OCCRA
Go to Post Once we know how magic works it's no longer magic; it becomes science. - Karthik [more]
CD-Media
Unread 11-05-2018, 07:44 PM
David B David B is offline
FRC #0386
David B is an unknown quantity at this point
Using Talon SRX with PWM
One of our Talons is alternating orange and red, but it's not the damaged hardware blink. When we drive it forward, only one of the green lights turns on. Factory reset did not seem to do anything. Is there any way to resurrect it or is it bricked?
Unread 11-06-2018, 01:55 AM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Re: Using Talon SRX with PWM
From the SRX User Guide on page 39,
Indication: both LEDs alternate red & orange
Problem: Damaged Hardware - the device requires service
Solution:
Contact CTRE (crosstheroadelectronics.com). The Talon SRX is not warranted for use until the hardware is repaired. DO NOT attempt to use the Talon SRX.
Given this, I would stop using the SRX and contact CTRE customer support. They are generally very helpful and will want to fix the problem. You will likely need to send it to them, and they probably will fix it and send it back or send a replacement. You won’t find anyone on here who knows more about the SRX than the people who designed it.
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
Unread 11-06-2018, 09:50 AM
CooperWard4499 CooperWard4499 is offline
FRC #4499
CooperWard4499 is an unknown quantity at this point
If you are positive that it is not damaged, and the Talon works ok, then it could be a broken LED. Since the orange light is just a combination of Red and Green lights, it wouldn't surprise me if this were the case. This would also explain why only one green light is working. However, if you do have any actual issues with using the motor controller, I do recommend sending it to CTR for repairs. Hopefully this helps!
Unread 11-06-2018, 10:38 AM
frank-g-e frank-g-e is offline
FRC #0341
frank-g-e is on a distinguished road
You say you 'factory reset' it. Did you calibrate it to its input signal?
Section 6 of:
http://files.andymark.com/Talon_User_Manual_1_3.pdf
Team 341 Mentor, Electrical, Retired Engineer
The longer a signature is the less I am interested in reading the post.
Unread 11-06-2018, 10:41 AM
FRC #0341
Whoops, I see it is an SRX, so, section 2.2 in this manual:
https://www.ctr-electronics.com/Talon%20SRX%20User's%20Guide.pdf
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
