OCCRA
Go to Post Why is it whenever you tell someone there is a million billion stars in the universe they believe you, but if you tell someone that the bench over yonder has wet paint, or if usfirst.org comes up as the 1st result in Google people have to try it for themselves? - artdutra04 [more]
Unread 10-31-2017, 05:37 PM
Gamma +'s Avatar
Gamma + Gamma + is offline
FRC #2130
Gamma + is on a distinguished road
Screaming VRM !?!?
Has anyone experienced obnoxiously loud noises coming out of their Voltage Regulator Modules? When a single 12 volt led light ring is plugged into the VRM, either 2A or 500mA, it (the VRM) emits a painful high frequency whistle. Even weirder, when other 12v loads are plugged in (i.e. Radio), the noise stops.
Any ideas?
Unread 10-31-2017, 05:47 PM
pkrishna3082's Avatar
pkrishna3082 pkrishna3082 is offline
love/hate relationship with swerve
AKA: Parthiv Krishna
FRC #3082 (Chicken Bot Pie) and FTC #13471 Mentor (Minnetonka)
Rookie Year: 2016
pkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond repute
Re: Screaming VRM !?!?
This sounds like coil whine. I just want to confirm:
Do you mean that plugging in the radio WHILE keeping the LED ring plugged in eliminates the noise? Or do you take the LED ring out and then put the radio in?
Also, does the LED ring light up when you plug it in? If not, I would suspect a short circuit in the LED ring. Try testing the resistance across the LED ring with a multimeter. In the forward direction, it should be in the order of 100-1000 ohms I think. In the reverse direction it should be very large (megaohms). If that is not the case, you probably have a bad LED ring, potentially a short.
My posts constitute my opinions, and mine alone, and are not representative of the views held by my team.
2010-2011: FLL 11083, 13873 (Minnetonka Silver) - Programmer
2016-: FRC 3082 (Chicken Bot Pie) - Captain, Programming Lead, Driver, 2017 Dean's List Finalist
2017-: FTC 13471 (Minnetonka/Tater Bot Hot Dish) - Mentor
2017-: FIRST Volunteer - 2017 North Champs Student Ambassador
Unread 10-31-2017, 06:18 PM
Classified*'s Avatar
Classified* Classified* is offline
Drive it like you stole it
AKA: Julia Cecchetti
FRC #0291 (CIA: Creativity in Action)
Rookie Year: 2015
Classified* has much to be proud ofClassified* has much to be proud ofClassified* has much to be proud ofClassified* has much to be proud ofClassified* has much to be proud ofClassified* has much to be proud ofClassified* has much to be proud ofClassified* has much to be proud ofClassified* has much to be proud of
I have this same problem. Even when it is not powering anything it whines. It started suddenly too. Gets pretty annoying at 1 am.
2017 NEOFRA MVRC Winner with 2399 and 2252
2017 Steel City Showdown Winner with 2614 and 3260
2017 WOW Championship Finalist with 4145, 3138, and 3511
2016 Rachacha Ruckus Finalist with 5406 and 639
2015 Rachacha Ruckus Finalist with 1126 and 5406
2015 NEOFRA MVRC Finalist with 48 and 379
2015 Buckeye Regional Finalist with 48 and 5413
Team291.com
Unread 10-31-2017, 07:24 PM
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
I believe that is a normal and expected behavior.
2017 FIRST Championship Daly Division | 2017 Seven Rivers Regional Chairman's Award | 2017 Wisconsin Regional Dean's List Finalist (Grace Fanson)
Unread 10-31-2017, 07:33 PM
Rookie Year: 2016
Can't tell if you are being sarcastic, but we do not have this problem.
Unread 10-31-2017, 07:55 PM
ns3517's Avatar
ns3517 ns3517 is offline
FRC #0316 (Lunatecs)
ns3517 has a spectacular aura aboutns3517 has a spectacular aura about
This is not normal expected behavior from a VRM.
Unread 10-31-2017, 09:03 PM
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Our VRM does this too, not sure why. I took a video of it happening:
https://www.youtube.com/watch?v=Rbnn...ature=youtu.be
Does anyone know how to fix this?
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-Present (Huntington Beach, CA)
Team 612 Engineering Mentor (Chantilly, VA) Present
Unread 10-31-2017, 09:07 PM
You can get a high pitched whine from frequency switching devices if the switching frequency is low enough to be audible (20 to 20,000 Hz), especially at low loads.
2018 Beta Testing Results
Unread 11-01-2017, 12:27 AM
Tom Line's Avatar
Tom Line Tom Line is offline
Danger: Raptor Crossing
FRC #1718 (The Fighting Pi)
Errr... yes it is. The old blue PDBs will do it too with the right load.
Unread 11-01-2017, 07:41 AM
ns3517's Avatar
A single ring light alone will cause the VRM to emit a high frequency noise?
We had a large ring light light last year and did not get a noise like this.
Unread 11-01-2017, 08:42 AM
FrisbeeFunTime's Avatar
FrisbeeFunTime FrisbeeFunTime is offline
AKA: Erik Yngstrom
FRC #1768
Rookie Year: 2015
FrisbeeFunTime will become famous soon enoughFrisbeeFunTime will become famous soon enough
I think there are two different "expected" being thrown around here. Correct me if I'm wrong but the expected you're using seems to be in reference to the intended behavior of the device. The expected that those who are saying coil whine can be expected are not using it in this way. What they are saying is that although not intended, you have to expect to some extent that coil whine could be present in the board. I would also have to agree with cgmv123 on the statement that coil whine is a normal behavior. Take for instance the GTX 970. At launch A huge number of units have massive issues with coil whine, to the point where is was actually quite normal. After a little bit the issues stopped happening because Nvidia stopped selling its reference models and board partners started tweaking mainly power delivery stuff in the firmware which made the cards sold after have much less coil whine. This issue was most prevalent among people who bought lesser quality power supplies because lesser quality power can be a large factor of coil whine.
Unread 11-01-2017, 09:35 AM
ns3517's Avatar
This helps explain my view and makes more sense.
Unread 11-01-2017, 09:38 AM
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily is a jewel in the roughcpapplefamily is a jewel in the roughcpapplefamily is a jewel in the rough
My team just found one of these "Blue PDBs" last night putting together an off season project.
Unread 11-01-2017, 03:52 PM
Tom Line's Avatar
Does it whistle when you power it up? We always joked about it because everyone noticed it standing near the old bots.
Unread 11-01-2017, 05:32 PM
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Just be glad that you're young enough to still hear it.
Take it from us old guys protect your hearing always.
"Champions are champions not because they do anything extraordinary but because they do the ordinary things better than anyone else." óChuck Knoll
