OCCRA
Go to Post i openly welcome our large game piece overlords - Chexposito [more]
Unread 02-19-2018, 07:55 PM
jfitz0807 jfitz0807 is offline
FRC #2877 (Ligerbots)
Team Role: Parent
jfitz0807 is an unknown quantity at this point
Network Tables not propagating from RoboRio
We are doing our vision processing with Python cscore on an odroid processor (small linux box). Our robot code is java. We are using NetworkTables to send data between the two.
We are monitoring the network tables via OutlineViewer.
In the robot java code, we're using SmartDashboard.putString('/vision/active_mode') to change the settings in the camera server. In the vision code on the odroid we're using the ntproperty ('/SmartDashboard/vision/active_mode').
When the robot code changes the property value, we see it in OutlineViewer, but the odroid python visionserver does not see the update. However, if we change the property in OutlineViewer, then the visionserver python code does see the change.
We even tried putting in a check in teleopPeriodic() to change the property every two seconds. The OutlineViewer updates, the code writes out the property to the riolog, but the visionserver still doesn't see the update.
Any suggestions are appreciated.
Unread 02-20-2018, 01:01 AM
Peter Johnson Peter Johnson is offline
Volunteer WPILib Developer, CSA
no team (WPILib)
Peter Johnson has a reputation beyond reputePeter Johnson has a reputation beyond reputePeter Johnson has a reputation beyond reputePeter Johnson has a reputation beyond reputePeter Johnson has a reputation beyond reputePeter Johnson has a reputation beyond reputePeter Johnson has a reputation beyond reputePeter Johnson has a reputation beyond reputePeter Johnson has a reputation beyond reputePeter Johnson has a reputation beyond reputePeter Johnson has a reputation beyond repute
Re: Network Tables not propagating from RoboRio
This sounds like the same issue as https://groups.google.com/forum/?utm...A/eZIJRWW0CAAJ ?
Don't put a leading slash on the SmartDashboard string.
WPILib Developer, 2014-Present:
  • Author of cscore - WPILib CameraServer for 2017+
  • Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
Mentor, Team 294, 2008-2018 (World Champions FRC 2010 & FTC 2008)
Unread 02-20-2018, 03:33 PM
Team Role: Parent
Thanks. I was actually sitting next to the guy who posted on google group. He posted there and I posted here.
Thanks for the help.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
