OCCRA
Go to Post A sign of character is the ability to move on and make the best of what you have, even if you feel you were completely wronged. - Cory [more]
Unread 03-28-2018, 07:35 AM
restouffer's Avatar
restouffer restouffer is offline
AKA: Bob Stouffer
FRC #2539 (Krypton Cougars)
Rookie Year: 2010
restouffer is an unknown quantity at this point
POE Injector Only Carries Data If Barrel Connector Plugged In
We have run into an issue that has stumped our programming and electrical teams:
When we power our radio with the REV POE Injector plugged into the 18-24v POE port, the radio powers on and we can connect to its wireless network and our Tegra TX1 coprocessor on the attached network switch. However, we have no connection to the roboRIO and the light for that port remains off.
If we plug the barrel connector from the other 12V/2A output of the VRM into the radio, the port's light comes on and we have communication with the roboRIO. Any ideas?
Unread 03-28-2018, 08:02 AM
marshall's Avatar
marshall marshall is offline
Online Stripe & Drape Sales
FRC #0900 (The Zebracorns)
marshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond repute
Re: POE Injector Only Carries Data If Barrel Connector Plugged In
Interesting...
Have any video of it?
First I've heard of this issue.
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Clarke's Laws
Unread 03-28-2018, 08:05 AM
restouffer's Avatar
AKA: Bob Stouffer
Rookie Year: 2010
I don't have a video of it. We can probably take one tonight, but it's really not that exciting to watch.
Unread 03-28-2018, 08:12 AM
marshall's Avatar
No but it might provide some additional clues to help diagnose the issue.
Clarke's Laws
Unread 03-28-2018, 08:23 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Mentor
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
I would check the connectivity, cross-connectivity, and resistance of each conductor of your injector, beginning with the POE lines. Each line should have only a few milliohms of resistance, and there should be no cross connectivity.
Also check the output of the VRM from the port you're using.
I wonder if the RIO's providing voltage at too low a level to complete the connection? I don't have any way to check right now.
[Quoting brennonbrimhall]: We design a new robot every year, but we can't forget that we also design a new team every year as folks come and go.
Unread 03-28-2018, 08:32 AM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
The crimp connections on the orange POE cables are a little marginal. (We recrimped our's and had not had a problem.) Maybe too much voltage drop in the cable. Enough to power up the radio, but not enough to power the wired Ethernet? Just a WAG on my part.
If you don't know what you should hook up then you should read a data sheet
Unread 03-28-2018, 09:20 AM
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
I have heard of some issues with the orange POE cables. Not enough to cause a riot, but if it's causing you problems, it's better to swap it out than keep struggling with it. Amazon has some for fairly cheap - I know both of these have been used on robots without issue:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
A POE splitter is identical to a POE injector, except for the barrel jack, which you'll cut off anyways. So each of these gives you 4 that you can use for only $8, 2 day shipping free with Amazon Prime. Plus, they wire up opposite the orange one - they plug directly into the RoboRio, and let you put the long ethernet between them and the radio. Really handy, since the power is usually near the RoboRio anyways - this way you don't have to run a long power cord as well.
I find it to be all around better than REV's - easier wiring, vastly cheaper, and faster shipping. For the $10 Rev wants, along with another $6 for shipping to get it by the end of next week, I can get 8 of these.
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016-2018; Iowa 2017; Northern Lights 2018; Great Northern 2018
Division LRI: Galileo 2016; Tesla 2017; Archimedes 2018
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 03-28-2018, 09:44 AM
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
The POE splitter from Amazon (at least the ones I have) are backwards from the REV ones. Power is injected into the female plug, not the male plug. So you have to power the injector plugged into the RIO.
Unread 03-28-2018, 09:56 AM
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (ALLSPARKS)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
If you are having issues with our POE cable please send us an email to support@revrobotics.com and we will get it sorted out.
The ones you linked to will work if you know what you are doing. The reason that ours is a bit more expensive is due to the way it is made and the relatively small qty produced. Making the power connections in the female side of the cable is much easier since there is a PCB inside there (thats how our first samples we gave to FIRST were). After discussions it was decided that it is much safer for teams to put the power in the male connector. If you connect the POE cable incorrectly and send 12v into the roborio you can and will likely kill it. The other issue with the off the shelf ones is that some of them that we found had power connected through both ends, so the roboRIO would be getting part of that 12v power regardless.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 03-28-2018, 10:27 AM
ATannahill ATannahill is offline
Developing tomorrow's best people
AKA: Alex Tannahill
ATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond repute
I have seen the REV cable installed backwards (male end into the roboRio) and the roboRio was not killed. I also remember hearing from NI (I think through some data sheet, but I cannot find it now) that the Rio can survive pretty much any miss-wiring if it does not exceed 12 volts.
I am a volunteer that reads the manual during kickoff day (and updates and Q&A when available) and I try my best to help people with questions that are posted.
I base my answers off of the game manual, Q&A responses and field tour videos at the time of my post. Rules will probably be modified or clarified between this post and your competition. My post means nothing to event officials. Please keep up with team manual updates and the FRC Q&A.
Unread 03-28-2018, 10:31 AM
From our knowledge the RoboRIO is not explicitly protected from this, but there are alot of protection inside the RIO, so it is possible it survives. All we can say is that we recommend that teams use caution.
Unread 03-28-2018, 11:01 AM
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
The power is on the "spare" pairs of the Ethernet cable. I would be a little surprised if they are actually connected to anything in the RIO.
I have seen POE equipment damaged from 48 V POE being plugged into a device expected 24V POE
Unread 03-28-2018, 11:49 AM
dawonn's Avatar
dawonn dawonn is offline
Mentor
AKA: Dereck
FRC #3538 (RoboJackets)
dawonn is an unknown quantity at this point
Exclamation Re: POE Injector Only Carries Data If Barrel Connector Plugged In
As an FiM Southfield CSA, a rookie team showed up with their POE cable installed backwards at their first event, and unfortunately it did take out their RoboRio Ethernet port.
Both LED's on the RoboRio ethernet port were solid on, even without any cable connected. The RoboRio would tether and function fine over USB in this condition, but would not communicate over Ethernet.
Tried obvious things like reloading firmware and swapping radios, but eventually swapped out the RoboRio advised that they contact NI for a replacement / repair.
Unread 03-28-2018, 12:02 PM
restouffer's Avatar
AKA: Bob Stouffer
Rookie Year: 2010
We have spare POE Injectors, and will swap it out, but we were interested in understanding how it was even possible for the ethernet cable to only carry data when the barrel connector was used. Everything else appears to function normally, but there might as well not even be an ethernet cable between the radio and roboRIO unless the barrel connector is plugged in.
  #15   Spotlight this post!
Unread 03-28-2018, 12:22 PM
The issue you are reporting is a really strange one. My guess is that if your POE cable is bad and you are not getting enough power to the radio that it isn't actually on and looking at packets. If the Barrel jack is providing the right amount of power to power the radio than things would work as expected. I would try swapping your POE and see if the same situation exists. If so send us an email and we will replace the defective cable.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
