OCCRA
Go to Post I think I need a bigger cup of coffee.... - JaneYoung [more]
CD-Media
Unread 03-14-2018, 07:51 PM
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
paper: Driver Station Best Practices
Thread created automatically to discuss a document in CD-Media.
Driver Station Best Practices by MrRoboSteve
Unread 03-15-2018, 09:21 AM
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Re: paper: Driver Station Best Practices
Since the topic is the driver station in general, here are a few lessons learned the hard way:
- Use game controllers or other input devices that are hardwired, not with micro USB ports in the controllers.
- Your drivers will be most efficient if they never are required to remove their eyes from the robot during the match to look down at the driver's station. Use tactile feedback, if your controllers have that function, or status lights (LED light strips work well) on the robot as visual indicators.
- Enable software logging for everything you can, including controller inputs, feedback devices, limit switches, motor currents, etc. This can be invaluable when troubleshooting unexpected controllability issues or hardware failures during a match.
- Be sure your driver station and controllers are treated with care, and not abused, between matches. Build a protected spot on your robot cart if you have to.
- Use velcro to attach the drivers station to the shelf.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 03-15-2018, 12:18 PM
Doug Frisk's Avatar
Doug Frisk Doug Frisk is offline
Keeping Score
AKA: Doug Frisk
Doug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond repute
Here are the powershell snippets I made last weekend. Start Powershell as an administrator on the driver's station and cut/paste the appropriate bits.
# Turn off the currently enabled firewall profile,
$CurrentProfile = Get-NetFirewallProfile
Set-NetFirewallProfile -Profile $CurrentProfile.Name -Enabled False
#disable WiFi and Bluetooth
$adapters = Get-NetAdapter
foreach ($adapter in $adapters)
    if ($adapter.PhysicalMediaType -like "*802.11" -or $adapter.PhysicalMediaType -like "*BlueTooth")
        Disable-NetAdapter -name $adapter.Name -Confirm:$false
#Pause Windows updates
Set-Service -Name wuauserv -Status Stopped
# Turn on the currently enabled firewall profile,
Set-NetFirewallProfile -Profile $CurrentProfile.Name -Enabled True
#enable WiFi and Bluetooth
        Enable-NetAdapter -name $adapter.Name -Confirm:$false
#start Windows updates
Set-Service -Name wuauserv -Status Running
To Do list:
Orange County Regional
Northern Lights Regional
Great Northern Regional
Central Illinois Regional
Minnesota North Star Regional
Seven Rivers Regional
Unread 03-15-2018, 06:50 PM
AKA: Steve Peterson
Thanks, Doug.
I know the quality of the driver station is kind of a boring topic when compared to robots and game strategy. At week 1 and 2 events I saw/heard about enough bad driver station situations that teams should really pay more attention. It's particularly sad when the FTA has to bypass a team because of their driver station not working well.
2019 ∑ ?
2011 - present ∑ FRC 3081 Kennedy RoboEagles mentor
2013 - present ∑ event volunteer at[list truncated]
http://twitter.com/MrRoboStevewww.linkedin.com/in/spetersonI am hiring for my team at Microsoft
Unread 03-25-2018, 11:10 PM
frcguy's Avatar
frcguy frcguy is offline
Sitting behind a Toughbook
AKA: Nicholas Dal Porto
FRC #0190 (Gompei and the H.E.R.D.)
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Just had a chance to browse through this. Great document, thanks for compiling.
Team 5940: 2015-2018 | Team 190: 2018-present
Volunteer: 2016-present
Event Travel Spreadsheet
Unread 03-26-2018, 02:40 PM
GreyingJay GreyingJay is offline
we'll fix it in the pit
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Apparently in the driver station USB configuration screen, once you've scanned for your USB controller devices, you can double-click them to lock their assignments?
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 03-26-2018, 02:47 PM
Tom Line's Avatar
Tom Line Tom Line is offline
Don't lay blame. Fix probems.
FRC #1718 (The Fighting Pi)
If you are looking for cheap but solid drivers stations, I use arrow direct. They are mostly business computers coming of leases. I strongly prefer the business class lenovos with real (not the collapsible) Ethernet ports.
Unread 03-26-2018, 03:09 PM
AKA: Steve Peterson
Port locking has some key constraints that people don't always think about, so I don't recommend it.
Note: If you have two or more of the same device, they should maintain their position as long as all devices remain plugged into the computer in the same ports they were locked in. If you switch the ports of two identical devices the lock should follow the port, not the device. If you re-arrange the ports (take one device and plug it into a new port instead of swapping) the behavior is not determinate (the devices may swap slots). If you unplug one or more of the set of devices, the positions of the others may move, they should return to the proper locked slots when all devices are reconnected.
https://wpilib.screenstepslive.com/s...-by-ni-labview
2019 ∑ ?
Unread 03-26-2018, 11:34 PM
AriMB's Avatar
AriMB AriMB is online now
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Iíll add that itís fine fine to use a reputable* USB hub if you need more ports for joysticks or Ethernet dongles if you need. If you do use one, be sure to tie it down and properly strain relieve it so if you take a hit you donít lose all of your joysticks.
*Donít use one you found in a dollar store, spend a good $10-15 in an electronics store for one you know you can trust. It should have a built-in cable, not a separate micro USB port and cable.
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
Unread 12-02-2018, 06:46 PM
AKA: Steve Peterson
I've updated this document based on feedback I've gotten since the 2019 competition season.
2019 ∑ ?
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
