OCCRA
Go to Post Frank is frank, and I like that. - rsisk [more]
Unread 12-04-2017, 07:44 PM
Sky Captain's Avatar
Sky Captain Sky Captain is offline
Software Mentor and FIRST Volunteer
AKA: Will
FRC #0386 (Voltage)
Sky Captain is an unknown quantity at this point
Jetson TK1 Power Jack
Hey CD,
During one of our preseason meetings, one of our students knocked our Jetson TK1 off the worktable and screwed up the power jack. We can get power to flow by holding the power adapter at a strange angle, but obviously this is unacceptable when it is mounted on the robot. I have done some research and have to come to two possible solutions.
1. Order a new thru-hole power jack and re-solder it onto the board. I need the exact part number, or similar one for this, and a source for it.
2. Solder power wires directly onto the pads on the board bypassing the power jack completely. (Relatively unsafe, and need to reinforce connection for use on robot)
If anyone can provide a part number for the barrel jack, that would be greatly appreciated. Any other suggestions are welcomed as well.
Thanks.
When in doubt, RTFM.
Unread 12-05-2017, 12:51 PM
21brownz's Avatar
21brownz 21brownz is offline
AKA: Zach Brown
FRC #6502 (DARC SIDE)
Rookie Year: 2018
21brownz is an unknown quantity at this point
Re: Jetson TK1 Power Jack
I've done a lot of jobs like this. I produce some music on the side, and a lot of the gear I buy from people is used/broken. Luckily, the datasheets have the info I need. Going off that info, in my opinion, your best bet it to probably check the datasheet.
Good Luck!
Zach
Unread 12-05-2017, 12:58 PM
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is on a distinguished road
Did you inspect it? Did it crack the the structure or did it break and/or rip a track off the board? You may be able to just reheat and solder the existing connector.
If your going to use it on the bot don't replace it with the OEM just solder a wire whip on and use your own connector as long as you never over volt it.
Unread 12-09-2017, 11:37 AM
AKA: Will
FRC #0386 (Voltage)
@amesmich, I have found the schematics, but it only lists the power jack as a power adapter, doesn't provide me with a part name and #. Thanks though.
@21brownz, This is option we're going with. I found this guy's guide, and we're following it. Thanks for the suggestion!
