Go to Post I dunno, with those Chucks, I'd be inclined to say he out-dresses the better part of DC... - Nuttyman54 [more]
  #16   Spotlight this post!
Unread 11-14-2017, 02:20 PM
AndreaV AndreaV is offline
FRC #1360
AndreaV has a spectacular aura aboutAndreaV has a spectacular aura aboutAndreaV has a spectacular aura about
Re: The tools you can't get through FRC build season without?
A simple set of nail clippers from anywhere is by far the best thing to cut off excessive zip tie length, the concave blade leaves a rounded edge.
2005-2006,2011 FRC 865 Warp7 Student, Mechanical team
2013 FRC 1310 RUNNYMEDE ROBOTICS Mentor, CAD and Manufacturing
2014-2015 FRC 5031 Downsview Robotics Mentor, Design and Manufacturing
2016-Present FRC 1360 Orbit Community Robotics Mentor, Design and Manufacturing
  #17   Spotlight this post!
Unread 11-14-2017, 02:54 PM
MonroeM MonroeM is offline
FRC #3570
Rookie Year: 2015
MonroeM is an unknown quantity at this point
A few essentials:
Kant-Twist Clamps
http://clampmfg.com/kant-twist/
Deburring Tool
https://www.mscdirect.com/product/details/05750997
Red Sharpies
https://www.target.com/p/sharpie-174...68#lnk=sametab
  #18   Spotlight this post!
Unread 11-14-2017, 03:01 PM
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
Cynicism isn't wisdom
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
Tenryu Alumi-Cut miter saw blades (example)
Lenox DIEMASTER 2 band saw blades with 14/18V tooth set (vendor)
Bright finish HSS screw machine length drill bits, in bulk quantities, stored in a Huot dispenser cabinet.
  #19   Spotlight this post!
Unread 11-15-2017, 12:19 AM
sanddrag sanddrag is offline
On to my 17th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Why would you ever leave any edge on a cut zip tie? Does anyone in industry seriously use nail clippers for cutting zip ties? I think not. Flush cutters used by competent operators is where it's at.
  #20   Spotlight this post!
Unread 11-15-2017, 12:34 AM
mman1506 mman1506 is offline
Reversible bumpers are my trigger
AKA: Marcus Quintilian
FRC #5406 (Celt-X)
Team Role: Mechanical
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
TS100 Soldering Iron. You can power it off a FRC battery in a pinch. If you think it's too small for heavy gauge wire, you'd be mistaken. It's even replaced my Hakko soldering station.
2012-2015: 865 Warp7 Team Captain
2016/17: Free Agent Mentor
2018: 5406 Celt-X
  #21   Spotlight this post!
Unread 11-15-2017, 09:13 AM
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
Rookie Year: 2012
InFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond repute
Originally Posted by Nate Laverdure View Post
Does this work well in practice? Seems like the 1/2" hex broach is nearly as long as the "max working height" of the press, which would only let you broach thin stuff.
They make bench sized 10 Ton Hydraulic Presses in the sub $300 range. This would give you over 13" of working height.
https://www.northerntool.com/shop/to...1793_200641793
The larger 20+ ton floor models would obviously do the job with ease if you have the dedicated space. The working range on these is beyond large.
  #22   Spotlight this post!
Unread 11-15-2017, 09:31 AM
brandon5638's Avatar
brandon5638 brandon5638 is offline
I make the robot work (sometimes)
AKA: Lundo
FRC #5638 (LqPV Robotics)
Rookie Year: 2015
brandon5638 is a splendid one to beholdbrandon5638 is a splendid one to beholdbrandon5638 is a splendid one to beholdbrandon5638 is a splendid one to beholdbrandon5638 is a splendid one to beholdbrandon5638 is a splendid one to beholdbrandon5638 is a splendid one to beholdbrandon5638 is a splendid one to behold
I'm surprised nobody has said this yet, but pliers are pretty useful. https://goo.gl/zsT2QW
Doing is better than hoping.
2015 - Northern Lights Quarter Finalists, Minnesota State Qualifiers
2017 - Iowa Regional Semi-Finalists, Minnesota State Qualifiers
2018 - Great Northern Regional Finalists, Minnesota North Star Quarter Finalists, Minnesota State Qualifiers
2019 - ?????
  #23   Spotlight this post!
Unread 11-15-2017, 09:33 AM
FRC #2363
Team Role: Coach
Rookie Year: 1999
Originally Posted by InFlight View Post
They make bench sized 10 Ton Hydraulic Presses in the sub $300 range. This would give you over 13" of working height. The larger 20+ ton floor models would obviously do the job with ease if you have the dedicated space. The working range on these is beyond large.
Yep, sure.
Related thread
  #24   Spotlight this post!
Unread 11-15-2017, 09:39 AM
philso philso is offline
Mentor
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
^ Please do this or just leave them uncut and tuck the tail in somewhere. The cut end that is not flush with the "head" of the zip-tie can cut you.
  #25   Spotlight this post!
Unread 11-15-2017, 09:55 AM
Dominick Ferone's Avatar
Dominick Ferone Dominick Ferone is offline
FRC #5030 (The Second Mouse)
Dominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really nice
So looking through this I had a few questions for supplies I have never seen or used.
