OCCRA
Go to Post I <3 statistics. - Barry Bonzack [more]
Unread 09-12-2017, 03:21 PM
ArtemusMaximus's Avatar
ArtemusMaximus ArtemusMaximus is offline
Enginerd
FTC #11722
ArtemusMaximus is a splendid one to beholdArtemusMaximus is a splendid one to beholdArtemusMaximus is a splendid one to beholdArtemusMaximus is a splendid one to beholdArtemusMaximus is a splendid one to beholdArtemusMaximus is a splendid one to beholdArtemusMaximus is a splendid one to beholdArtemusMaximus is a splendid one to behold
[FTC]: Cryptobox Detection
Any thoughts on how to detect Cryptobox for putting Glyph in correct column in Autonomous?
2017 FTC 11722 (Coach)
2016 FTC 10544 (Coach) Canadian Championship Finalist, Rockwell Collins Innovate Award.
2014 FRC 5064 (Mentor)
Unread 09-12-2017, 03:38 PM
marshall's Avatar
marshall marshall is offline
Discerning and exacting individual
FRC #0900 (The Zebracorns)
Re: [FTC]: Cryptobox Detection
I know very little about the FTC control system but if it were me, I'd probably recommend storing the patterns of all 3 pictographs and do a compare against the one on the field and then run my auto routine based on the pattern found. You can likely improve this by figuring out the differences between them and only concentrating on identifying those differences rather than the complete image.
Before I ever did that though, I'd examine all the possible points and scoring options and I'd figure out if scoring those pictograph based auto points is actual worth the time. It might make more mathematical sense to go after another challenge.
Clarke's Laws
Unread 09-12-2017, 03:56 PM
Enginerd
FTC #11722
Detecting Pictograph is not an issue. FTC SDK already pre-loaded with Pictographs for detection by PTC Vuforia. SDK also has the sample code for that.
My question was about detecting location of Cryptobox itself for placing the Glyph in correct place.
It doesn't appear like it too difficult, but I am not sure how to do it.
Unread 09-12-2017, 05:08 PM
Billfred's Avatar
Billfred Billfred is offline
I am 2000% spitballing here. Haven't tried it, probably won't work, but the advice was free and worth every penny.
Thought 1) A whisker kind of switch would let you bump into each extrusion as you drive or strafe past.
Thought 2) Design in some kind of alignment widget (maybe thick scrap lexan, maybe euroboard, maybe 3D printed, maybe on a servo to pivot away) that lets you nestle up against a known part of the Cryptobox. Get close from encoders, drive in slowly to locate yourself using the widget, then run your left/center/right routine off of that location.
2017-: FRC 5402 (Iron Kings) - Mentor, Coach
104 events (more than will fit in a ChiefDelphi signature), 14 seasons, over 69,000 miles, and still on a mission from Bob.
Unread 09-12-2017, 05:49 PM
Gdeaver Gdeaver is offline
FRC #1640
Teams will already be using Vuforia for pictograph reading. Seams it should be able to detect the glyph box with location info. Add in gyro and ranging off of side walls. Something for programmers to chew on.
Unread 09-12-2017, 06:43 PM
Enginerd
FTC #11722
Thank you for the ideas.
After typing last reply, I thought of same thing, using Vuforia to calculate robots location and go from there.
Last year distance from starting point to the picture was problematic for Vuforia. this year starting point is right in front of the picture
