Go to Post Do not treat Vex and FLL as inferior because they may not get as much exposure as FRC on these boards. Just remember, FLL has seven times more teams than FRC from twenty additional countries. - artdutra04 [more]
Unread 04-16-2018, 12:18 PM
Zeenat Zeenat is offline
Zeenat is an unknown quantity at this point
Suggestions for Motor Controller
Hello,
We are looking for a suitable motor controller, but so far we are unable to find one which meets the following requirement:
We have a 4 wheeled robot with a payload of 150kg, and according torque and speed requirements our current requirement is 120A per wheel.
Currently we considered using 12 Talon SRX (one with each of the three motors per wheel). Is there some better solution available? Something that is within the cost range of approximately1500AUD.
Thanks a lot.
Unread 04-16-2018, 12:27 PM
darajaco's Avatar
darajaco darajaco is offline
Just a College Kid
AKA: Jacob Dara
FRC #7226 (Error 404)
Rookie Year: 2012
darajaco is a jewel in the roughdarajaco is a jewel in the roughdarajaco is a jewel in the roughdarajaco is a jewel in the rough
Re: Suggestions for Motor Controller
Sparks can handle up to 60A a piece and 120/3=40. If you're looking for a cheaper option those are only 51.50 AUD each.
Half the price of talons, biggest difference is that it runs PWM instead of CAN. Which could be nice because you can use PWM splitters to run the 3 motor controllers per wheel as one, streamlining programming.
2013-2017 2960 Automation Nation (Student)
2018-???? 7226 Error 404 (Mentor)
2015 Champs Tesla Division Semi-Finalist...2017 MSC Dow Division Finalist
2017 Southfield Event Winner......................2017 North Champs Daly Division Semi-Finalist
2017 St. Joseph Indiana Event Winner........2018 Shepherd Event Winner
Unread 04-16-2018, 12:32 PM
nickbrickmaster nickbrickmaster is offline
Human left pad
AKA: Nick Schatz
no team (3184 Alum)
Rookie Year: 2014
nickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond repute
Is the requirement 120A per motor or per wheel? If it's per wheel, then each motor controller only needs a continuous current of 40A, which is well within any FRC standard motor controller. If it's per motor, no FRC motor controller is rated for this.
Either way, using Talon SRXes is very expensive, twice as much so as the cheapest option. The only reason to use Talon SRXes is if you're using the built in closed loop features (onboard PID loops, current limiting, voltage ramping, etc.) If you're not planning on using these, then there are much cheaper options available, like the Spark controller or the Victor SPX, both of which support PWM. The Victor SPX also supports CAN, but if this is for a non-FRC project it may be more trouble than it's worth to port the libraries.
12 Sparks will set you back only $480, opposed to the 12 Talons which will cost $1080.
Proceed as if success is inevitable.
Unread 04-16-2018, 12:33 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
120A per wheel you say. How many (and what type) of motor(s) per wheel?
Unread 04-16-2018, 12:34 PM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I'm curious how you determined what your current requirement per wheel is.
Also, I'm curious how long this much current will be needed, or if the current demand drops off quickly once the robot begins moving.
Knowing these things, might help others help you determine what you really need.
Unread 04-16-2018, 12:38 PM
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
Rookie Year: 2011
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
http://www.ampflow.com/vex_motor_speed_controller.htm
I saw these when I was looking into battlebots. Looks like a Victor on steroids. I'm not sure if they make them anymore, though.
//TODO: make signature
Unread 04-16-2018, 12:46 PM
darajaco's Avatar
Just a College Kid
AKA: Jacob Dara
Rookie Year: 2012
Chad those are 400 bucks a piece
Unread 04-16-2018, 04:00 PM
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
But they are also rated at 300A continuous.... so it is possible they could use 2 of these controllers.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 04-16-2018, 04:09 PM
darajaco's Avatar
Just a College Kid
AKA: Jacob Dara
Rookie Year: 2012
Depending on drivetrain style might not be practical, if regular tank drive then yes makes sense but for mechanum or swerve (more likely set ups for 4 wheel independent driving) youd need the extra controlers.
Unread 04-16-2018, 04:23 PM
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond repute
"estimated 300A continuous" - why "estimated"?
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
