OCCRA
Go to Post I WANT to see teams succeed. - Steve W [more]
  #91   Spotlight this post!
Unread 11-14-2017, 03:33 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: FRC Blog - 2018 Beta Teams, Brushless Motors, and More!
Does anybody know how many stator pole pairs and rotor pole pairs this 2018 FRC BLDC motor has??
Does anybody know if it's trapezoidally or sinusoidally wound?
Does it use 3 Hall sensors for commutation?
If so, is the tach signal derived from the 3 Hall sensors, or is there a separate tach sensor?
Oh... @Mark: what's causing the jerking in the video?
  #92   Spotlight this post!
Unread 11-14-2017, 03:45 PM
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Originally Posted by Richard Wallace View Post
I can confirm that teams can purchase the crimp terminal that fits the harness connector housing (terminal is Molex 16-02-0103), and connect the Pin 1 Tachometer to a digital I/O.
Thanks, I ordered some terminals to use in testing.
We are what we repeatedly do. Excellence, then, is not an act, but a habit. -Aristotle
  #93   Spotlight this post!
Unread 11-14-2017, 03:48 PM
Just Itinerant
The torque of full reversal of shaft direction-full forward to full reverse and back again.
  #94   Spotlight this post!
Unread 11-14-2017, 03:56 PM
Ether's Avatar
Rookie Year: 1969
Judging from the relatively small reaction, the ratio of the moment of inertia of the rotor to the moment of inertia of the remaining (static) parts of the motor appears to be significantly smaller than other FRC motors... probably due to the lightweight rotor typical of brushless motors compared to the apparently more massive static parts of this BLDC motor compared to equivalently powerful brushed FRC motors.
  #95   Spotlight this post!
Unread 11-15-2017, 11:18 AM
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
The Dynamo has five electrical cycles per mechanical rotation; i.e., ten magnetic poles (5N, 5S).
It is single-tooth wound. There are twelve stator slots (thus twelve teeth) and each coil is wound on one tooth.
The resulting back-EMF and flux-linkage are sinusoidal functions of angular shaft position.
There are three Hall-effect sensors (surface mounted on the Greendrive circuit card) that produce commutation signals in response to a magnetized disc on the shaft, just below the card.
The Tachometer signal is derived from the Hall sensors; thus there are 15 Tach pulses per mechanical rotation (3 Halls x 5 pole-pairs).
Mark is right about the jerking seen in the video; it indicates relatively quick reversals. You are correct about the ratio of reversing torque to rotor inertia; this is an inherent advantage of in-runner type brushless PM motors, compared with conventional brush-type PMDC motors.
Mark, can you measure the transient DC supply current during rapid reversal? A 'scope trace would be nice to see. I can do that myself, but due to travel I will be away from my lab for a couple of weeks.
Richard Wallace
since 2003
  #96   Spotlight this post!
Unread 11-15-2017, 01:26 PM
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond repute
Originally Posted by MrRoboSteve View Post
Stronghold is a good example. You might have had a string that looked like:
ACEBF 00120 BADCE 02210
Where the letters represent the defense configuration and the digits represent the current crossing state, for both alliances.
This is what I was assuming as well when I first read it. Maybe something to indicate which goal is "Hot" and gets a bonus, maybe something right before autonomous which might make you change what strategy you use....
I predict the string will have the following properties:
1) Not be required to use to score points
2) Impart some advantage if you can display it to the driver, and allow the human to make decisions
3) Impart lots of advantage if you can parse it and use it to control the robot automatically
For the sake of crowd interaction, you'd probably also want the same data displayed to them (somehow) so they can understand why robots are doing certain things, or why (perhaps) the same action has different point values. It would definitely require some creativity to make the teams use the string, and not whatever the audience gets.
In any case, I fully plan on having our team log all strings received to file for later analysis.
  #97   Spotlight this post!
