OCCRA
Go to Post If you don't KNOW something as fact, please do not state it as fact. - dlavery [more]
CD-Media
Unread 10-29-2018, 07:54 AM
risho900 risho900 is offline
FRC #6897 (Astraea Robotics)
Rookie Year: 2015
risho900 is a name known to allrisho900 is a name known to allrisho900 is a name known to allrisho900 is a name known to allrisho900 is a name known to allrisho900 is a name known to all
Battery Cart Feedback
I recently designed a new battery cart for my team. I designed it to be able to fit and charge 9 batteries at once. (I plan on widening the battery compartments by an inch. Too tight of a fit right now). If you look closely though, you'll see that the aluminum actually has a slot on the ends. I plan to put some sort of material in between the slots but I don't know what material to place. Any suggestions will be most welcome. Also, I designed it to be a bench for my team so on the top there'll be some sort of covering BUT I want that to be a hinge so then underneath I can place chargers for power tools and such. Lastly, if you look in the front, you'll see two different colored panels - this is how I plan to access the batteries. The top portion will be rigid while the bottom will be hinged so if we need to access batteries, we open the bottom one down. When closed, it will be latched with the top. Obviously, though still need material suggestions for these panels too. The only issue I see is that the cart may not be able to support the weight of batteries, chargers, and humans. What you guys think of that?
Link: https://a360.co/2Q33y3r
Unread 10-29-2018, 08:28 AM
marshall's Avatar
marshall marshall is online now
"Who's Marshall?"
FRC #0900 (The Zebracorns)
Re: Battery Cart Feedback
The biggest issue I see if that you have about a foot between the ground and where most of the central mass is. On top of that, it's on a base that isn't super wide given how the central mass is distributed. I suspect this is going to be a bit tipsy.
Clarke's Laws
Unread 10-29-2018, 09:17 AM
Skuke Skuke is offline
AKA: Payton
FRC #0846 (The Funky Monkeys)
Skuke is an unknown quantity at this point
Originally Posted by risho900 View Post
... If you look closely though, you'll see that the aluminum actually has a slot on the ends. I plan to put some sort of material in between the slots but I don't know what material to place...
Lastly, if you look in the front, you'll see two different colored panels... The top portion will be rigid while the bottom will be hinged so if we need to access batteries, we open the bottom one down. When closed, it will be latched with the top. Obviously, though still need material suggestions for these panels too.
I'd make the panels clear plastic to allow for additional light to enter. ...maybe add some LED lighting?
I think the top rigid panel should be shorter (not extend down as far). I think it would be easier to lift the batteries in/out with a shorter panel. Don't forget you'll probably have cables attached which effectively increases the height of the batteries. You'll also want to reach in to disconnect the Andersons.
I also agree the the legs look a bit long. I get you want the batteries higher for easier access. Add gussets to the legs?
Skuke
Unread 10-29-2018, 09:36 AM
marshall's Avatar
"Who's Marshall?"
Good idea but not going to fix the tipping problem. That only gets fixed when you adjust the mass distribution.
Clarke's Laws
Unread 10-29-2018, 09:42 AM
philso philso is offline
It might be good to mock this up using what you have around already i.e. some shelving, some cardboard. The panel might get in the way of how you get to the batteries and may not actually be necessary.
Will you be using this cart at events? If so, you may want to use larger wheels. Will this fit in the back of a large SUV? It would also be good to have a way to restrain the batteries so they don't come out of their slots and get damaged. Lastly, make some accommodation for a power bar to power everything in the cart including tools, phone chargers etc.
Unread 10-29-2018, 10:20 AM
Rookie Year: 2015
Yeah I was gonna mount a power strip in back and I tbink bungee cord across top should restrain batteries. Also School provides a truck for transportation so we have space for it.
Unread 10-29-2018, 10:21 AM
Rookie Year: 2015
I see that. Didnít realize. Gotta think of something.
Unread 10-29-2018, 10:49 AM
bcampbell's Avatar
bcampbell bcampbell is offline
bcampbell has a spectacular aura aboutbcampbell has a spectacular aura aboutbcampbell has a spectacular aura about
I would suggest looking into cable management before moving forward. With the amount of money and effort being put into the cart, you want to make sure it provides easy access to your batteries in addition to being able to plug and unplug them easily.
The nicest battery carts that I have seen are ones that have integrated the wiring into their designs. I dont see by your current design an easy way to do that. Maybe some kind of bar that runs above the batteries would allow you to attach the connectors to it but that would be awkward from a plug/unplug ergonomics standpoint.
