OCCRA
Go to Post It's really quite amazing what people will find time to talk about in the month before kickoff. - Ekcrbe [more]
CD-Media
Unread 01-10-2018, 06:06 PM
traverda traverda is offline
FRC #3009 (The High Scalers)
Rookie Year: 2016
traverda is an unknown quantity at this point
Send a message via AIM to traverda Send a message via MSN to traverda Send a message via Yahoo to traverda
ADI 16448 Registry Set Error
Last year our team used the ADI 16448 IMU in LabVIEW, and this year the associated IMU vi's have changed so that they no longer properly "play" together. It appears that the "IMU 16448 Open" vi has been very recently modified (github.com/juchong/ADIS16448-RoboRIO-Driver), but not the "IMU 16448 Set/Get Registry" vi's. The Open exposes an "ADI IMU DevRef Out" data type, and the associated "ADI IMU Registry Set" currently expects an "ADI Interrupt DevRef In" type as input. The corresponding "ADI IMU Registry Get" likewise outputs an "ADI IMU Interrupt DevRef" type, not an "ADI IMU DevRef" output the "ADI IMU Reset" is expecting. Is there a conversion between the two data types that I am missing?
Unread 01-14-2018, 11:49 PM
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong has a reputation beyond reputejuchong has a reputation beyond reputejuchong has a reputation beyond reputejuchong has a reputation beyond reputejuchong has a reputation beyond reputejuchong has a reputation beyond reputejuchong has a reputation beyond reputejuchong has a reputation beyond reputejuchong has a reputation beyond reputejuchong has a reputation beyond reputejuchong has a reputation beyond repute
Re: ADI 16448 Registry Set Error
Hi! It looks like in my haste to finish updating the driver I failed to clean up. dkt01 on GitHub went ahead and cleaned up the DevRef issues. If you pull and use the new code, you should be good to go! I'm also working on building an updated installer that should be online later tonight.
Team 1817 | Llano Estacado RoboRaiders | Mentor | 2007-2011
Team 3730 | NuBots | Mentor | 2012
Team 3005 | RoboChargers| Mentor | 2013-2014
Team 2655 | The Flying Platypi | Mentor | 2014-2018
Analog Devices Inc. | KoP Supplier | FRC Gyro Designer | More Info
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
