Go to Post The trick to designing is to identify the problem before finding a solution. - BJC [more]
Unread 01-12-2018, 09:13 AM
beanieweenie beanieweenie is offline
FRC #5987
beanieweenie is an unknown quantity at this point
Frequently burning VRM's
Our team has 3 out of 4 not working VRM's.
We're trying to find the cause of this, what could be the reason for the burnt/not working VRM's?
Unread 01-12-2018, 09:16 AM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Frequently burning VRM's
Maybe you are connecting things to the, that draw too much current?
Let us know exactly how you are using the VRM. What do you connect to it?
Unread 01-12-2018, 09:24 AM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
How have you determined that they're broken?
What was connected when they allegedly died?
What wiring practices are you employing to stop short circuits at the connectors?
What was happening with the robot's electrical system when they died?
Do you disconnect your main breaker before changing batteries?
Y'all got any more of them details?
Unread 01-12-2018, 09:50 AM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
While not disconnecting the battery SB connector under load is certainly a good idea and generally a best practice, I am not sure if it any less electrically Noisey than the breaker switch. It not like there is a lot of load on it.
We have found the VRM very reliable. But we are very careful with the electrical. With the little information given, I would start with looking for shorts and making sure you are not trying to draw too much current. Talking directly to CTRE customer service would be useful too.
Unread 01-12-2018, 01:58 PM
philso philso is offline
Have they been connected with the input voltage reversed? Have the outputs been connected to the 12 V from the PDP?
My understanding is that the VRM has two switching regulators in it, one to make the stable 12 V output and one to make the 5 V output. These circuits typically have very good self-protection features and usually can survive a short circuit.
If 3 in a row have died, check the input wiring from the PDP, both ends.
Unread 01-12-2018, 02:33 PM
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond repute
I can concur from experience. We accidentally had a pinched wire coming off of the VRM in 2016 and it was able to take it perfectly.
Unread 01-12-2018, 11:03 PM
You got a bunch of responses.
We'd like to hear back from you.
Unread 01-13-2018, 11:26 AM
FRC #5987
We're connecting only the radio to the VRM, nothing else
Unread 01-13-2018, 12:26 PM
So does it work now?
It is most likely that an incorrect connection was made to the 12 V supply on the PDP. Unfortunately, if what you have now is working, the evidence of an incorrect connection will have been destroyed.
In the future, have a second, detailed oriented person check EVERY wire against the wiring diagram before applying power.
Unread 01-13-2018, 01:44 PM
FRC #5987
We checked the connections, they are okay, the burnt VRM's are not working no matter what, our other VRM is working fine so we assume that they probably drew too much current.
Unread 01-13-2018, 09:25 PM
As stated before, all of the chips used in designs like this are designed to protect the circuit from output short circuits without sustaining permanent damage. All the ones I have worked with could withstand having a constant short applied across the output and will start working properly once the short is removed. It is virtually impossible for a chip manufacturer to sell one that cannot do this now.
It is more likely that the dead ones were connected with the input wires reversed or the 12V input was connected to the outputs. That is why I suggested that in the future, have a second, detailed oriented person check EVERY wire against the wiring diagram before applying power. This is standard operating procedure in a manufacturing environment.
For a definitive answer, you can contact CTRE and ask if they will perform a failure analysis on the dead ones if you send them back to them. Since they are the developers of this product, they are likely to have seen examples of many different failure modes. They might even be able to repair them for a reasonable fee . Sorry, I just noticed that you are in Israel so the cost of the shipping might make it impractical to ship the dead ones around.
Unread Yesterday, 09:11 AM
FRC #5987
We'll make sure to check the connections before applying power.
Thanks everyone!
Unread Yesterday, 09:20 AM
Thanks everyone!
Please save those burned-out VRMs in a safe place, and bring them to the US if you guys go to champs.
Give them to CTRE for autopsy.
You really should find out what caused their death, so you can learn what not to do.
Unread Yesterday, 09:31 AM
FRC #5987
We'll make sure to do that, thank you!
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
