Go to Post I suggested it in brainstorming, but then people threw things at me. Apparently there ARE bad ideas in brainstorming. - Kevin Sevcik [more]
Unread 07-09-2018, 10:10 PM
JarJarTheJedi JarJarTheJedi is offline
Rookie Year: 2016
JarJarTheJedi is an unknown quantity at this point
Fan for 775pros
I am working on a drive gearbox that uses 3 775pros. On the Vexpro website, it says that the motor is primarily used for applications that don't have long periods of stall. Have people used 775pro gearboxes as drive gearboxes without major issues? Do you need some sort of fan near the motors cooling them down?
Unread 07-09-2018, 11:01 PM
messer5740's Avatar
messer5740 messer5740 is offline
AKA: Matt Esser
FRC #5740 (Trojanators)
Rookie Year: 2015
messer5740 has much to be proud ofmesser5740 has much to be proud ofmesser5740 has much to be proud ofmesser5740 has much to be proud ofmesser5740 has much to be proud ofmesser5740 has much to be proud ofmesser5740 has much to be proud ofmesser5740 has much to be proud of
Re: Fan for 775pros
I would recomend checking out PWNAGE's gearboxes from the past. They have had some good success with them. Remember to keep the air vents exposed on the motor! You dont NEED a fan but it is a good idea to keep them cool. I would just zip tie or make a mount for a fan to be used on the back or side of the motor.
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: Quarterfinalists at Greater Pittsburgh Regional and Buckeye Regional
2017: Dean's List Finalist
2018: Engineering Inspiration Award; Quarterfinalists at the Miami Valley and Greater Pittsburgh Regional
Unread 07-09-2018, 11:24 PM
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: Fan for 775pros
Not sure how effective fans would be for cooling motors to prevent a stall from burning them out. 775s burn out in just a few seconds in a stall condition, the amount of heat the generate in that short period is quite impressive.
775s do have internal fans, so as long as they don't reach a stall condition, they generally self-cool fairly effectively.
That said, I have played around with the idea of using pneumatic air pressure to force lots of air through the vent ports of a 775 motor rapidly during a stall condition so that the forced air serves to make up for the lack of airflow from the internal motor fan (since the fan isn't moving during a stall). Not sure if this is legal (technically, the motor wouldn't be a pressurized component, and you'd basically just be venting the pneumatics into the motor) or if it would be practical, but it seems like something that would be interesting to try. In theory, this might also be an effective way to internally cool CIM-type motors if used in conjunction with vented mounting screws.
To answer the first part of your question, my team used a pair of 775s and Decimate gearboxes on each of our two 3-CIM ball shifters this year, along with a pair of MiniCIMs on each gearbox (8 total drive motors). Never had any problems with the motors (aside from some gearbox mounting issues that were later resolved with Loctite). Overall, I'd definately be open to using 775s in a drive again, though it's worth noting that this game also didn't lend itself to the heavy-defense situations that you'd generally worry about a stall, so if we end up with another open-field high-defense game (ala 2014), it might be a harder call to make.
2005-2008: FRC 703 Phoenix - Robot Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 07-10-2018, 12:24 AM
Re: Fan for 775pros
If you were to set up a small stack of legal fans, and then 3D print a duct to fit to the vent port, you could probably get a similar effect. Or, better yet, use another 775Pro with a shrouded fan on it through a reducing duct...
I can't say for sure how legal that would be from a safety point of view, or from a pneumatics point of view, though I do recall a past Q&A that would seem to allow such a thing (though it would need to be asked again to be valid for 2019).
2003-2007: FRC0330 BeachBots; 2008: FRC1135 Shmoebotics; 2012: FRC4046 Schroedinger's Dragons
Unread 07-10-2018, 06:21 AM
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond repute
Re: Fan for 775pros
There was a thread on this a while back. The conclusion at the time was "you need a pretty big fan to make a dent".