Unread 11-15-2017, 02:01 PM
Waz Waz is offline
AKA: Steve
FRC #6843 (Guardian Gears)
Waz will become famous soon enoughWaz will become famous soon enough
Originally Posted by gerthworm View Post
For the sake of crowd interaction, you'd probably also want the same data displayed to them (somehow) so they can understand why robots are doing certain things...
I think the ghosts the robots are chasing changing color will be sufficient.
Anyway.... I do think you are on the right track.
Steve
Edit: Hmmm.... human players in color changing ghost costumes....
  #98   Spotlight this post!
Unread 11-15-2017, 05:06 PM
Ether's Avatar
Rookie Year: 1969
The Dynamo has five electrical cycles per mechanical rotation ... There are three Hall-effect sensors (surface mounted on the Greendrive circuit card) that produce commutation signals ... The Tachometer signal is derived from the Hall sensors; thus there are 15 Tach pulses per mechanical rotation (3 Halls x 5 pole-pairs).
5 electrical cycles per mechanical rotation
times
6 commutation steps per electrical cycle
equals
30 commutation steps per mechanical rotation
which means
30 Hall edge detections per mechanical rotation
So therefore the tach rating of "15" must mean 15 complete lo/hi cycles per mechanical rotation, or 30 rising+falling edges per mechanical rotation... so the edge-edge resolution would be 12 motor shaft degrees. Yes?
I'm guessing the motor is sinusoidally commutated when it has an encoder?
  #99   Spotlight this post!
Unread 11-15-2017, 07:45 PM
Rookie Year: 1996
Yes, if the Hall sensor signals are exactly 50% duty and exactly 24 degrees apart.
Reasonable guess. We had in mind to do that when the motor was initially developed, many years ago. I will ask the engineers who support this motor now, when I see them.
Richard Wallace
since 2003
  #100   Spotlight this post!
Unread 11-15-2017, 08:17 PM
Ether's Avatar
Rookie Year: 1969
Ah. I was wondering about that.
... 6 commutation steps per electrical cycle ... so the edge-edge resolution would be 12 motor shaft degrees. Yes?
Commutation accuracy affects motor efficiency. Like everything else in engineering it's a tradeoff I guess. What's a typical design goal for 6-step commutation accuracy? Or better yet, do you have access to the specs for the edge tolerances for the tach signal?
  #101   Spotlight this post!
Unread 11-15-2017, 08:34 PM
Just Itinerant
Tested the pins that aren't part of the cable harness.
The Tach (fast & slow traces below) and Direction pins work.
Tach video (stop->slow->fast)
There isn't a Quad encoder on the FIRST model, so nothing from those pins.
ID:	22665  Click image for larger version
  #102   Spotlight this post!
Unread 11-15-2017, 08:47 PM
marshall's Avatar
marshall marshall is offline
Online Stripe & Drape Sales
FRC #0900 (The Zebracorns)
marshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond repute
The shaft does come through the back side (once you remove the housing) and would make connecting an encoder on the rear easy enough but I'm not sure what will be legal to modify in terms of the housing for this motor... Definitely room for an aftermarket encoder though.
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Clarke's Laws
  #103   Spotlight this post!
Unread 11-15-2017, 09:02 PM
Just Itinerant
This was the trace on the DC supply during a rapid reversal.
(I was without a single thumbdrive, because I came from a sponsor event, so it's a real snapshot.)
  #104   Spotlight this post!
Unread 11-15-2017, 09:31 PM
Rookie Year: 1996
Looks like the 'scope trace transient ranges +/- 40 mV. What does that correspond to, in Amperes? What kind of probe did you use?
Richard Wallace
since 2003
  #105   Spotlight this post!
Unread 11-15-2017, 09:35 PM
Just Itinerant
It was a 1x passive probe. I may have had the scope set on AC though.
I don't know what the input impedance of the probe was. It was borrowed.
I can play with it again tomorrow.
P.S.
I only have a stand-alone clamp meter. I'll have to borrow a probe to measure current.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
