Go to Post Play FRC like Bruce Lee, not an MMA fighter. - Jessica Boucher [more]
Unread 04-24-2018, 10:38 PM
s3529's Avatar
s3529 s3529 is offline
AKA: Stephen
FRC #6352 (LAUNCH TEAM 6352)
s3529 is an unknown quantity at this point
New to Pneumatics - What to get?
Hello,
This was our team's second season and, so far, we've gotten by with just mechanical systems. This summer, we want to expand and learn how to use pneumatics. Before our vouchers expire next week, we want to use our Clippard PDV. What would be some useful equipment to purchase with it?
Thanks in advance!
LAUNCH TEAM 6352 (Founded in 2016)
2016 Dean's List Finalist - AZ West Regional
Team Paradise 1165 (2014-2017)
Unread 04-24-2018, 10:48 PM
Bluman56's Avatar
Bluman56 Bluman56 is offline
No more carpet ripping Robots
AKA: Nikita
FRC #2579 (LIC Robodogs)
Bluman56 has a brilliant futureBluman56 has a brilliant futureBluman56 has a brilliant futureBluman56 has a brilliant futureBluman56 has a brilliant futureBluman56 has a brilliant futureBluman56 has a brilliant futureBluman56 has a brilliant futureBluman56 has a brilliant futureBluman56 has a brilliant futureBluman56 has a brilliant future
Re: New to Pneumatics - What to get?
Tubing is available on Clippard and is always useful to have (annoying to run out of!)
Typically we buy air tank mounting brackets with our credit but if you don't have any air tanks, here are the ones we buy (also available on AndyMark).
Apart from Clippard, we are going to be using these tiny and super cute pressure gauges and pressure regulators from AutomationDirect. Use their credit as well if you haven't yet (assuming it hasn't expired). While they are awesome and usually ship a tubing cutter with orders, get one of these because you never wanna cut tubing without one (no one I know likes having slow leaks).
Hope that helps!
Unread 04-24-2018, 10:50 PM
darajaco's Avatar
darajaco darajaco is offline
Just a College Kid
AKA: Jacob Dara
FRC #7226 (Error 404)
darajaco is a jewel in the roughdarajaco is a jewel in the roughdarajaco is a jewel in the roughdarajaco is a jewel in the rough
http://www.clippard.com/part/AVT-PP-35
You need something to hold the air you're going to use. If i remember the voucher is for 25, i think its worth the 5 extr abucks for a second tank (either for on board the primary robot or for practice bot).
2013-2017 2960 Automation Nation (Student)
2018-???? 7226 Error 404 (Mentor)
2015 Champs Tesla Division Semi-Finalist...2017 MSC Dow Division Finalist
2017 Southfield Event Winner......................2017 North Champs Daly Division Semi-Finalist
2017 St. Joseph Indiana Event Winner........2018 Shepherd Event Winner
Unread 04-24-2018, 10:51 PM
darajaco's Avatar
Just a College Kid
AKA: Jacob Dara
Originally Posted by Bluman56 View Post
This a luxury! Zip ties will always do, just remember no tapes, adhesives, or paints since its technically modifying a pneumatic component.
Unread 04-25-2018, 04:20 AM
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond repute
The AutomationDirect $35 Voucher is good until the end of the month (aka 5 days)
Use it to get:
Mini Pnuematics
Tubing
Cylinders
Push To Connect Fittings
All things pnuematics
Unread 04-25-2018, 06:02 AM
GBK GBK is offline
FRC #1918 (NC GEARS)
GBK is a name known to allGBK is a name known to allGBK is a name known to allGBK is a name known to allGBK is a name known to allGBK is a name known to all
A couple things that helped a lot. The biggest was going to solenoids that are not piloted. Many of the solenoids will not work below 45 psi. Our next big improvement was going to 5/32 tubing. We used 1/4 to feed our manifold and went to 5/32 from there out. The manifold we used is a 7 port that is about 2 inches long and weighs only a couple of ounces.
At state this year we went to a practice match first thing in the day and realized that we had not charged our air. We still had 50 psi on our working side from the night before. and 70 in on the main tank
The smaller line may not work well for large cylinders, but the 1" dia and smaller with 7 inch or less stroke that we use, is no problem
Unread 04-25-2018, 06:09 AM
messer5740's Avatar
messer5740 messer5740 is offline
AKA: Matt
FRC #5740 (Trojanators)
Rookie Year: 2015
messer5740 is a splendid one to beholdmesser5740 is a splendid one to beholdmesser5740 is a splendid one to beholdmesser5740 is a splendid one to beholdmesser5740 is a splendid one to beholdmesser5740 is a splendid one to beholdmesser5740 is a splendid one to beholdmesser5740 is a splendid one to behold
Manifolds are also a great thing to get. Remember to stock up on the standard pneumatic parts like flow valves, pressure gauges, and fittings.