Unread 07-10-2018, 07:27 AM
stramat8's Avatar
stramat8 stramat8 is offline
I speak for myself, not for my team
AKA: Mathew Strader
FRC #5406 (Celt-X)
stramat8 will become famous soon enoughstramat8 will become famous soon enough
Re: Fan for 775pros
We ran a single speed 775pro drive this year with 4 motors per gearbox. While machining the gearbox we made sure the motors could still get air by giving them a bit of a standoff. (you could also just machine openings in the plate) I'm sure current limiting helped also.
It would be cool to see the results of less motors!
Here is a snip of what we did.
https://drive.google.com/file/d/1ZHm...ew?usp=sharing
-Mat
My FIRST History
Team 781 - The Kinetic Knights : 2013 - 2015, Student - Design/Strategy/Mechanical/FLL/BRI
Team 5406 - Celt-X : 2015 - Current, Mentor - Mechanical/Design/Strategy
Unread 07-10-2018, 07:34 AM
Billfred's Avatar
Billfred Billfred is offline
Never look back, no, never say die
AKA: Always attack with the warrior's cry...
FRC #1293 (Pandamaniacs); FTC #11444 (Garnet Squadron)
Re: Fan for 775pros
I'd say "to make a dent in the middle of a match". Teams like Stryke Force have made adapters for their shop vacs so they can bring the internals down to ambient temperature quickly between matches.
Consider VEX's testing of the 775pro, especially the locked rotor stall test. As people will tell you, stalling at 12V is insta-death. It takes getting down to 6V before you can really get some breathing room, and even that has a pretty significant drop-off in torque over the time.
You do have to take care of 775-class motors more than you would a CIM or Mini CIM, but it's not impossible. Designing to run the motors on the high-speed side of the power curve, planning to run with voltage and current limits (so get your programmers studying the Talon SRX) well below peak (how far below depends on weight, wheel size, and CoF), and ensuring you've got enough power after all that nerfing to be effective (which is why a lot of single-speed designs use a fourth motor).
Do some deep searching--I'm time-limited this morning, but there are some top-notch threads on "775s on drive".
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Owner/Director of Bricks 4 Kidz in Columbia, SC.
2017: FRC 5402 (Iron Kings) - Mentor, Coach
2018-: FRC 1293 (Pandamaniacs) - Mentor
113 events (more than will fit in a ChiefDelphi signature), 15 seasons, over 74,500 miles, and still on a mission from Bob.
Unread 07-10-2018, 08:04 AM
cbale2000's Avatar
AKA: Chris Bale
Re: Fan for 775pros
It might be different with the FRC-legal fans, but I actually tried something similar with an 80mm computer fan a few months back and found that if you try to reduce the air channel smaller than a certain point (less than about 50% the diameter of the fan), the airflow simply "leaks" back out around the fan blades and doesn't go into the duct.
Now that said, I could see a fan mounted on the back of a 775 with a 3D printed duct that forces air through the rear vents as having some potential (perhaps in a "pulling" configuration), and it could augment the existing internal fan without interfering with it, though I still think pneumatics may be the only way to force enough air through fast enough to prevent (or delay) a stall burnout.
Unread 07-10-2018, 12:20 PM
philso philso is offline
Re: Fan for 775pros
Axial fans like computer fans work best at moving air in low back pressure applications like ventilating a box. Centrifugal fans give higher air flow than axial fans in applications with higher back pressure like forcing air along a long heatsink with a tight shroud around it or through a motor like the 775's. Centrifugal fans also tend to have a smaller outlet so there is less need to reduce the cross sectional area of the air path so there will be much less of the effects you are describing in your first paragraph.
The testing my colleagues did showed that at some point, increased airflow actually decreased the amount of heat removed from a heat sink. If I recall correctly, a high air speeds, the air molecules are not in contact with the heatsink for enough time to absorb the heat. You will need to find a way to install temperature sensors on your motor to get meaningful, quantitative results.
Unread 07-10-2018, 02:11 PM
Type's Avatar
Type Type is offline
AKA: AJ
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud of
Re: Fan for 775pros
My team ran 8- 775 Pros on our drivetrain and got them warm, but never to the point of stalling/ destroying. We used current limiting to help protect the amount of current that was allowed through (acting as a protector).
