OCCRA
Go to Post With computers, every once in a while you see something that makes you think "I could have done this, why didn't I think of it? It would have made my life so much easier." Now is one of those times. - Nadav Zingerman [more]
  #31   Spotlight this post!
Unread 11-14-2017, 11:12 AM
Deke Deke is offline
FRC #0085
Deke is a glorious beacon of lightDeke is a glorious beacon of lightDeke is a glorious beacon of lightDeke is a glorious beacon of lightDeke is a glorious beacon of lightDeke is a glorious beacon of light
Re: Find the Speed Limit of a Piston?
Originally Posted by Oblarg View Post
Please do!
I added solenoid Cv values to it to remove the ACd calculation for the solenoids.
https://www.chiefdelphi.com/media/papers/3401?
  #32   Spotlight this post!
Unread 11-14-2017, 12:24 PM
Chief Robot Inspector
Originally Posted by rafi View Post
Quick question about this: You said that the tubing only allows 1 cfm, but the solenoids we consider as "low flow" are listed as 0.22 Cv and 220 L/min, which convert to ~8.1 CFM and ~7.8 CFM, respectively. Why would the valves be designed to allow such high flow rates through if the tubing they connect to does not allow a flow nearly that high?
Sorry,
I think I was using 10CFM and left off the last digit.
Knowledge is power. Power UP!
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
