OCCRA
Go to Post Step 1: Get Drill Step 2: Insert 1/2"-1" bit into drill Step 3: Drill Those Speed Holes! - Adam Richards [more]
CD-Media
Unread 08-20-2018, 02:56 PM
KarpTomer's Avatar
KarpTomer KarpTomer is offline
AKA: tomer Karpovsky
FRC #5987 (Galaxia)
Team Role: CAD
Rookie Year: 2017
KarpTomer is an unknown quantity at this point
pic: 2 speed flipped 4 775 pro gearbox
Unread 08-20-2018, 03:10 PM
baconbot's Avatar
baconbot baconbot is offline
Do the CAD, save the world.
AKA: James
FRC #3506 (YETI Robotics)
Team Role: CAD
Rookie Year: 2017
baconbot is on a distinguished road
Re: pic: 2 speed flipped 4 775 pro gearbox
I like the design, but I would personally choose not to use it on a west coast drive train. I prefer to use CIM motors for drive trains, and 775 motors for object handling and linear motion (elevators, etc.). Another thing that concerns me with this design is that you would probably not be in a good position if you got in a pushing match with a west coast drive using a 3 CIM shifter. I could see those motors getting smoked if you pushed them too far.
Nevertheless, your design looks like it would be good for a game where robot size is extremely limited, because it allows for extra space between gearboxes (assuming you are using them on a west coast drive train) to fit components.
That's all I the advice I can give without looking at the CAD. if you could post it, I would be able to get a closer look at it and maybe give some more advice.
Unread 08-20-2018, 08:57 PM
asid61's Avatar
asid61 asid61 is offline
Design Simple
AKA: Anand Rajamani
FRC #1072 (Harker Robotics)
Rookie Year: 2013
Not sure if you've been around CD recently, but there have been several discussions on the merits of 775s in many applications in the past few months. A search for "775pro drive site:chiefdelphi.com" on Google will bring up many relevant results to peruse.
The TL;DR is that 775pro drive gearboxes are ok with caution. A 8-775 drivetrain will very easily live the season with current limiting or 30A breakers on the motors.
Love the design. Very compact, and I love the offset gear to save space. One thing I have to mention is that the motor mounting plate looks pretty heavily pocketed and thin; changing to 1/4" material there might be prudent, and making the webbing thicker.
For free speed I'm getting about 18.5fps with a 4" wheel. That's not a bad free speed, but may be a little fast even with 4 775s. It really comes down to how your driver is handling it, so if you plan on making this, make sure your driver can handle it.
Team 1072 2017-present
Team 299 2017
Team 115 2013-2016 (student)
2018 Davis Finalists (w/ 6474 and 3880), 2018 Roebling Winners (w/ 3476, 1323, and 1778)
Unread 08-20-2018, 09:28 PM
NerdRage's Avatar
NerdRage NerdRage is offline
Student Captain
AKA: Aaron Fang
FRC #3863 (Pantherbotics)
Team Role: Student
Rookie Year: 2016
NerdRage has a spectacular aura aboutNerdRage has a spectacular aura aboutNerdRage has a spectacular aura about
Originally Posted by KarpTomer View Post
Since you're looking for feedback, the only thing I can say without seeing the CAD is that I would use a snap ring to hold the large cluster gear in place instead of the screw + washer. Granted, you might not have the capability to machine a groove, but I generally prefer snap rings since they're lighter and don't have the possibility of self-loosening.
FIRST Stronghold - LA Regional Judge's Award & Semifinalists, Ventura Regional Semifinalists
FIRST Steamworks - Orange County Quarterfinalists
FIRST Power Up - LA Regional Quarterfinalists, Ventura Regional Semifinalists
Unread 08-21-2018, 02:41 AM
KarpTomer's Avatar
FRC #5987 (Galaxia)
Team Role: CAD
Rookie Year: 2017
Hi thanks for the responses I published the CAD here
I am not sure how thick should the webbing be my webbing is 4 mm wide and the plates are 5 mm thick. when we will have our new CNC router setup we will start testing with the pocketing
Unread 08-21-2018, 02:59 AM
asid61's Avatar
Design Simple
AKA: Anand Rajamani
Rookie Year: 2013
I normally do approximately 6mm wide by 6mm thick webbing. Especially if this is your first custom gearbox like this, compromising with thinner webs may not be a good idea.
Team 299 2017
Unread 08-21-2018, 12:23 PM
Marcus Q Marcus Q is offline
Reversible bumpers are my trigger
AKA: Marcus Quintilian
FRC #5406 (Celt-X)
Team Role: Mechanical
Rookie Year: 2012
Marcus Q has a reputation beyond reputeMarcus Q has a reputation beyond reputeMarcus Q has a reputation beyond reputeMarcus Q has a reputation beyond reputeMarcus Q has a reputation beyond reputeMarcus Q has a reputation beyond reputeMarcus Q has a reputation beyond reputeMarcus Q has a reputation beyond reputeMarcus Q has a reputation beyond reputeMarcus Q has a reputation beyond reputeMarcus Q has a reputation beyond repute
Not sure if you've seen our 2018 gearboxes but they look to be pretty similar. Something we did was instead of webbing the plate for vents we pocketed out the area around the motor mounts to create a raised boss to space the motor from the plate. IMO it allowed for better airflow especially once you get to thicker plates. Conveniently it's also quicker to machine since you don't need to move to a tiny end mill to get sharp corners.
The pocketing ended up reducing the plate to about 5mm thick. This was a little too thin in our experience even though our design was a little better supported than yours. We had some issues where the plate would bend making the mesh uneven and causing premature pinion wear.
In the future we'd probably want to start with 3/8 in material but remove more of it leaving thicker ribs.
The other thing I'd note is if your designing a 32DP gearbox where the motors fully surround the gear instead of just being on one side you should add a little bit of distance to your C-C especially if your machine isn't capable of holding high tolerances. We didn't add any distance to our C-C which I think would of been fine in a single motor gearbox since there's some slop in the bearing and shaft that ends up increasing the CC. When the motors surround the gears it ends up over constraining the mesh and causing premature wear. +.001 - +.003 should be fine.
2012-2015: 865 Warp7 Team Captain
2016/17: Free Agent Mentor
2018-present: 5406 Celt-X
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
