OCCRA
Go to Post Earlier today, I finally saw a copy of the [WFA] essay that was submitted by my team (there will be a separate reckoning later with all those that kept this a secret from me). The narrative overwhelmed me. - dlavery [more]
Unread 01-22-2018, 08:17 AM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: Am I Doing It Right Guys?
Everything old becomes new again:
https://www.youtube.com/watch?v=h3l6Xqts4to
Unread 01-22-2018, 08:22 AM
jnicho15's Avatar
jnicho15 jnicho15 is offline
Dannoooooooooo
AKA: Dan
FRC #0548 (Robostangs)
jnicho15 has a brilliant futurejnicho15 has a brilliant futurejnicho15 has a brilliant futurejnicho15 has a brilliant futurejnicho15 has a brilliant futurejnicho15 has a brilliant futurejnicho15 has a brilliant futurejnicho15 has a brilliant futurejnicho15 has a brilliant futurejnicho15 has a brilliant futurejnicho15 has a brilliant future
Originally Posted by bobbysq View Post
It almost certainly would if they also changed the shifter to a servo instead of a piston.
Nah man, door latch actuator.
My views or statements do not represent the views of my team or anyone else.
2014: MIHOW CA, Finalist; MILIV EI 2015: MISOU Finalist; MILIV CA, Winner; MIBED Winner; MICMP Winner
2016: MILIV CA; MICMP 16th Alliance- 8-F winner 2017: MISOU CA; MILIV EI; MICMP CA
2018: MILIV EI, MICMP EI, DAR-CUR Entrepreneurship
Unread 01-22-2018, 09:02 AM
cbale2000's Avatar
AKA: Chris Bale
FRC #5712 (Gray Matter)
I have actually been wondering about using these, but unless you're using a solenoid-type actuator (which have limited power under the solenoid rules and might not be strong enough), wouldn't you run into issues stalling the motor?
2005-2008: FRC 703 Phoenix - Robot Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 01-23-2018, 08:10 AM
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Yes unless the actuator had it's own detent built in or you added your own detent. Every lock actuator I've seen had no detent (plunger was free-moving when not powered) as they used the door lock mechanism itself as the detent.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