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: Quarterfinalists at Greater Pittsburgh Regional and Buckeye Regional
2017: Dean's List Finalist
2018: Engineering Inspiration Award; Quarterfinalists at the Miami Valley and Greater Pittsburgh Regional
Unread 04-25-2018, 07:00 AM
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond repute
Originally Posted by rfolea View Post
Though expensive, I've always thought these are really slick.
Also if anyone tells you that you need penumatic fluid, well.... I mean yes you do, but don't go spending any money on it.
Unread 04-25-2018, 07:05 AM
hrench's Avatar
hrench hrench is offline
mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench has a brilliant futurehrench has a brilliant futurehrench has a brilliant futurehrench has a brilliant futurehrench has a brilliant futurehrench has a brilliant futurehrench has a brilliant futurehrench has a brilliant futurehrench has a brilliant futurehrench has a brilliant futurehrench has a brilliant future
If I were 'stocking up', I'd get solenoid valves.
The best value is Automation Direct single solenoid, 5-way. They're much larger and flow more then the Festo that AM sells, but sometimes larger is difficult. Also at $22, easier to 'stock' than the $89 Festo.
Here's the one I buy.
https://www.automationdirect.com/adc/Shopping/Catalog/Pneumatic_Components/Pneumatic_Valves_-a-_Accessories/General_Purpose_Solenoid_Directional_Control_Air_V alves/5-port_(4-way),_2-pos.,_Body_Ported_-z-_Manifold_(AVS-5,AM_Series)/AVS-5211-24D
Getting air cylinders with coupons is fine, but you nearly always end up needing to get a special length, bore, magnet or cushion that makes them more specific for a design. Better to not have the 'wrong' ones hanging around, just buy them specific for your needs. Cylinders are very expensive too.
Tanks and regulators and fittings, gauges are great, but they're nearly always available free from FirstChoice before the season. You can look at last year's FirstChoice here:
https://firstchoicebyandymark.com/everything
Unread 04-25-2018, 07:18 AM
Tomithy's Avatar
Tomithy Tomithy is offline
Facing build season withdrawal
FRC #5727 (REaCH Omegabytes)
Rookie Year: 2016
Tomithy has a spectacular aura aboutTomithy has a spectacular aura aboutTomithy has a spectacular aura about
+1 on those Automation Direct solenoids, they work great. I would recommend the double solenoids instead of the single because from my team's experience they are easier to program, but both are a good value.
Unread 04-25-2018, 07:36 AM
danielbatmanj's Avatar
danielbatmanj danielbatmanj is offline
AKA: Daniel Johnson
FRC #5115 (Knight Riders)
Rookie Year: 2018
danielbatmanj is an unknown quantity at this point
Unfortunately, some LRI's don't allow zipties. Our LRI in CHS doesn't, so just be aware
Unread 04-25-2018, 07:44 AM
brennan-macaig's Avatar
brennan-macaig brennan-macaig is offline
FRC #5962 (perSEVERE)
Rookie Year: 2015
brennan-macaig will become famous soon enough
Zipties are presumably not going to be allowed much longer to hold tanks down as it's not considered a permenant mounting solution.
FRC 1721 Tidal Force - 2015-17 (Team Captain 2017)
FRC 5962 perSEVERE - 2017-Present (Mentor)
Unread 04-25-2018, 07:50 AM
marshall's Avatar
marshall marshall is offline
Discerning and exacting individual
FRC #0900 (The Zebracorns)
Ohh, the old LRI-a-roo.
Clarke's Laws
Unread 04-25-2018, 09:22 AM
Billfred's Avatar
Billfred Billfred is offline
Never look back, no, never say die
AKA: Always attack with the warrior's cry...
FRC #1293 (Pandamaniacs); FTC #11444 (Garnet Squadron)
Why not REV's for half the price? http://www.revrobotics.com/rev-11-1107/
(I'm legitimately asking on the "why", maybe there's something I don't know.)
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Owner/Director of Bricks 4 Kidz in Columbia, SC.
2017: FRC 5402 (Iron Kings) - Mentor, Coach
2018-: FRC 1293 (Pandamaniacs) - Mentor
112 events (more than will fit in a ChiefDelphi signature), 15 seasons, over 72,000 miles, and still on a mission from Bob.
Unread 04-25-2018, 09:37 AM
ARaulinaitis ARaulinaitis is offline
FRC #4999 (Momentum Robotics)
Rookie Year: 2015
ARaulinaitis is just really niceARaulinaitis is just really niceARaulinaitis is just really niceARaulinaitis is just really nice
Something that hasn't been brought up in this thread is the design ideas that you need to have when using pneumatics.
Obviously you'll need to know how to calculate the force that pistons can exert at a given pressure.
The important thing that is easy to mess up, is you need to be sure to design your mechanical/pneumatic system to not put any side-loading on the piston rod, or you can risk destroying the piston.
Essentially design your system so it is fully constrained except for one axis of motion, and then add your piston there. If your system has more than one degree of freedom, you risk bending your piston.
Don't limit others to the level of your own creativity.
Spec sheets are your friend.
A problem that you don't want to solve is an opportunity to better yourself.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
