OCCRA
Go to Post I have many ideas, every last one of them involves finding something more productive to do with your time. - Andrew Schreiber [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
  #31   Spotlight this post!
Unread 10-08-2018, 07:47 AM
Akash Rastogi's Avatar
Head Coach | Lead Mentor
FRC #5686 (Wirecats)
Re: Interesting AM14U2 and AM14U3 upgrades
Originally Posted by risho900 View Post
Instead of having threads in the wood like you described, would it be ok if we used self tapping/drilling screws to attach the bumper?
I don't recommend this if I understand your question. You want to drill into the bumper backing each time?
If you don't want to insert threads into the bumpers, use L brackets that are attached to the bumper and then the L brackets are bolted to your chassis.
Jim Zondag is my spirit animal.
['18-'xx]: Lead Mentor FRC 5686 (formerly FRC 1059)
['17-'17]: Mentor FRC 2170
['13-'14]: Floating Mentor FRC 11/FRC 2495
['11-'13]: Founding Mentor FRC 3929 - 2012 World Championship Rookie Inspiration Award
['07-'10]: Student/Captain FRC 11 - MORT
  #32   Spotlight this post!
Unread 10-08-2018, 08:20 AM
Type's Avatar
Type Type is online now
AKA: AJ
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud of
+1
We've been doing that for years and I cant imagine having to reattach through the wood each time we wanted to mount our bumpers.
3452- Lead Builder/ Pit Boss
*My posts do not reflect the opinion of my team*
  #33   Spotlight this post!
Unread 10-08-2018, 09:37 AM
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by Type View Post
+1
+2.
Please don't attach your bumpers using only wood screws. They will come off.
I have sometimes been one of those grey-haired inspectors informing a team that their bumper attachment method is not secure enough. The most recent incarnation of the robot rule I have in mind is R30-G (2018):
G. must attach to the FRAME PERIMETER of the ROBOT with a rigid fastening system to form a tight, robust connection to the main structure/frame (e.g. not attached with hook-and-loop, tape, or tie-wraps). The attachment system must be designed to withstand vigorous game play
Generally, my spiel goes like this: "I could pass your bumpers now, but if they come off during a match, which is likely if your robot takes a modest hit, then two things bad things might happen. The first is that your robot will be disabled per G07 (2018), causing your alliance to become weaker and perhaps lose the match. The second is that a referee will order a re-inspection before your robot is allowed to compete again, and in that case your inspector will require more robust bumper attachment. My advice is to get it done now."
Richard Wallace
since 2003
  #34   Spotlight this post!
Unread 10-08-2018, 07:37 PM
GeeTwo GeeTwo is offline
In Transition
AKA: Gus Michel II
I can't imagine any circumstance I'd be sanguine with self-tapping screws being removed and replaced to mount bumpers. You don't want each removal/replacement of the bumper to actively threaten your fastening system.
[Quoting brennonbrimhall]: We design a new robot every year, but we can't forget that we also design a new team every year as folks come and go.
  #35   Spotlight this post!
Unread 10-08-2018, 08:27 PM
risho900 risho900 is offline
FRC #6897 (Astraea Robotics)
Rookie Year: 2015
risho900 has a spectacular aura aboutrisho900 has a spectacular aura about
Sorry sorry, I meant use self tapping screws to attach the bracket to the bumper and then when we take off or remove bumpers, its the bracket that gets unscrewed from drive base, not the tapping screws.
  #36   Spotlight this post!
Unread 10-08-2018, 09:59 PM
Type's Avatar
AKA: AJ
Rookie Year: 2016
My team always uses t-nuts and typically flathead screws to attach our brackets to the wood. Since we are never removing the brackets from the bumper, we dont have any issues with the t nuts getting messed up.
  #37   Spotlight this post!
Unread 10-09-2018, 10:06 AM
In Transition
AKA: Gus Michel II
Some self-tapping screws are really designed for metal and some will damage wood more than is necessary to enter the screw. Also, there are no threads on about 1/4" of their length; I wouldn't recommend these for either of these reasons. Drywall/deck thread screws work pretty well, though I'd try to find some which present a flat face (rather than a fluted face) against the bracket. And whatever screws you use, don't overtighten.
Single-use T-nuts should work OK. I seem to recall a team which used 1/4" carriage bolts (head on the noodle side) to good effect.
  #38   Spotlight this post!
Unread 10-09-2018, 01:28 PM
We've been using these wood screws for attaching angle to bumper backing.
We have also used them to attach brackets that reinforce the corners of our wrap-around one-piece bumpers.
Richard Wallace
since 2003
  #39   Spotlight this post!
Unread 10-10-2018, 06:39 PM
Bill Klein Bill Klein is offline
FRC #3688 (Norsemen Robotics)
Bill Klein is a jewel in the roughBill Klein is a jewel in the roughBill Klein is a jewel in the roughBill Klein is a jewel in the rough
I was under the understanding that you could only use aluminum to reinforce the bumper corners. Did I interpret the rule incorrectly?
  #40   Spotlight this post!
Unread 10-10-2018, 06:56 PM
Good catch, you're right. R30-F requires those brackets to be aluminum. R30-B also requires that they not extend more than 1" beyond the frame perimeter. I don't think we found a COTS aluminum part to match the common steel one that I linked earlier, so IIRC we had to make them.
Richard Wallace
since 2003
  #41   Spotlight this post!
Unread 10-19-2018, 08:33 PM
Thatscoutingguy Thatscoutingguy is offline
AKA: Amogh C
FRC #1807 (Redbird Robotics)
Rookie Year: 2016
Thatscoutingguy is an unknown quantity at this point
Has anyone experimented with VexPro 3 CIM Dog Shifter on the KOP? I'm aware that VexPro has a guide to installing the ball shifter on the kit of parts chassis, but nothing regarding interfacing the 3 CIM Dog Shifter. Interested to hear how people dealt with the different mounting holes on the gearbox and KOP plate and any other concerns with using this gearbox on the KOP chassis.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
