Go to Post FRC is about giving students the best experience possible. - MikeE [more]
Unread 02-12-2018, 04:11 PM
tzaiger2018's Avatar
tzaiger2018 tzaiger2018 is offline
AKA: Tyler Zaiger - Lead Programmer/Driver
FRC #6121 (RoboVikes)
Rookie Year: 2016
tzaiger2018 is an unknown quantity at this point
How to wire HERLV_MaxSonar Sensor
My team wants to use the HERLV_MaxSonar. We want to Wire it though a PWM wire. If annyone knows how to wire one of these though PMW, it would be greatly appreciated. Thank you.
Unread 02-12-2018, 04:36 PM
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #2468 (Team Appreciate)
Re: How to wire HERLV_MaxSonar Sensor
Here's a link to the datasheet for the MaxBotix HRLV Series: https://www.maxbotix.com/documents/H..._Datasheet.pdf
The pinout is in there. Typically, you'd use what most teams call a PWM cable (three pin with black, red, and white wires). I'm guessing that's what you're asking about?
Black is ground, red is +5V, and white is the signal.
There are several ways to read the distance, but I'd recommend using Pulse-Out to a DIO pin. You'd measure the pulse-width and convert the PW to distance using the conversion detailed in the datasheet. The other easy way would be to use an analog input, either ways works pretty well.
Controls Mentor
@rnazaretian
Current team:
Team Appreciate, FRC 2468
Previous teams:
Team Fusion, FRC 364 (2003 - 2015)
Garnet Squadron, FRC 4901 (2015-2016)
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