Here are some pics of our teams battery cart in the link below. Each battery connection is mounted under each battery which gives students easy access to pull any battery at any time. This battery cart is around 8 years old but we have had no reason to change/upgrade it as it has been rock solid.
https://www.chiefdelphi.com/forums/s...d.php?t=166088
Hope that helps. Otherwise I think it looks great.
Unread 10-29-2018, 10:56 AM
Rookie Year: 2015
Thought about that, I figured the amount of space I have in there would be enough for a person to navigate with their hands. I'll look into adding a bar though thanks!
Unread 10-29-2018, 11:52 AM
ChopinWood ChopinWood is offline
AKA: Paul Braun
FRC #4362 (GEMS)
ChopinWood will become famous soon enoughChopinWood will become famous soon enough
I second this notion. Figure out how you will mount the connectors to the cart and how to fit the batteries (with cables/connector). Try to make it easy for one hand operation. Optimize the design for the thing you will do most often with it... placing/plugging, unplugging/removing batteries.
Since it will be heavy, use the largest casters you can, and some beefy handles to help with loading and lifting over thresholds, etc. during pit moves.
You should be able to do stress analysis in Fusion 360 to determine if your shelf will hold everything. Its easy to learn and there are lots of tutorials online.
This looks like a great cart that will be around for many years !
2014-2018: Mentor, FRC 68 Truck Town Thunder
2019-Present: Mentor, FRC 4362 GEMS Robotics
Unread 10-29-2018, 12:12 PM
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
I definitely agree with this. Lower that bottom shelf as much as you can. With our current battery cart, the batteries sit on the bottom shelf, which is itself bolted directly to the top of 5" wheels (2 caster, 2 fixed) from Home Depot. That puts the majority of the weight as low as possible.
It's not clear how you're going to get the batteries in and out - lift them over the chargers? I would recommend finding a more ergonomic way. With our cart, the chargers are mounted directly above the batteries, giving us full access right in the front, with additional storage deeper inside the cart. Batteries can be pulled forward along the smooth shelf right into your hands. This helps reduce the urge to lift the batteries by the cables, something that should never be done. You're going to be accessing the batteries frequently, so make it easy on yourself! Remember, the pits can be cramped, so opening and closing doors can be difficult.
For the top, get a butchers block or an old solid-core door and cut it down to size - that's what we did. It's a bit heavy, but extremely durable and can take a beating when you need to do work, I have no problem putting something on it and beating it with a hammer if I need to. Attach it to the top with some door hinges and it'll stay put - you won't even need a latch on it. As a bonus, with something that durable, you can mount a vise to it, which always comes in handy! We also put some gas springs on it - they assist the lift, and when it's fully upright they can hold it up so you can dig around underneath it safely. Also, plan to get under it as infrequently as possible - you'll accumulate a lot of stuff on there, and the last thing you want to do is spend a bunch of time having to clear it off just to open it up.
Make your drill chargers easily accessible - you'll be swapping out drill batteries a fair amount.
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016-2018; Iowa 2017; Northern Lights 2018; Great Northern 2018-2019
Division LRI: Galileo 2016; Tesla 2017; Archimedes 2018
2016: Lake Superior WFFA
Unread 10-29-2018, 01:54 PM
You may want to use something like a non-conductive bar (wood?) that gets locked on top of the batteries and is visible from outside the cart when it is in place. Bungee cords will work if they are not too loose and if they are actually installed correctly. When they don't work, you can end up having to clean up the acid from batteries broken open by bouncing around in the cart.
Does the school own the truck or does it rent one each time your team goes to an event. You will want to make sure you have sufficient clearance under the cart to go from a ramp to the truck bed. The steeper the ramp, the more clearance you need. The team I currently mentor has a bunch of large cabinets that a previous mentor built for them. The casters give only around 6" of ground clearance. They have to rent a low deck trailer (no steep ramps) to get them to events. The trailer rental apparently cost them over $600 last year.
Unread 10-29-2018, 06:38 PM
Rookie Year: 2015
how do you guys usually attach casters to the bottom?
Unread 10-29-2018, 06:40 PM
Rookie Year: 2015
Tbh, I have no clue about school truck situation. First time they're giving transport so gotta see what they come up with.
Unread 10-29-2018, 06:47 PM
Rookie Year: 2015
No I plan to have a door in front of the batteries than will open down. Batteries can be lifted up and out pretty easily.
I thought about making it a workspace but we have a enough workspace, one cart and the table that's provided is enough I would think
Hmmm, what if I mount the chargers on the outside, that would be pretty interesting I think
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
