OCCRA
Go to Post Admitted to MIT '14. FIRST is good stuff. - sparrowkc [more]
Unread 10-11-2018, 11:33 AM
BenjaminRowe's Avatar
BenjaminRowe BenjaminRowe is offline
FRC #5147 (Hornets)
Rookie Year: 2016
BenjaminRowe is a splendid one to beholdBenjaminRowe is a splendid one to beholdBenjaminRowe is a splendid one to beholdBenjaminRowe is a splendid one to beholdBenjaminRowe is a splendid one to beholdBenjaminRowe is a splendid one to beholdBenjaminRowe is a splendid one to beholdBenjaminRowe is a splendid one to behold
Command Based
Does anybody have any examples of java command based for robots a bit on he simpler side? I'm trying to transition our team but all of the releases I can easily find are more advanced and hard to follow, thanks in advance!
Unread 10-11-2018, 11:51 AM
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Software/Mechanical Mentor
Brian Selle has a reputation beyond reputeBrian Selle has a reputation beyond reputeBrian Selle has a reputation beyond reputeBrian Selle has a reputation beyond reputeBrian Selle has a reputation beyond reputeBrian Selle has a reputation beyond reputeBrian Selle has a reputation beyond reputeBrian Selle has a reputation beyond reputeBrian Selle has a reputation beyond reputeBrian Selle has a reputation beyond reputeBrian Selle has a reputation beyond repute
Re: Command Based
The WPI IDE plug-in includes a simple project that includes one subsystem and one command. I typically start teaching with this project on a control system test board, takes 3 steps:
1) add a motor controller and a setSpeed() method to ExampleSubsystem
2) call the setSpeed() method from the ExampleCommand initialize() method
3) add a button on the SmartDashboard to trigger the command in OI.java.
If you are using the 2018 libraries in Eclipse, go to File->New->Other->WPILib Robot Java Development->Robot Java Project then select Command-Based Robot. You can also create it using the new Alpha libraries in VS code (can't remember the exact path... start with button in the upper right corner).
http://www.team3310.com/
Unread 10-11-2018, 11:53 AM
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Command Based
Try this presentation:
http://team2363.org/2016/11/command-based-java-for-frc/
Unread 10-11-2018, 02:08 PM
gixxy's Avatar
gixxy gixxy is offline
Programming Mentor
AKA: Gustave Michel III
FRC #3468 (MAGNATech)
gixxy is on a distinguished road
Re: Command Based
Brad Miller's Tutorial from 2013 is still a very good walkthrough of the Command-Based Structure, even if a few things have changed since then (most namely, the removal of the CommandBase, in favor of initializing subsystems in the main Robot class.
https://www.youtube.com/watch?v=k7Pa...lgn vhGObeKzp
Here is my "data-flow" diagram I use when trying to explain the Command-Based Structure:
https://drive.google.com/open?id=1wH...wEHbQEw92H No
and here is the code repository for 3468's T-Shirt Cannon. It should be more than simple enough to get the idea across (perhaps too simple?):
https://github.com/frc3468/CharlotteAirCannonJava
Best of Luck! I welcome any comments, suggestions, or questions.
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 2018 - 3946 - Programming Mentor
2014, 2018 - Present - 3468 - Programming Mentor
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
