Go to Post If we supply the part that adds the awesome to their robot, that makes us look good too. - DonRotolo [more]
Unread 02-12-2018, 04:57 PM
kingc95 kingc95 is offline
FRC #0453
kingc95 is an unknown quantity at this point
Record Encoder Data to a different file
This isn't super urgent but I wanted to put the question out there.
If there a way to record your encoder data during matches? Like with readings over time that can be exported. Our robot is coded in Java. We'd like to take those encoder readings and mesh them with a simulated version of our robot in Rviz on the Nvidia Jetson tx2. Its more of a is there a waytype of question. We're trying to find a good use for the Jetson this year since theres no point with Vision processing this year. Any ideas?
Unread 02-12-2018, 08:23 PM
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant future
Re: Record Encoder Data to a different file
If you use the Shuffleboard dashboard application, it provides the ability to do data logging of all NetworkTables values. Java and C++ automatically publish sensor data (such as encoders) to NetworkTables.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