On our robot cart (inspired by Stryke Force's 2017 and 2018 cart), we installed 2- electric car radiator fans that would move a ton of air across the motors to cool them. A motor almost too hot to touch when placed on the cart was cold by the time we walked back to the pits.
3452- Lead Builder/ Pit Boss
*My posts do not reflect the opinion of my team*
Unread 07-10-2018, 03:18 PM
Re: Fan for 775pros
The part of the motor that really needs to be cooled is the rotor. Moving air over the motor will mostly only cool the outside can of the motor. The rotor may still be hot when the can feels cool.
Unread 07-10-2018, 03:40 PM
Billfred's Avatar
Re: Fan for 775pros
May, but testing has shown a fan blowing on the motor after hard running makes a meaningful impact. Maybe not enough to totally cool a CIM-based drivetrain between finals matches, but an 83% drop in cooling time for the air inside is significant in my book.
A 775-class drivetrain should be able to cool even faster, since it has less thermal mass, and I imagine big radiator fans cool a bit better than a 120mm KOP fan. (5402 used those in testing in 2017 mounted axially with respect to the CIMs, and they made a difference but didn't reach to the outside edges of the cans so there was definitely meat left on the bone.)
So I suppose the lesson is "let the fan run beyond the time the outer can is cooled to ambient", but how long is a matter for more instrumented testing (and then better data logging than Aren's post, though I appreciate him sharing what he has).
Unread 07-11-2018, 05:21 AM
wgorgen wgorgen is offline
FRC #1533 (Triple Strange)
wgorgen is a splendid one to beholdwgorgen is a splendid one to beholdwgorgen is a splendid one to beholdwgorgen is a splendid one to beholdwgorgen is a splendid one to beholdwgorgen is a splendid one to behold
Re: Fan for 775pros
We tried these heat sinks on our robot last year. We did not do any testing to measure the impact, but they did look pretty cool.
We still smoked a lot of motors, so take this with a grain of salt...
Unread 07-11-2018, 10:03 AM
BoilerMentor BoilerMentor is offline
Research Engineer, Medical
AKA: Charlie Baxter
FRC #1747 (Harrison Boiler Robotics)
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
Re: Fan for 775pros
Last summer in our testing of our 775 pro chassis that we ran this competition season, we took some thermal images of the motors after high load activity. It's apparent looking at the photos that the primary heating in the motors is occurring in the region of the brushes and brush arms. Active cooling will do little to protect these regions because of how quickly heating occurs and how little thermal mass the components in question have.
Instead of active cooling, I would strongly suggest considering imposing an artificial current limit in your design space. Since the standard in FRC drive design is to target a traction limited situation, make sure you cross your traction limit at a lower current. This means more gearing (larger reduction) and a lower limit for peak robot speed if you're targeting a single speed drive. JVN's calculator outputs the current information natively.
For reference we were geared for 21ft/s theoretical with imposed limits of 14 ft/s in auto and 18 ft/s in teleop with a full weight robot on black 6" hi-grip wheels in a drop center six wheel configuration with eight motors in the drive. Our theoretical traction limit occurred at ~40% rated stall torque. In changing traction materials for off season play we discovered that by increase our available traction our drive was no longer traction limited, because we were exceeding the capacity of the battery to supply the required current. It's a new limit, and something we're developing a method to instrument for testing purposes.
If you have any specific questions, please reach out. People seem to be afraid of these drive trains, and there are considerations, but the threshold for safe use of 775's in the drive is not so daunting as often advertised.
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
2015-2017 Ri3D Team Indiana - Mechanical and Fabrication
Unread 07-11-2018, 10:23 AM
Billfred's Avatar
Re: Fan for 775pros
I agree that active cooling is of limited utility during the match, though I would venture a fan setup for after the match is more valuable in bringing the motors down to ambient temperature.
I'll ask a couple about your particular setup: How did you implement your speed limits? Did you replace any motors during the season, either due to failures or as preventative maintenance?
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
