OCCRA
Go to Post I'm still trying to find a way to get FIRST to dump the Chicken Dance song. :p - Koko Ed [more]
CD-Media
Unread 10-09-2018, 12:08 PM
D_fence_1418 D_fence_1418 is offline
FRC #1418
D_fence_1418 is an unknown quantity at this point
Repairing Talon Motor Controllers
We have a drawer in our electronics bin that has 8 broken Talon motor controllers sitting in it. I'v opened them up to find issues only to discover no visible burn marks on the PCB and that the capacitor (which I expected to be the issue) was totally ok.
Could this be a failure of an onboard component we cannot replace and does anyone else have a similar issue? Just want to see if there is any hope for these parts.
Exact part: http://www.andymark.com/Talon-SRX-p/am-2854.htm
Unread 10-09-2018, 12:11 PM
JamieSinn's Avatar
JamieSinn JamieSinn is offline
Mentor - 1334/1374
FRC #1334 (OT Robotics)
JamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond repute
Re: Repairing Talon Motor Controllers
How are they "dead"?
Is the status LED red when connected to power and CAN?
You could try a firmware update/recovery since it's likely a firmware issue.
It's also worth noting that any of these that you opened cannot/shouldn't be used in competition (modifying electronics)
1334/1374 Control Systems Mentor
Unread 10-09-2018, 12:13 PM
FRC #1418
Two do not power on, the rest are red when fully wired up.
Unread 10-09-2018, 12:14 PM
JamieSinn's Avatar
Mentor - 1334/1374
Go through the troubleshooting steps listed here:
https://www.ctr-electronics.com/Talon%20SRX%20User's%20Guide.pdf
(At the bottom)
It should tell you what kind of state it's in, and whether it needs to go to CTRE or not.
Unread 10-09-2018, 12:32 PM
Unsung FIRST Hero
Chief Robot Inspector
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
If you open the controllers, do they power up with the case removed? We had a few (not recently) that had issues with the wiring contacting the case or for PWM/CAN wiring to be crimped together. A little TLC correcting the issues and then reassembling brought them back to life.
However, not all electronic failures will show up as scorch marks. The CPU could be dead and never show any outward signs.
Al
WB9UVJ
www.wildstang.org
________________________
Knowledge is power. Power UP!
Unread 10-09-2018, 02:55 PM
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
(At the bottom)
To add to this, CTRE/VEX has great customer support and are usually interested in getting defective units sent back to them so they can evaluate the failure (and they've been known to provide replacements too). It might be worth calling/emailing their support.
2005-2008: FRC 703 Phoenix - Robot Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