What are clecos/what are they used for?
The ferrule crimps, we have in the shop and never used them. We were just asking the advantages and uses for em yesterday but didn't know the name of them.
What are 1-2-3 blocks and purpose?
The Brake Vice, how does it work?
Thanks for the help.
2010-2013 Team 353 The POBots (Student)
2012 SBPLI Finalists, 2013 SBPLI Engineering Inspiration
2014-2018 Team 5030 The Second Mouse (Founder and Mentor)
2014 Rookie All-Star, 2016 NYC Regional Winners, 2018 CNY Regional Winners/Volunteer of the Year, 2018 Buckeye Regional Winners
  #26   Spotlight this post!
Unread 11-15-2017, 10:25 AM
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
R I P Georgia Dome
FRC #1102 (M'Aiken Magic & Team FUN)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
The worlds greatest temporary alignment holding tool for riveting. Used in aircraft manufacturing a lot if I'm not mistaken.
https://www.youtube.com/watch?v=DA1cMkTAgzs
Random video with demonstration. I'm not advertising that specific brand.
John Fogarty - 13 Years in FIRST - http://cceti.com
FLL 1102 -> FTC 3864/1102 | FRC 1102 -> FRC 1772 -> FRC 4901 -> FRC 5632 | FTC 11444 -> FRC 1102 | VRC 5817
Head Coach - FRC Team 1102 M'Aiken Magic
"By teaching students the power of STEM, we're M'Aiken Magic happen!"
2010 FTC World Championship Winner - FTC Team 3864 Driver/Captain
  #27   Spotlight this post!
Unread 11-15-2017, 12:06 PM
pkrishna3082's Avatar
pkrishna3082 pkrishna3082 is offline
love/hate relationship with swerve
AKA: Parthiv Krishna
FRC #3082 (Chicken Bot Pie) and FTC #13471 Mentor (Minnetonka)
Rookie Year: 2016
pkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond repute
They are used to make it easier and cleaner to plug wires into the Weidmuller connectors on the VRM, PCM, and the end of the PDP.
My posts constitute my opinions, and mine alone, and are not representative of the views held by my team.
2010-2011: FLL 11083, 13873 (Minnetonka Silver) - Programmer
2016-: FRC 3082 (Chicken Bot Pie) - Captain (2+ yrs), Programming Lead (3+ yrs), Driver (2+ yrs), Operator (1 yr), 2017&2018 Dean's List Finalist
2017-: FTC 13471 (Minnetonka/Tater Bot Hot Dish) - Founding Mentor
2017-: FIRST Volunteer - 2017 North Champs Student Ambassador
  #28   Spotlight this post!
Unread 11-15-2017, 12:53 PM
Mike Marandola's Avatar
Mike Marandola Mike Marandola is online now
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (LUNATECS)
Rookie Year: 2007
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
1-2-3 blocks are steel blocks that are ground to 1" x 2" x 3". Even $10 sets are usually close to size, squareness, and parallel within 0.0003". The blocks are made with various hole patterns but the most common is a combination of 23 tapped and clearance holes.
There are thousands of uses but they are mainly used for workholding setups. You can use the blocks as spacers or put a bolt in one of the tapped holes for a easy machinist jack. They can also be used with small strap clamps for holding small parts while sanding or cutting. Here is an example. At work I will occasionally stick a mag base to the large face and use it as a quick comparator. I doubt too many people are surface grinding in FRC but they are used a lot for blocking in material or parts on a magnetic chuck. This is a example setup I used when bending a few stainless rods. Adding two cap screws to the 1-2-3 block allowed the rods to stay perpendicular to the brake.
A vise brake is pretty much just a miniature press brake that can be put on a bench vise. The grizzly version just temporarily attaches to the jaws using magnets and you simply tighten the vise to increase the amount of bend in the material.
FRC 316 Student 2007 - 2011
FRC 316 Mentor 2012 - 2017
FRC 316 Lead Technical Mentor 2018 - ?
Last edited by Mike Marandola : 11-16-2017 at 03:15 AM. Reason: Spelling and added info about brake
  #29   Spotlight this post!
Unread 11-15-2017, 04:07 PM
ctt956's Avatar
ctt956 ctt956 is offline
Mostly Legal Volunteer
Rookie Year: 2016
ctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud of
Impact driver. Once you have one, you'll wonder how you got by without it.
Portable bandsaw. A lot more useful than you might think.
Angle grinder. In addition to cutting and smoothing ferrous metals and cleaning welds, it's also probably the fastest and most satisfying way to remove excess length from wood screws or cut any iron/steel fasteners that are stuck or otherwise unremovable. Get a paddle switch, and ideally, a grinder designed for cutting. Metabo has a good video on grinder safety.
Originally Posted by Mike Marandola View Post
-A quality label maker
Get one with a QWERTY keyboard rather than an alphabetical keyboard.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
  #30   Spotlight this post!
Unread 11-15-2017, 05:47 PM
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond repute
Or, better yet, get a computer controlled one so you can print labels with different layouts and you have a full sized keyboard to work with.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
