OCCRA
Go to Post and Bob's your uncle. - Joe Johnson [more]
Unread 04-15-2018, 12:14 PM
npbartelt's Avatar
npbartelt npbartelt is offline
AKA: Noah Bartelt
FRC #6381 (Red Raider Robotics)
Rookie Year: 2010
npbartelt is an unknown quantity at this point
Swerve drive introduction
Our team is looking at doing an offseason swerve drive project this summer to serve as an introduction to the concept. We're thinking about just coughing up for the AndyMark swerve modules in order to maximize the time our programming team gets, as well as to minimize initial frustration. Does anybody have insight into these modules? Are they worth it? Or does anybody have a suggestion for a relatively easy to manufacture swerve design? We have CNCs, 3D printers, and a plasma cutter, but our time that we will actually have in the shop this summer will be somewhat limited.
Unread 04-15-2018, 12:25 PM
C4's Avatar
C4 C4 is offline
AKA: Charlie Lockyer
FRC #4505 (McDonogh Robotics)
Team Role: Student
Rookie Year: 2017
C4 has much to be proud ofC4 has much to be proud ofC4 has much to be proud ofC4 has much to be proud ofC4 has much to be proud ofC4 has much to be proud ofC4 has much to be proud ofC4 has much to be proud of
Re: Swerve drive introduction
What main build system do you use (e.g. Versaframe, sheet metal, AM)?
“When you're a winner you're always happy, but if you're happy as a loser… you'll always be a loser.”
The views I express in my posts almost never represent the views of my team.
Unread 04-15-2018, 12:43 PM
OwenD's Avatar
Happy Birthday! OwenD OwenD is offline
AKA: Owen Dray
FRC #2067 (Apple Pi)
Team Role: CAD
Rookie Year: 2016
OwenD will become famous soon enoughOwenD will become famous soon enough
From what I have heard the andymark modules tend to wear pretty fast, but with some modifications can be made to work reliably. If you are only using them to program and don't plan on using them in competition they can be a good place to start.
In terms of design of your own modules, definitely avoid things like slip wrings and CVT/two speed as they significantly over complicate things. I have posted the full cad of the modules we (apple pi) used in the past and I would consider them to be relatively simple when compared to other swerve designs, but they are still very complex. The CAD posted before build season for this year was still a prototype, I will be posting the final version in the coming weeks.
It is also worth looking into 1640s non-cvt modules as well as the documentation they have on their site, it is very extensive and they are excellent at swerve.
Unread 04-15-2018, 01:31 PM
npbartelt's Avatar
AKA: Noah Bartelt
Rookie Year: 2010
We'll probably use 2x1 tubing that's either welded or riveted together, similar to versaframe.
Unread 04-15-2018, 05:20 PM
wgorgen's Avatar
wgorgen wgorgen is offline
FRC #1533 (Triple Strange)
Rookie Year: 2014
wgorgen is a splendid one to beholdwgorgen is a splendid one to beholdwgorgen is a splendid one to beholdwgorgen is a splendid one to beholdwgorgen is a splendid one to beholdwgorgen is a splendid one to beholdwgorgen is a splendid one to behold
I'm biased, but I think our swerve modules are pretty simple.
https://www.chiefdelphi.com/forums/s...hreadid=164790
All the parts are either COTS or flat pattern that you could easily cut with your plasma cutter (we use waterjet to cut our parts). The only tricky part is machining the groove for the ball bearings, but this can be done very easily on your CNC (we cut the groove on a simple mill using a rotary table).
I know we posted the CAD for version 4.0 last year. Version 4.1 is a relatively small change to switch to Colson wheels for better tread life. I will check with my son and see if he posted the CAD for that version.
https://www.chiefdelphi.com/forums/s...d.php?t=152393
Link to version 4.0 CAD files:
https://grabcad.com/library/strange-swerve-4-0-1
As far as coding, our code was also posted last year. The code is very straight forward. You need to adjust the length and width of the robot and that is about it. The vector math takes over from there.
Link to code:
https://github.com/ecgrobotics/Strange-Swerve
If you have the means to cut the custom parts, I would recommend trying this design. It has gone through a lot of refinement and is very solid now.
Unread 04-15-2018, 05:32 PM
C4's Avatar
C4 C4 is offline
Team Role: Student
Rookie Year: 2017
If you're using 2x1, I'd definitely look at 1533's 4.1 modules. Those are really solid and work really well with versaframe-esque stuff.
Unread 04-15-2018, 06:38 PM
npbartelt's Avatar
AKA: Noah Bartelt
Rookie Year: 2010
Thanks for the advice! I'll be on the lookout for your CAD.
Unread 04-15-2018, 06:40 PM
npbartelt's Avatar
AKA: Noah Bartelt
Rookie Year: 2010
Thanks! That looks pretty doable. Is there a BOM anywhere with the estimated price?
Unread 04-16-2018, 09:51 AM
tdogb tdogb is offline
FRC #6502
tdogb is an unknown quantity at this point
Link to code:
How did you guys get that large gear for steering? Did you edm it?
Unread 04-16-2018, 11:50 AM
dmpage318 dmpage318 is offline
Rookie Year: 2012
dmpage318 is an unknown quantity at this point
We used waterjet last year and tried laser this year, and both work fine. The quality isn't quite what you get out of a professionally made gear, but we've never been concerned about that because it's in a low-speed, low-load application.
Unread 04-16-2018, 12:06 PM
EvanRS1023's Avatar
EvanRS1023 EvanRS1023 is offline
I like team t-shirts!
AKA: Evan Schimmel
FRC #2410 (Metal Mustang Robotics)
Team Role: Scout
Rookie Year: 2017
EvanRS1023 is a glorious beacon of lightEvanRS1023 is a glorious beacon of lightEvanRS1023 is a glorious beacon of lightEvanRS1023 is a glorious beacon of lightEvanRS1023 is a glorious beacon of light
2410 has used the Andymark Swerve & Steer Modules for the past two years. (2017 & 2018) They're mechanically sound, but they are decently heavy. (our drivetrain was around 60lbs iirc) As with swerve, there's encoders. They're a pain to get to work, but when they work, they work great. The cost of the modules is a bit steep, but I'd go with them and get comfortable with swerve before venturing to design and manufacture your own modules.
Team 2410 - The Metal Mustangs
2017-Present: Scouting Lead & CAD
2018 Alliance Partners: 1710, 1723, 1984, 3633
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
