OCCRA
Go to Post Robots that don't obey the laws of physics will be checked for alien technology and magic. - Greg McKaskle [more]
Unread 01-31-2018, 08:38 AM
cbale2000's Avatar
AKA: Chris Bale
FRC #5712 (Gray Matter)
Re: What is the best pocketing design for 2x1?
Originally Posted by Brian M View Post
I'll second this pattern (or similar), I've used it a lot throughout the years and it's worked pretty good.
That said, this year my team opted to build a sheet metal drivetrain, and so to cut down on mill work we used a circle pattern on a number of elements so that the holes could be punched out using the our sponsors CNC punching machine. We're pretty happy with it so far.
2005-2008: FRC 703 Phoenix - Robot Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 01-31-2018, 11:34 AM
RoboChair's Avatar
AKA: Devin Castellucci
Originally Posted by Andy A. View Post
Are you committed to that particular wall thickness?
2"x1"x.0625" aluminum tubing is available, and will probably beat the thicker material that's been trussed out in both weight and generalized strength, while also being cheaper and not requiring a whole lot of machining time.
Seconded
Originally Posted by Knufire View Post
Use 1/16" wall. Add plates wherever you need more wall thickness, such as supporting a bearing.
Seconded
Originally Posted by Basel A View Post
This is the right answer in most cases. Immediately cuts out half the weight, with similar strength to pocketing, much much less work, and if you really need the thickness you can throw in a bearing block as needed.
Seconded
One of the driving reasons teams go over weight is not using 1/16th everywhere possible, it's almost always the better option in non-drivetrain parts.
Originally Posted by Chris Hapstack View Post
We've had a heck of a hard time finding 2"x 1"x 1/16" in 6061-T6. Everywhere we've tried has been back-ordered for a couple weeks. Kind of unsurprising, given the elevator focus for many teams this year. Also to note, I called Vex and confirmed their 2" x 1" aluminum VersaFrame tube is out of stock until March.
We chose 1/8" wall 6061 instead of 1/16" wall 6063 as a second option. I haven't worked with 6063 before, but it's certainly softer. Does anyone have a source for 1/16" wall 6061? Or has had success with 1/16" wall 6063?
try contacting 973, they have worked to distribute the thin wall stuff fro Coast Aluminum here in California.
6063 is the devils aluminum. Sure it's more corrosion resistant, but that no help to us. Have fun deburring ALL your holes and cuts, frickin' cheese-grade I tell ya.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 01-31-2018, 08:19 PM
Chris Hapstack's Avatar
Chris Hapstack Chris Hapstack is offline
Design Mentor
FRC #0342 (Burning Magnetos)
Chris Hapstack has much to be proud ofChris Hapstack has much to be proud ofChris Hapstack has much to be proud ofChris Hapstack has much to be proud ofChris Hapstack has much to be proud ofChris Hapstack has much to be proud ofChris Hapstack has much to be proud ofChris Hapstack has much to be proud ofChris Hapstack has much to be proud ofChris Hapstack has much to be proud of
Thanks for the recommendations, everyone - 973 has some available.
2017-XXXX - Team 342 mentor (Charleston, SC)
2015-2016 - Team 85 mentor (Zeeland, MI)
2007-2010 - Team 281 student (Greenville, SC)
Unread 02-01-2018, 02:12 AM
frcguy's Avatar
frcguy frcguy is online now
Sitting behind a Toughbook
AKA: Nicholas Dal Porto
FRC #0190 (Gompei and the H.E.R.D.)
Coast was out of stock last I checked, so it's triangle season on 5940 .
Team 5940: 2015-2018 | Team 190: 2018-present
Volunteer: 2016-present
Event Travel Spreadsheet
Unread 02-01-2018, 02:13 AM
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
http://www.wcproducts.net/aluminum-tubing
Also have misc tubing including 2x1x.0625 available here.
R.C.
MadTown Robotics Team 1323
Unread 02-01-2018, 07:24 AM
philso philso is offline
... One of the driving reasons teams go over weight is not using 1/16th everywhere possible, it's almost always the better option in non-drivetrain parts...
+1
2587 built most of their 2015 robot out of 1/8" wall 2x1 and 1x1 by mistake. It was probably similar in size to what you are building. We spent most of a weekend with two hole saws and many deburring tools to "add lightness". At least we didn't have to put that on the BOM
Unread 02-01-2018, 09:54 AM
bcampbell's Avatar
bcampbell bcampbell is offline
bcampbell has a spectacular aura aboutbcampbell has a spectacular aura aboutbcampbell has a spectacular aura about
We just took a shipment on monday of 260 feet of .063 wall 2x1. I would call again and see. They were back ordered but we got our delivery this week. It only took them 1 week to fill the order.
Unread 02-01-2018, 12:36 PM
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond repute
I like to use 0.0625" wall material when possible. But when wall thickness and light weight are both design requirements, I like to pocket part way through the material, and use large triangles. It's fast to cam and cut, it retains a lot of strength, and it looks nice. Attached is a picture of an example.
FLL Team Future imagineers
2011-????:
FRC Team Mean Machine
Unread 02-01-2018, 12:43 PM
Nice. Very nice.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
