OCCRA
Go to Post If this strategy backfires on any alliance that attempts it, they will have no one to blame but themselves. Be smart - know the risks before proceeding. - Travis Hoffman [more]
Unread 05-15-2018, 04:33 PM
risho900 risho900 is offline
FRC #6897 (Astraea Robotics)
Rookie Year: 2015
risho900 will become famous soon enough
Radio Help
So I've been trying to connect my laptop to the radio but I cannot seem to get coms. The wifi light on radio is orange but driver station shows no coms or robot code. Any help would be greatly appreciated.
Unread 05-15-2018, 04:35 PM
aryker's Avatar
aryker aryker is offline
FRC #0868 (TechHOUNDS)
aryker will become famous soon enougharyker will become famous soon enough
Re: Radio Help
Do you get an IP address when you connect to the radio? If so, can you ping the radio or the RoboRIO? They should have IP addresses 10.68.79.1 and 10.68.79.2 respectively.
Unread 05-15-2018, 04:37 PM
Re: Radio Help
Can you see the radio SSID in your list of wireless APs to connect to on your PC?
Have you connected to the radio SSID?
Have you reconfigured your radio, since your last competition?
If your PC has connected to the radio then:
- What does the Diagnostics tab on the PC's Driver Station app show?
- The Diagnostics tab will show your PC IP and the IP addresses it is attempting to use for the roboRIO.
- The Diagnostics tab will also show what it can successfully ping, e.g., radio, roboRIO.
We are what we repeatedly do. Excellence, then, is not an act, but a habit. -Aristotle
Smalls1625's Avatar
Smalls1625 Smalls1625 is offline
AKA: Zane
FRC #1625 (Winnovation)
Rookie Year: 2016
Smalls1625 is an unknown quantity at this point
Re: Radio Help
If you haven't tried this already, make sure that you have your radio configured correctly, and make sure that your team number is set correctly everywhere (i.e. driver station, code, radio config). Also make sure that your Ethernet run between your roboRio and your radio is solid.
Unread 05-15-2018, 04:40 PM
deslusionary's Avatar
deslusionary deslusionary is offline
easily impressed by fancy acronyms
AKA: Christopher Tinker
FRC #7093 (Veritas Valiants)
Rookie Year: 2018
deslusionary has a brilliant futuredeslusionary has a brilliant futuredeslusionary has a brilliant futuredeslusionary has a brilliant futuredeslusionary has a brilliant futuredeslusionary has a brilliant futuredeslusionary has a brilliant futuredeslusionary has a brilliant futuredeslusionary has a brilliant futuredeslusionary has a brilliant futuredeslusionary has a brilliant future
Re: Radio Help
Make sure you have reflashed your radio with the provided software after your last competition. The radio is set up differently for home and competition use.
Unread 05-15-2018, 05:40 PM
Rookie Year: 2015
Re: Radio Help
I used it on a different laptop just this past Saturday outside of competition and it worked fine. Also, I'm on mechanical so i don't know how to ping the radio. Could you explain it please?
Unread 05-15-2018, 06:01 PM
Re: Radio Help
If it worked with a different laptop last week, then it's probably just your new laptop setup.
Here are the standard things to try:
- Turn off the PC firewall.
Firewalls will work only if they are setup correctly, so it's generally just easier to turn it off if you have difficulties.
- Turn off any anti-virus programs that are running. They also specialize in blocking communications.
- Make sure the wireless connection is set to DHCP.
It will gain an IP address from the robot radio.
Finally, run the Driver Station app and switch to the Diagnostic tab on the left side of the DS screen.
The Diagnostic screen is constantly doing ping tests for you.
You just need to look at the lights (off or green) to see what's happening.
I've attached an example.
Look for green lights for radio and robot-next to the robot will be displayed the IP address being used or tried.
Unread 05-15-2018, 06:24 PM
Rookie Year: 2015
Re: Radio Help
I tried that but still no comms and diagnostics tab isn't showing anything
Unread 05-15-2018, 06:30 PM
Rookie Year: 2015
Re: Radio Help
I did connect it with ethernet and sent a ping and it did receive and reply with a ping but still comms
Unread 05-15-2018, 06:36 PM
Re: Radio Help
What shows on the Diagnostics tab for the Ethernet connection?
You will have an Ethernet IP address listed-what is it?
Unread 05-15-2018, 06:37 PM
Rookie Year: 2015
Re: Radio Help
169.254.37.98
Unread 05-15-2018, 06:39 PM
Re: Radio Help
That means your PC is not taking an IP address from the robot radio.
You won't get robot comms until your PC accepts a robot compatible IP address, like 10.TE.AM.xx
Sometimes that just takes a long while for some PCs.
You can prod the network adapter by Disabling/Enabling.
Control Panel (can be searched for) -> Network and Sharing Center (or "View network status and tasks" depending on how you view your Control Panel) -> Change Adapter Settings
Then right-click on the Ethernet adapter icon and select Disable, then right-click again and select Enable
Unread 05-15-2018, 06:40 PM
Rookie Year: 2015
Re: Radio Help
aw rip so I just gotta wait?
Unread 05-15-2018, 06:45 PM
FletcherS7's Avatar
FletcherS7 FletcherS7 is offline
FTAA, Webmaster, and such
AKA: Fletcher
FRC #0100 (WildHats)
FletcherS7 will become famous soon enough
Re: Radio Help
You cannot be connect to the internet when connect to the robot.
To get the IP from the Radio.
Open the Windows Command Prompt. (WIN+R, type CMD, press enter)
enter the commands:
ipconfig /release
ipconfig /renew
FTAA, Webmaster, IT, Media, and everything between.
Unread 05-15-2018, 06:54 PM
Rookie Year: 2015
Re: Radio Help
I did that. I connected over WiFi to robot. I couldn't get a reply when I ping when i used ping roboRIO-6897-FRC.local I did get a response when i individually pinged radicand it was good. When I tried roborio individually using 10.86.96.2, it got a reply but said destination host unreachable.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
