Go to Post 321 didn't get picked up today because the front desk of the high school wouldn't let him in! Thank goodness the FedEx driver was nice enough to come back and get it for us! - Chuck Glick [more]
Unread 02-12-2018, 06:00 PM
SMC SMC is offline
FRC #2805
SMC is an unknown quantity at this point
Talon Sr blinking yellow or yellow/red
The Talon SRs on our bot are blinking yellow and a few are blinking yellow/red. We're using java but we tried building the default labview code and that worked-ish. The yellow blinking ones worked, but the yellow/red ones didn't with labview. Probably going to crosspost this to the programming forums but we're pretty stuck so any ideas are appreciated.
Unread 02-12-2018, 06:08 PM
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech has much to be proud ofTikiTech has much to be proud ofTikiTech has much to be proud ofTikiTech has much to be proud ofTikiTech has much to be proud ofTikiTech has much to be proud ofTikiTech has much to be proud ofTikiTech has much to be proud of
Re: Talon Sr blinking yellow or yellow/red
Here is a link to the users manual..
Looks to be a few things.. perhaps the Talons were not given different ID's?
CAN terminations? Calibration?
Go through the troubleshooting portions..
TALON USERS GUIDE
Good Luck..
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor - Kealakehe High School - Kailua-Kona, Hawaii
_ _ _ _
2018 Roebling | San Francisco Regional Chairman's Award | Sacramento Regional Finalist
2017 Los Angeles Regional Team Spirit Award | HI Regional Innovation in Control Award
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | HI Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Winners & Engineering Inspiration & Deans List
2014 Newton Division | HI Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Chairman's Award & Creativity Award | Los Angeles Regional Engineering Inspiration | HI Regional
2012 Curie Division | HI Regional Engineering Inspiration Award
2011 Newton Division | HI Regional Winners & Industrial Design Award
_
Unread 02-12-2018, 06:42 PM
TacoTheCat TacoTheCat is offline
AKA: Katya Rott
FRC #2374 (Crusader Bots)
TacoTheCat is an unknown quantity at this point
Hey there!
Electrical lead for team 2374 here. We've been working with talons for the past two years, and we've encountered a fair share of LED issues.
First, YELLOW blinking lights are the normal status. They mean that the talon a. Has power b. Has signal.
Blinking GREEN means the talon has signal to run forward, blinking JUST RED is reverse.
If it's blinking RED with quick YELLOW, that means "internal damage", which sounds scary but isn't unless you run it for a very long time. Something was probably plugged in wrong, or you have a short somewhere in the circuit. Check for checkerboarded wires, and then look for shorts in your signal wires, then look in your RoboRIO for a red power light. If you have a red power light you have a short somewhere (most likely), so vacuum over your roboRIO to suck out any metal shavings. (I recommend doing that anyway to clean everything out!!)
If you're still having issues, I recommend checking your circuitry with a multimeter to make sure you don't have shorts elsewhere.
I hope this helps!
Unread 02-13-2018, 10:30 AM
kdreed1999's Avatar
kdreed1999 kdreed1999 is offline
FRC #5114 (Titanium Tigers)
Rookie Year: 2015
kdreed1999 is an unknown quantity at this point
Your Talons most likely have the same device ID's. If you go into internet explorer and open the roborio go and change all the Talon ID's. Also they all won't show up because if they're new they'll all be zero so you have to refresh after numbering the Talon each time.
Unread 02-13-2018, 01:00 PM
Brian Michell's Avatar
Brian Michell Brian Michell is offline
FRC #1817 (Llano Estacado RoboRaiders)
Rookie Year: 2015
Brian Michell is just really niceBrian Michell is just really niceBrian Michell is just really niceBrian Michell is just really niceBrian Michell is just really nice
People seem to be missing that this is a Talon SR problem. Here is the manual for the Talon SR's.
Section 5 has the information you are looking for but I'll summarize it. Blinking orange means it's fine, but the bot is disabled or not receiving a PWM signal.
Blinking orange and red means:
1. It is not receiving enough voltage (less than 3.3V)
2. It is over temperature (over 170 degrees Celsius)
3. A transistor is shorted
If you test the first 2 and they are fine then chances are the Talon is damaged and you should replace them unless you have the materials and the know-how to repair it.
*Any views I express are my own and do not reflect those of any organization I am currently or formerly associated with unless stated.
5416
2015-2016: Programming, Drive Coach
6488
2017: Programming, Drive Mentor
1817
2018-?: Programming Mentor
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
