system with the base-level tuning numbers suggested by Jaci in this post, but are seeing some strange behavior. When we run a path that is supposed to drive straight forward for a meter, our robot accelerates, not stopping until we disable to avoid hitting the wall. We kept working with this, but only get remotely close with numbers that seem ridiculously far off from what is correct:
kP: .0005
kD: .005
kA: .0755
max_velocity: 8
max_acc: 3
jerk: 16
However, when we change the path to run 2 meters, it overshoots it by about a meter. We are considering offloading the profiles to the Talons, but have heard this is inaccurate. Does anybody have any suggestions? Has anybody seen anything similar.
I have made the code public in hopes of fixing the issue, so here is a link to the Drivetrain code. Any help is appreciated. Thank you.
Max DeVos | Programmer | KING TeC 2169
Unread 03-13-2018, 12:51 PM
Re: Massive Pathfinder issues
Originally Posted by Maxcr1 View Post
kP: .0005
kD: .005
kA: .0755
max_velocity: 8
max_acc: 3
jerk: 16
Can you ZIP the generated path and post it as an attachment please?
Unread 03-13-2018, 06:38 PM
gregzetko's Avatar
gregzetko gregzetko is offline
Programming mentor
FRC #2609 (BeaverworX)
Rookie Year: 2016
gregzetko is a glorious beacon of lightgregzetko is a glorious beacon of lightgregzetko is a glorious beacon of lightgregzetko is a glorious beacon of lightgregzetko is a glorious beacon of lightgregzetko is a glorious beacon of light
^ this. Or can you point me to the waypoints that you are talking about? Is it
Waypoint[] example = new Waypoint[] {
    			new Waypoint(0, 0, 0),
    			new Waypoint(1, 1, 0),
    			new Waypoint(2, 0, 0)
2609 Programming Mentor
2017 Curie - 3rd pick, Quarterfinalist
2017-2018 McMaster District event - CSA
2018 Ryerson District event - Field Reset
Unread 03-13-2018, 08:02 PM
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm is just really nicerahilm is just really nicerahilm is just really nicerahilm is just really nice
You forgot to link your code in the original post, but I found it with some Google-ing. I noticed this snippet:
left.configureEncoder(leftMaster.getSelectedSensorPosition(0), Constants.ticksPerRotation,
				PathfinderData.wheel_diameter);
right.configureEncoder(rightMaster.getSelectedSensorPosition(0), Constants.ticksPerRotation,
				Constants.wheelDiameter);
It looks like the left follower has a correct wheel diameter in meters, but the right does not (6m diameter). This could result in some erratic behavior between the left and right side trying to do different things.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 03-13-2018, 09:01 PM
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
kP: .0005
kD: .005
kA: .0755
max_velocity: 8
max_acc: 3
jerk: 16
We made an embarrassing mistake this past weekend. When we cleaned up the wiring after unbagging, we accidentally swapped the encoders for the left and right talons, which resulted in large positive errors on both sides of the drivetrain. This caused it to drive forward full-speed for every trajectory.
Unread 03-14-2018, 08:07 AM
Jaci's Avatar
Jaci Jaci is offline
http://imjac.in/ta/name
AKA: Jaci R Brunning
FRC #5333 (Can't C#) #5663 (Ground Control) | (OpenRIO, FRC West Aus)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
I would recommend using 449's drivetrain characteristics paper to determine the proper values for kV and kA instead of going off theoretical values, then adjusting kP followed by kD.
Make sure your control loop is running at a fast, consistent rate (use the WPILib Notifier), since Pathfinder assumes it is being called at this rate.
Also make sure your robot is mechanically and electrically sound (encoders work as they are supposed to, the gyro is recording the correct +/- value, etc). Part of this is also making sure your values in your code reflect those in real life (wheel diameter as rahilm mentioned above, ticks per revolution, etc)
Curtin FRC (5333+5663) : Head Mentor
WPILib : Developer
Website | Github
jaci.brunning@gmail.com
Unread 03-14-2018, 11:12 AM
CodeNinja CodeNinja is offline
FRC #3997 (Screaming Chickens)
Rookie Year: 2017
CodeNinja is an unknown quantity at this point
By WPIlib Notifier, do you mean use timed robot?
Unread 03-14-2018, 12:30 PM
@Max: status update?
Unread 03-14-2018, 07:42 PM
Jaci's Avatar
Rookie Year: 2015
I mean WPILib Notifier, you shouldn't run your control loop inside of your main robot class, whether it's timed or not.
https://github.com/wpilibsuite/allwp.../Notifier.java
WPILib : Developer
Website | Github
Unread 03-18-2018, 09:26 AM
Maxcr1's Avatar
Rookie Year: 2016
I'm sorry for going silent, as I found myself with no time as our competition occurred over the last few days. I am going to try these things out as soon as I get the chance.
Thank you for your help, and I'm sorry for going silent.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
