OCCRA
Go to Post I think this just hit the nail in the head with a sledgehammer. - Yan Wang [more]
Go Back   Chief Delphi > Competition > District Events
Unread 03-26-2018, 12:09 PM
346CADmen's Avatar
346CADmen 346CADmen is offline
Lucky husband and father.
FRC #0346
346CADmen has much to be proud of346CADmen has much to be proud of346CADmen has much to be proud of346CADmen has much to be proud of346CADmen has much to be proud of346CADmen has much to be proud of346CADmen has much to be proud of346CADmen has much to be proud of346CADmen has much to be proud of346CADmen has much to be proud of
Blue Wins
Found it interesting after a review, CHS SWV event the blue side had 40 wins while red had 21 through 62 qualification matches. (1 tie) Is this coinsidence?
Unread 03-26-2018, 12:28 PM
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit has much to be proud ofAustinShalit has much to be proud ofAustinShalit has much to be proud ofAustinShalit has much to be proud ofAustinShalit has much to be proud ofAustinShalit has much to be proud ofAustinShalit has much to be proud ofAustinShalit has much to be proud ofAustinShalit has much to be proud of
Re: Blue Wins
Yes.
Unread 03-27-2018, 06:31 AM
346CADmen's Avatar
FRC #0346
Re: Blue Wins
Originally Posted by AustinShalit View Post
Yes.
Interesting that you are sure. I would like to think so too. However experience tells me such things should be confirmed. Not sure if any checks or measures exist or are made to assure field setup and action is working and recorded properly.
Unread 03-27-2018, 01:43 PM
Sir_Fenwick's Avatar
Sir_Fenwick Sir_Fenwick is offline
Change Your Battery
AKA: Jacob Colson
FRC #2883 (Fighting Rednecks Engineering & Design)
Sir_Fenwick is a jewel in the roughSir_Fenwick is a jewel in the roughSir_Fenwick is a jewel in the rough
Re: Blue Wins
Its a very strange coincidence that also has been shown to happen at all regionals/events. For whatever reason, blue alliance wins more often than red. This is not implying that a red alliance won't win a regional, but for whatever reason the blue alliance is more likely to win a match. Its a very weird trend. I don't remember where all on that data is compiled, but if I find it, I'll link it.
Unread 03-27-2018, 10:00 PM
AriMB's Avatar
AriMB AriMB is online now
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Re: Blue Wins
My guess is that if this is truly the case, it has to do with playoff blumper color assignment. IIRC assuming a perfect bracket the higher alliance is always blue. There, it makes sense that the blue alliance generally has a higher chance of winning. I expect if you kust look at the data for quals, you’ll see a much more random distribution.
I can assure you, there is no grand FRC conspiracy to disadvantage the red alliance
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
Unread 03-27-2018, 10:04 PM
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
no team (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond repute
Re: Blue Wins
Not quite - in quarterfinals, higher seed is always red. After that, the colors are as follows:
SF:
  • Seed 1 or 8 - Red
  • Seed 2 or 7 - Red
  • Seed 3 or 6 - Blue
  • Seed 4 or 5 - Blue
Don't forget your towel!
Unread 03-27-2018, 10:31 PM
AriMB's Avatar
FRC #5987 (Galaxia)
Re: Blue Wins
SF:
  • Seed 1 or 8 - Red
  • Seed 2 or 7 - Red
Oops...remembered that backwards
Without seeing the data then my best guess would be too small of a sample size to properly converge to 50%.
Unread 03-27-2018, 10:52 PM
010101001010101 010101001010101 is offline
010101001010101 is an unknown quantity at this point
Re: Blue Wins
Well obviously there is a statistical bias in the elims but it is an interesting trend in the qualification matches where they shown be about 50/50.
Unread 03-28-2018, 07:18 AM
346CADmen's Avatar
FRC #0346
Re: Blue Wins
Was never concerned about any conspiracy, simple quality control. If a trend/pattern like this presents, are any checks made? I am unsure of how the field/scoring is set. Was a limit switch slightly out of position? Were all elements in balance, per specification? Are their specifications?
Appreciate I am not pointing fingers or blaming anyone. It could well be coincidence, but should parameters be set so that FTA's can assure the field is working properly?
Unread 03-29-2018, 07:10 PM
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #0612 (Chantilly Robotics)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Re: Blue Wins
Maybe it follows the theory about police officers tagging red cars more often than beige or others that are more color neutral. The red colored bumpers stand out more, and therefore induce more ref fouls because their movement and activity naturally get caught by the ref's eye more often?
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-Present (Huntington Beach, CA)
Team 612 Engineering Mentor (Chantilly, VA) Present
Unread 03-30-2018, 07:13 PM
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
Re: Blue Wins
Watching a few of the webcasts I have seen FTAs go use a calibration sick to make sure a scale trips at the correct point after matches that see heavy robot to scale interaction. I believe there is a spec for how far the scale should move to trigger. There is also a general spec for how accurate the field should be for dimensions and such. There is another interesting thread discussing the ratio of the different color randomizations.
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes | 2017 SE Mass #7, QF, Inspector - Reading #4, Winners (1071, 5556), EI, Inspector - NECMP #TBD
Unread 04-01-2018, 01:33 PM
richardahn_!219 richardahn_!219 is offline
AKA: Richard Ahn
FRC #2930 (Sonic Squirrels)
Team Role: Electrical
Rookie Year: 2015
richardahn_!219 is an unknown quantity at this point
Re: Blue Wins
At the Glacier Peak Week 4 event in PNW, there were only 2 matches in playoffs where blue won, and they were by the same team in semis. Every other match was red.
Unread 04-01-2018, 01:58 PM
Liu346's Avatar
Liu346 Liu346 is offline
FRC #0346 (Robohawks)
Liu346 is an unknown quantity at this point
Re: Blue Wins
There is a statistical bias for red alliance in elims. The point he is making is only for quals where there should not be one.
Unread 05-09-2018, 03:22 PM
346CADmen's Avatar
FRC #0346
Re: Blue Wins
Qual. 103 Galileo Houston
Watched this match (for something unrelated) but noticed a score error that gave me concern which has to do with the OP of this thread.
Toward the end of this match (57 seconds) Blue clearly controls red switch (indicated by the FMS/scoreboard as well as casual observation. However at 30 seconds left (endgame), red regains control, per FMS/scoreboard although no more cubes have scored or even shifted.
What means of field operation quality control exist and are put in action if a question comes about?
Unread 05-09-2018, 08:19 PM
AKA: אוסטין
Re: Blue Wins
Red played a force...
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
