OCCRA
Go to Post Of course, the banana might mean nothing. It could just mean that Dave needs more potassium in his diet. :) - KathieK [more]
Unread 10-08-2018, 07:59 PM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
pic: 2019 Round 1 Event Assignment
Unread 10-08-2018, 08:09 PM
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #2767 (Stryke Force, Thunder Robotics, Team F.U.N.)
Skyehawk has a reputation beyond reputeSkyehawk has a reputation beyond reputeSkyehawk has a reputation beyond reputeSkyehawk has a reputation beyond reputeSkyehawk has a reputation beyond reputeSkyehawk has a reputation beyond reputeSkyehawk has a reputation beyond reputeSkyehawk has a reputation beyond reputeSkyehawk has a reputation beyond reputeSkyehawk has a reputation beyond reputeSkyehawk has a reputation beyond repute
Re: pic: 2019 Round 1 Event Assignment
Nice work. That underlying shape file of the US is a little rough though. I don't know if that is a limitation of how you made the map.
Radial flow maps are interesting, the scale for this may be a bit to small (the area you are covering is to large). It may be interesting to bin the incoming lines to 10-20 degree increments and for each event create a circular bar plot or a polar graph of the coefficient of variation for each bin vs. the whole.
(If you have the raw data would be interested in playing with it in arc map)
My time in FIRST has made me a better person, frankly I don't know where I'd be without it.
  • A small mountain of hardware, good memories & life lessons with 876: 2011 - 2018
  • Inevitable good times upcoming with 2767 : 2018 - ????
Unread 10-09-2018, 04:34 AM
AriMB's Avatar
FRC #5987 (Galaxia)
I generated the maps with python's matplotlib and Basemap. The libraries weren't particularly well documented or easy to use, so there may be a way to increase the resolution that I didn't see.
You can find a csv file with each of the team and event coordinates, and the TBA event type number* here. The team coordinates are from FIRSTmap and the event coordinates are from TBA. I'm interested in seeing how you can use this data.
*0=Regional, 1=District, 2=DCMP, all other events excluded
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
Unread 10-09-2018, 07:33 AM
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
Yeah... basemap is good for sanity checks at large(r) scales and not much else, i.e. it's fine for plotting a satellite trajectory w/ point data, but falls apart when you need it for actual location on the map. (There may be a way to increase the pyrimid level (resolution) that I am not aware of.)
A better option would be to use cartopy to bring in a shape layer of state outlines, (maybe add US_Major_Roads while you're at it), add the team data, and project it.
I think I will try to get my travel times script going and use that data, I may manually throw together an event chart as discribed in ny previous post. Off the top of my head matplotlib is the only package I know of that has a fighting chance of doing it automatically. Qfter that I think a custom expression in adobe may be the only real option (or generate it with custom code).
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
