OCCRA
Go to Post They had a well made scouting form on the bottom was a check box with nothing next to it, when asked what the box was for they said. "Oh thats the jerk box" Since then one of our team goals is "Stay out of the jerk box" - Gary Stearns [more]
Unread 09-20-2018, 04:06 PM
3674 3674 is offline
FRC #3674
3674 is an unknown quantity at this point
bus error opencv on jetson tk1
I'm getting a bus error when cvtColor runs, it appears to be cv::Mat &out that is causing it
void VisionPipeline::hslThreshold(cv::Mat &input, double hue[], double sat[], double lum[], cv::Mat &out) {
	cv::cvtColor(input, out, cv::COLOR_BGR2HLS);
	cv::inRange(out, cv::Scalar(hue[0], lum[0], sat[0]), cv::Scalar(hue[1], lum[1], sat[1]), out);
it is being ran by:
	hslThreshold(hslThresholdInput, hslThresholdHue, hslThresholdSaturation, hslThresholdLuminance, this->hslThresholdOutput);
thanks for any help
Unread 09-20-2018, 10:05 PM
codedr codedr is offline
FRC #0537
codedr will become famous soon enoughcodedr will become famous soon enough
Re: bus error opencv on jetson tk1
A bus error would typically occur if the buffer being written to is not correctly byte aligned.
The arm processor like intel doesn't like it when a 2 or 4 byte entity is written to at an odd byte address.
If you are able to debug the issue with gdb, or the generated core file, you should be able to see the failing instruction. Dumping the target or source address from the register being used in the instruction will probably show an odd valued address.
If it's the out buffer, I would look at how the buffer is being allocated and make sure it is correctly aligned for the data type.
Unread 09-21-2018, 02:50 PM
FRC #3674
here is what i get from gdb:
Program received signal SIGBUS, Bus error.
0x0000b5d2 in __gnu_cxx::__exchanged_and_add (__mem=0x2, __val=-1)
at /usr/include/c++/4.8/ext/atomicity.h:49
49     { return __atomic_fetch_add(__mem, __val, __ATOMIC_ACQ_REL); }
Unread 09-21-2018, 03:04 PM
FRC #3674
0x0000b5d2 appears not to be byte aligned, how would i align it?
Unread 09-22-2018, 07:32 PM
FRC #3674
Ok we fixed it by eliminating some pointers
Unread 10-19-2018, 03:53 PM
FRC #0537
__mem does not look valid (2). It appears to be an invalid pointer.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
