OCCRA
Go to Post The thought of destroying any robot is just......depressing :( - Richard McClellan [more]
Unread 03-16-2015, 09:30 AM
nfusselman1 nfusselman1 is offline
FRC #4076
nfusselman1 is an unknown quantity at this point
Java with the labview Dashboard?
Is it possible to program your robot in Java and still use the LabView Dashboard for your Gyro, Camera Feed...
Lead Programmer Team# 4076
nfusselman1
Unread 03-16-2015, 10:07 AM
Re: Java with the labview Dashboard?
Yes, we are using Java on the robot with the default LabVIEW dashboard.
We are what we repeatedly do. Excellence, then, is not an act, but a habit. -Aristotle
Unread 03-16-2015, 10:09 AM
FRC #4076
If you could can you post a copy of the code you use for the dashboard.
nfusselman1
Unread 03-17-2015, 08:54 AM
afiolmahon afiolmahon is offline
FRC #1218
afiolmahon is an unknown quantity at this point
Java makes it nice and easy to use the labview dashboard. Program your labview dashboard the way you normally would, and then use the methods in the SmartDashboard class to get or send any information your robot needs.
Unread 03-17-2015, 08:57 AM
Sorry, I'm traveling without the code, so I don't have an example to post.
Unread 03-17-2015, 10:20 AM
FRC #4076
That is ok I will figure it out.
Unread 03-19-2015, 09:23 AM
FRC #4076
I found a document but it does not say what all the location names are.
Do you know what the "DB/" name is for the gyro?
Lead Programmer Team#4076
nfusselman1
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
