Go to Post Reputation is a good thing to have. - adammiller3122 [more]
  #181   Spotlight this post!
Unread 11-13-2017, 07:26 AM
Chris is me's Avatar
three on the scale
AKA: Pinecone
no team (formerly FRC 3929, 228, 2791)
Re: How the rules can discourage dangerous behavior
Originally Posted by JesseK View Post
Agree 100%. Once the rules are set, they should be enforced as-is. With that said, the head ref still needs to be given leeway for a good judgement call. This thread has said enough about that though.
Regardless, allowing opponents to do anything to try to sway the head ref's decision is probably a bad idea.
I think this is 100% okay if the opponents are attempting to say "no, don't give them that penalty, they didn't actually do what you said they did". The classic example is the 2013 Curie finals, when the opponents were arguing that the red card for the other alliance contacting them while climbing was incorrect as the contact did not occur. This kind of advocacy should be commended.
I think having opponents go "no, that's a silly rule, don't enforce that please" could be the slippery slope you're warning about, though.
Looking for a new team in north Chicago / northwest suburbs
Mentor: 3929 (2018)
Mentor / Drive Coach: 228 (2016-17) - 2016 RIDE Winner &
Consultant: 2170 (2017)
College Mentor: 2791 (2010-15) Build Photos - 2013 WPI Finalists, 2012 BAE Finalists
Student: 1714 (2009) - 2009 MN 10K Lakes Winners
  #182   Spotlight this post!
Unread 11-13-2017, 11:30 AM
pfreivald's Avatar
AKA: Patrick Freivald
Agreed on both counts.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
The Bausch Foundation and Naples High School
I write books, too!
  #183   Spotlight this post!
Unread 11-13-2017, 11:44 AM
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Either case is a slippery slope. This effectively allows head refs to second-guess the information the 4 other refs have asserted is true. Sure, the information is sometimes imperfect*. Yet the only sources of information for an individual call should be the other event officials (referees primarily, but FTA/volunteers via solicited information as well). Video replays/etc are a totally different topic from rules about safety though.
*Initially, a red card was given to 1885. It was overturned since the ref who called the foul didn't know for sure who actually caused the gear to fall. The question we asked the head ref was "Because this will impact alliance captains, please verify which human player actually caused the gear to fall". We would have lived with the result regardless of video replay results because I understood that the source of information had to be the ref who called the foul. The video replay confirms what I had hoped was true given what both pilots told me, but video isn't something that's available to a head ref.
Regardless of which way the call went, this is a great example of a referee using judgement to confirm info with proper sources and then determining the best outcome based upon the evidence she had. Within the technicalities of the rules, she very well could have let the card stand, given it to the other pilot, or given it to both teams who had pilots.
1885: YouTube | CAD Library
  #184   Spotlight this post!
Unread 11-13-2017, 08:40 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by Jon Stratis View Post
Send the production fields to locations nominated by the Planning Committees that will be the first ones to set up the field. Give the first people to set up the fields a chance to do it early for a week-0 event so we can figure out everything that's missing and problematic, and have replacement parts and solutions figured out before we have to do it for week 1. I couldn't even begin to estimate how much money is spent at Home Depot week 1 just to get the fields up and running. It's a problem that's been solved by the time the fields get to their second event.
If I understand you correctly, I'd consider that a "friendly amendment", unless/until practice indicated that the planning committees avoided rather than sought "high stress" locations.
Also, definitely in favor of two yellow cards in a match (especially if for two occurrences of the same offense) becoming a one-RP-ding rather than a disqualification.
  #185   Spotlight this post!
Unread 01-18-2018, 11:30 AM
#JusticeforPinecone
A bit of a thread revival here, I just wanted to touch base on how it seems like this was taken into account in the 2018 game.
I can't currently find a place in the game where a safety rule would hurt teams, other than the "walking on the field while the lights are still purple" scenario, and students in early weeks likely not using the rollers to get cubes from the exchange.
Kudos to the GDC avoiding the dangerous behavior penalties of years past (as far as I can tell at this point).
College Mentor of Team 5254, HYPE - Helping Youth Pursue Excellence (2015-Present)
frc5254.win
  #186   Spotlight this post!
Unread 01-18-2018, 12:11 PM
Brian Maher Fan Club's Avatar
Brian Maher Fan Club Brian Maher Fan Club is offline
School is a pre-robotics activity
AKA: Karan Yadav
FRC #2791 (Shaker Robotics)
Team Role: Driver
Rookie Year: 2016
Brian Maher Fan Club has much to be proud ofBrian Maher Fan Club has much to be proud ofBrian Maher Fan Club has much to be proud ofBrian Maher Fan Club has much to be proud ofBrian Maher Fan Club has much to be proud ofBrian Maher Fan Club has much to be proud ofBrian Maher Fan Club has much to be proud ofBrian Maher Fan Club has much to be proud ofBrian Maher Fan Club has much to be proud ofBrian Maher Fan Club has much to be proud of
The only thing I can think of is human players reaching with their hands to get cubes from the hole in the exchange (sticking their hands out of it, instead of using the rollers with their feet).
Team 2791:
2018: Central New York Winners, TVR Finalists, Detroit World Championship Darwin Quarterfinalists, IRI Invite
2017: TVR Winners, NYC Semifinalists, St. Louis World Championship Curie Quarterfinalists, IRI Invite, Ra Cha Cha Ruckus Quarterfinalists, Robot Rumble Winners
2016: TVR Semifinalists, FLR Semifinalists, Robot Rumble Winners, BattleCry Winners
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
