OCCRA
Go to Post What is the airspeed velocity of an unladen wiffle ball? - The Doctor [more]
Unread 09-14-2018, 04:08 PM
risho900 risho900 is offline
FRC #6897 (Astraea Robotics)
Rookie Year: 2015
risho900 will become famous soon enough
Pneumatic System Help
I am struggling to get our pneumatics to work. The PCM is slowly blinking red, the CAN lights on PDP are yellows, and the power light on Roborio is red. Iíve tried rewriting everything which didnít change. I also tried using WebDash but the PCM does not come up. Someone mind helping out?
Unread 09-14-2018, 04:41 PM
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Pneumatic System Help
Slow red usually means a compressor or solenoid fault. Download the manual, it's all in there.
http://www.ctr-electronics.com/downloads/pdf/PCM%20User's%20Guide.pdf
"Champions are champions not because they do anything extraordinary but because they do the ordinary things better than anyone else." óChuck Knoll
Unread 09-14-2018, 04:46 PM
Rookie Year: 2015
I went through all that but still nothing changed.
Unread 09-14-2018, 04:54 PM
Rookie Year: 2015
I suspect something is wrong with the CAN because the PCM did not appear on the roboRIO Web-based configuration page but not sure how to fix that issue.
Unread 09-14-2018, 05:02 PM
Sounds like the CAN is not working properly.
If you haven't already, try it with just the PCM CAN terminals hooked to the RIO CAN terminals - double check that green connects to green, and yellow to yellow.
The red Power light on the RIO means you have a short on one of the RIO output ports, but it isn't CAN related.
We are what we repeatedly do. Excellence, then, is not an act, but a habit. -Aristotle
Unread 09-14-2018, 05:03 PM
Rookie Year: 2015
The only CAN system we have is with the PCM connected to roboRIO and PDP.
Unread 09-14-2018, 05:18 PM
philso philso is offline
You will probably want to add a 120 Ohm termination resistor across the yellow and green wires at the PCM to take the place of the one that is normally in the PDP.
Can you communicate with the PDP.
Unread 09-14-2018, 05:24 PM
Rookie Year: 2015
Communicate how?
Unread 09-14-2018, 05:35 PM
Communicate how?
Can you read back any current values for one of the channels. The value can be zero i.e. nothing is plugged into that channel. If you cannot communicate with the PDP and the PCM, it may be the CAN interface in your RoboRio is bad. You can then try swapping in a different RoboRio.
If you do find that you have a bad CAN interface in the PDP or PCM, get in touch with CTRE. They may be able to repair it for a reasonable price.
Unread 09-14-2018, 09:33 PM
Tom Line's Avatar
Tom Line Tom Line is offline
Don't lay blame. Fix probems.
FRC #1718 (The Fighting Pi)
Is your PCM at the end of the can chain or is it in between the Rio and PDP?
If it's at the end of the chain it MUST have a resistor in it to terminate the chain.
Unread 09-15-2018, 06:11 AM
Rookie Year: 2015
No it is in between both,
Unread 09-15-2018, 06:12 AM
Rookie Year: 2015
What do I use to read the PDP current values?
Unread 09-15-2018, 07:47 AM
You can check it through the Driver Station Log Viewer.
http://wpilib.screenstepslive.com/s/...og-file-viewer
Do you see the PDP listed on the roboRIO Web-based configuration page?
Unread 09-15-2018, 07:52 AM
Rookie Year: 2015
You can check it throught the Driver Station Log Viewer.
No only then roboRIO comes up.
Unread 09-15-2018, 07:58 AM
Then the whole CAN-bus is inoperable.
I'd still suggest testing a single component on the bus at a time with the roboRIO to isolate the issue.
Rewire each connection with new wire-redoing each of the connectors carefully, in case it's a wire whisker type short.
Just use a new set of wires temporarily:
First, directly wire CAN from the roboRIO to the PDP and just see if the PDP then shows up on the configuration page.
Second, just wire the PCM-no PDP (don't bother with a 120ohm terminator for this test), just direct connect it alone to the roboRIO and see if it shows up on the configuration page.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
