Go to Post It's all about that bumper quality. - Gutherie88 [more]
Unread 02-13-2018, 01:32 PM
Mood's Avatar
Mood Mood is offline
FRC #4183 (Bit Buckets)
Rookie Year: 2016
Mood is an unknown quantity at this point
Can't load firmware onto the radio.
Every time we try and load the firmware onto the radio, It throws an error saying it can't find the NPF device except we checked and the computer detects the radio with the same name. It detects the radio when try to configure it but obviously throws a old firmware error. We've tried both ports. Any advice?
Unread 02-13-2018, 01:56 PM
forbes's Avatar
forbes forbes is offline
NYC Googler
AKA: Evan Forbes
FRC #0694 (StuyPulse)
Rookie Year: 2012
forbes has a brilliant futureforbes has a brilliant futureforbes has a brilliant futureforbes has a brilliant futureforbes has a brilliant futureforbes has a brilliant futureforbes has a brilliant futureforbes has a brilliant futureforbes has a brilliant futureforbes has a brilliant futureforbes has a brilliant future
Re: Can't load firmware onto the radio.
Did you try this?
If you see an error about NPF name, try disabling all adapters other than the one being used to program the radio. If only one adapter is found, the tool should attempt to use that one. See the steps at the bottom of this article for more info.
http://wpilib.screenstepslive.com/s/...ing-your-radio
Also, are you plugging in the power to the radio after you click the load firmware button and are prompted?
Unread 02-13-2018, 06:11 PM
Mood's Avatar
Rookie Year: 2016
Originally Posted by forbes View Post
Did you try this?
Yes, and we aren't given a prompt it just straight throws an error before we even power it.
Unread 02-13-2018, 06:35 PM
forbes's Avatar
NYC Googler
AKA: Evan Forbes
Rookie Year: 2012
I would just try using a different computer.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
