Go to Post I think the GDC should force us to use steam engines, but the electrically-inclined folks on my team might stop whining if they're given more to work with. - Madison [more]
Unread 02-12-2018, 02:00 PM
AnAccountForRob AnAccountForRob is offline
FRC #1474
AnAccountForRob is an unknown quantity at this point
Could not instantiate robot
I have a question about compiling. Whenever I compile, I always get this error.
ERROR 1 Could not instantiate robot org.usfirst.frc1474.2018RobotBuild2.Robot! edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:225)
I'm guessing it has to do with the Robot.java, so here is its code.
package org.usfirst.frc1474.robot;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.command.Command;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
import edu.wpi.first.wpilibj.smartdashboard.SendableChoos er;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboar d;
import org.usfirst.frc1474.robot.commands.*;
import org.usfirst.frc1474.robot.subsystems.*;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the TimedRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the build.properties file in
* the project.
public class Robot extends IterativeRobot{
Command autonomousCommand;
SendableChooser<Command> chooser = new SendableChooser<>();
public static OI oi;
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DECLARATIONS
public static Drive1 drive1;
//public static Grabber grabber;
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DECLARATIONS
* This function is run when the robot is first started up and should be
* used for any initialization code.
@Override
public void robotInit() {
RobotMap.init();
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTRUCTORS
drive1 = new Drive1();
//grabber = new Grabber();
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTRUCTORS
// OI must be constructed after subsystems. If the OI creates Commands
//(which it very likely will), subsystems are not guaranteed to be
// constructed yet. Thus, their requires() statements may grab null
// pointers. Bad news. Don't move it.
oi = new OI();
// Add commands to Autonomous Sendable Chooser
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=AUTONOMOUS
chooser.addObject("IntakeCube", new IntakeCube());
chooser.addDefault("Autonomous Command", new AutonomousCommand());
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=AUTONOMOUS
SmartDashboard.putData("Auto mode", chooser);
* This function is called when the disabled button is hit.
* You can use it to reset subsystems before shutting down.
@Override
public void disabledInit(){
@Override
public void disabledPeriodic() {
Scheduler.getInstance().run();
@Override
public void autonomousInit() {
autonomousCommand = chooser.getSelected();
// schedule the autonomous command (example)
if (autonomousCommand != null) autonomousCommand.start();
* This function is called periodically during autonomous
@Override
public void autonomousPeriodic() {
@Override
public void teleopInit() {
// This makes sure that the autonomous stops running when
// teleop starts running. If you want the autonomous to
// continue until interrupted by another command, remove
// this line or comment it out.
if (autonomousCommand != null) autonomousCommand.cancel();
* This function is called periodically during operator control
@Override
public void teleopPeriodic() {
Unread 02-12-2018, 02:15 PM
forbes's Avatar
forbes forbes is offline
NYC Googler
AKA: Evan Forbes
FRC #0694 (StuyPulse)
forbes has a brilliant futureforbes has a brilliant futureforbes has a brilliant futureforbes has a brilliant futureforbes has a brilliant futureforbes has a brilliant futureforbes has a brilliant futureforbes has a brilliant futureforbes has a brilliant futureforbes has a brilliant futureforbes has a brilliant future
Re: Could not instantiate robot
Can you post the entire output you get when compiling?
Unread 02-12-2018, 03:19 PM
FRC #1474
This is the robot console. Print statements and error messages will appear here.
Console output requires a Driver Station to be connected to the robot.
********** Robot program starting **********
ERROR 1 Unhandled exception instantiating robot org.usfirst.frc1474.2018RobotBuild2.Robot java.lang.ClassNotFoundException: org.usfirst.frc1474.2018RobotBuild2.Robot java.net.URLClassLoader.findClass(URLClassLoader.j ava:381)
at java.net.URLClassLoader.findClass(URLClassLoader.j ava:381)
at java.lang.ClassLoader.loadClass(ClassLoader.java:4 24)
at sun.misc.Launcher$AppClassLoader.loadClass(Launche r.java:335)
at java.lang.ClassLoader.loadClass(ClassLoader.java:3 57)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:216)
Error at java.net.URLClassLoader.findClass(URLClassLoader.j ava:381): Unhandled exception instantiating robot org.usfirst.frc1474.2018RobotBuild2.Robot java.lang.ClassNotFoundException: org.usfirst.frc1474.2018RobotBuild2.Robot
WARNING 1 Robots should not quit, but yours did! edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:224)
Warning at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:224): Robots should not quit, but yours did!
Error at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:225): Could not instantiate robot org.usfirst.frc1474.2018RobotBuild2.Robot!
Unread 02-12-2018, 08:20 PM
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant future
What are the contents of your build.properties file? Based on your code, it should be:
package=org.usfirst.frc1474.robot
robot.class=${package}.Robot
but based on the error message is likely:
package=org.usfirst.frc1474.2018RobotBuild2
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
