OCCRA
Go to Post FIRST is all about working with others. - briholton [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 11-01-2017, 05:39 PM
Physics Quiz 13
Imagine an ideal* brushed DC motor whose +/- coil wires are directly connected to an adjustable DC voltage power supply, and whose output shaft is connected to a dynamometer capable of maintaining a constant torque.
The power supply is adjusted to 12 volts applied to the motor, and the dynamometer is set to maintain a constant load of To ounce inches on the motor's output shaft, and as a result the motor spins at Wo RPM and the motor is drawing Io Amps. Assume this operating point is well within the motor's safe continuous-duty operating range.
Without changing anything else, the applied voltage is adjusted down to 10 volts. Assume the motor is still spinning at this lower voltage. Ignoring secondary effects such as windage and bearing friction etc in the motor, to a first approximation what happens to the motor speed and current due to the decrease in applied voltage?
a) speed decreases and current decreases
b) speed decreases and current stays roughly the same
c) speed decreases and current increases
d) speed increases and current decreases
e) speed increases and current stays roughly the same
f) speed increases and current increases
* assume free speed current is zero Amps
Unread 11-01-2017, 06:43 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Physics Quiz 13
Ether,
Thanks for the warm-up as I was planning to start working out a mental model for brushless motors!
Gus
Unread 11-01-2017, 07:45 PM
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Physics Quiz 13
b).
Rep to the first concise, student-written response that explains why.
Richard Wallace
since 2003
Unread 11-01-2017, 08:14 PM
noah.gleason's Avatar
noah.gleason noah.gleason is online now
Rookie Year: 2016
noah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond repute
Re: Physics Quiz 13
Originally Posted by Richard Wallace View Post
b).
Alright, here's my shot: The DC motor state equation is Voltage = k*speed + current over windings * R, which means that voltage is being split between back-EMF (the first term) and actually producing torque (second term). We can ignore k and R because this is asking about relative increase/decrease and both are positive constants. When voltage decreases, one of the two must decrease along with it. However, we're told that torque is constant, so I*R must remain constant. Therefore k*speed must decrease, so the motor gets slower.
EDIT: The instantaneous effect is that current drops, because velocity can't change instantly. This reduces the torque for a moment, slowing the motor down until the back-EMF compensates entirely for the change in voltage.
Unread 11-01-2017, 10:51 PM
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: Physics Quiz 13
Not quite as concise as I'd hoped, but I'll give reps. More reps to a better/simpler student explanation!
Unread 11-01-2017, 11:05 PM
Brian M's Avatar
Brian M Brian M is offline
Design Lead
FRC #1360 (Orbit Robotics)
Team Role: CAD
Brian M has a brilliant futureBrian M has a brilliant futureBrian M has a brilliant futureBrian M has a brilliant futureBrian M has a brilliant futureBrian M has a brilliant futureBrian M has a brilliant futureBrian M has a brilliant futureBrian M has a brilliant futureBrian M has a brilliant futureBrian M has a brilliant future
Re: Physics Quiz 13
My turn!
B) because the same constant torque (To) is still applied to the shaft, thus speed decreases with the lower power input, but current stays the same.
2016 - Rah Cha Cha Ruckus Winners
2017 - Industrial Design (Durham), Entrepreneurship (McMaster), Quality Award (Ontario DCMPS)
Last edited by Brian M : 11-01-2017 at 11:41 PM. Reason: ......same idea, reworded.
Unread 11-02-2017, 01:18 PM
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: Physics Quiz 13
Originally Posted by Brian M View Post
My turn!
OK, but why is the current the same?
Unread 11-02-2017, 02:02 PM
Mark Wasserman's Avatar
Mark Wasserman Mark Wasserman is online now
FRC #2767 (Stryke Force)
Mark Wasserman is a splendid one to beholdMark Wasserman is a splendid one to beholdMark Wasserman is a splendid one to beholdMark Wasserman is a splendid one to beholdMark Wasserman is a splendid one to beholdMark Wasserman is a splendid one to beholdMark Wasserman is a splendid one to behold
Re: Physics Quiz 13
Let me see if I get this right:
Because torque and current go hand in hand. If the torque is constant then current must follow.
Unread 11-02-2017, 02:36 PM
Bob Steele's Avatar
FIRST Senior Mentor - Washington
AKA: Bob Steele
Re: Physics Quiz 13
In a DC motor, the output torque is directly proportional to the current through the windings
not sure what hand in hand means but I think this is what you mean....
4H TEAM 1983 Skunk Works Robotics- Seattle, Washington
Unread 11-02-2017, 03:02 PM
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has a brilliant futureCyberphil has a brilliant futureCyberphil has a brilliant futureCyberphil has a brilliant futureCyberphil has a brilliant futureCyberphil has a brilliant futureCyberphil has a brilliant futureCyberphil has a brilliant futureCyberphil has a brilliant futureCyberphil has a brilliant futureCyberphil has a brilliant future
Re: Physics Quiz 13
Originally Posted by Mark Wasserman View Post
.... then current must follow.
Someone has been reading too much DUNE.
Unread 11-02-2017, 03:55 PM
Re: Physics Quiz 13
You are thinking of Spice. Torque is not proportional to Spice.
But the Spice must flow...
Richard Wallace
since 2003
Unread 11-02-2017, 04:09 PM
Re: Physics Quiz 13
So now we know torque and current are directly proportional, can someone list at least 2 scenarios in FRC land where we could put this new found knowledge to use and how you might implement it?
Unread 11-02-2017, 04:29 PM
Brian M's Avatar
Design Lead
Team Role: CAD
Re: Physics Quiz 13
Because the % stall is the same?
Unread 11-02-2017, 04:32 PM
Brian M's Avatar
Design Lead
Team Role: CAD
Re: Physics Quiz 13
Well you wouldnt because we use 12 and 5v, and then only pwm to control speed. Maybe to compensate for battery undervoltage but even then wouldnt encoders and sensors solve that?
Unread 11-02-2017, 07:03 PM
Rookie Year: 2016
Re: Physics Quiz 13
I've got one but it's important: modeling your motors for open-loop control or for feed-forward in closed-loop. By driving the robot at a bunch of steady voltages, you can find the velocity vs. voltage curve (it's actually a line). The y-intercept of that line will give you the minimum amount of torque/current you need to overcome friction. The slope of that line gives K in the motor state equation I discussed above.
Once you have that equation, accelerate the robot any way you want (driving around works) and measure the voltage, velocity, and acceleration (use the derivative of velocity, not an accelerometer, they're too noisy). By subtracting out the voltage that the motor "should" draw according to the line you got above, you can find how much voltage is going towards "productive" (i.e. not fighting friction) torque. Plotting that voltage against acceleration gives you R, the resistance of the windings. With these measurements, you can upgrade your open-loop/feedforward from voltage=12*(velocity sp/max speed) to voltage = k*velocity sp + intercept + r*(acceleration), which almost fully characterizes the motor. The only things missing are inductance and capacitance, both of which are negligible for a drive motor and probably negligible for any mechanism slower than a can grabber.
