Go to Post Don't limit programming to just hitting keys, there is a lot of logic/design involved. - Mike [more]
Unread 08-11-2017, 10:12 AM
AmitShavit's Avatar
AmitShavit AmitShavit is offline
FRC #1577 (SteamPunk)
Team Role: CAD
Rookie Year: 2015
AmitShavit is an unknown quantity at this point
pic: Flipped Transmission By SteamPunk #1577
Unread 08-11-2017, 10:14 AM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
Rookie Year: 2012
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Re: pic: Flipped Transmission By SteamPunk #1577
Looks good! It's pretty standard in FRC to add 0.003" (0.067mm) between gears to keep them from binding up. It looks like the pocketing could use a bit of work (especially in the inner-most plate), but other than that it looks like a nice gearbox.
Studying MechE at the Technion - Israel Institute of Technology
2017-present: Technical Mentor FRC 5987
2017-present: CSA for FIRST Israel
2012-2016: Member FRC 423 Captian, Programmer (LabVIEW), Electrical, CAD, Manipulator, Chassis, Business, Outreach (everything)
Unread 08-11-2017, 11:29 AM
Peter Salisbury Peter Salisbury is offline
FRC #5811 (The BONDS)
Team Role: Tactician
Rookie Year: 2010
Peter Salisbury has a brilliant futurePeter Salisbury has a brilliant futurePeter Salisbury has a brilliant futurePeter Salisbury has a brilliant futurePeter Salisbury has a brilliant futurePeter Salisbury has a brilliant futurePeter Salisbury has a brilliant futurePeter Salisbury has a brilliant futurePeter Salisbury has a brilliant futurePeter Salisbury has a brilliant futurePeter Salisbury has a brilliant future
I second everything here. My two additions are:
1. I don't know anything about your team's manufacturing, but make sure you can hold at least +- 0.003" accuracy on your mill or router. If you are +- 0.004" or worse, you can go the "beneath" the 0.003" addition and really grind gears. This makes very inefficient gearboxes and very hot CIMs, not fun. Single speed does make manufacturing easier and this gearbox is well packaged, so that is good.
2. Your theoretical free speed with a 4" wheel is nearly 20ft/s which is pretty speedy, so make sure you leave room for drive practice, and avoid prolonged pushing matches. Even with some more conservatively geared 4CIM single speeds, you are in danger of really heating up motors or popping breakers, if your robot is heavy. I speak from experience. At our off-season event our shifting gearboxes got stuck in high gear (18ft/s theoretical max), and after a ~10s pushing match our main breaker popped. If your robot is heavy and geared aggressively, AKA not traction limited, you can stall CIMs and pop breakers quickly.
With those warnings out of the way, this looks like a good gearbox overall.
Unread 08-11-2017, 11:32 AM
Rookie Year: 2010
1. I don't know anything about your team's manufacturing, but make sure you can hold at least +- 0.003" accuracy on your mill or router. If you are +- 0.004" or worse, you can go the tighter than the 0.003" addition and really grind gears. This makes very inefficient gearboxes and very hot CIMs, not fun. Single speed does make manufacturing easier and this gearbox is well packaged, so that is good.
Unread 08-11-2017, 03:15 PM
marcusbernstein's Avatar
marcusbernstein marcusbernstein is online now
Baseball hat kid
AKA: Marcus Bernstein
FRC #1836 (Milkenknights)
Team Role: Team Spirit / Cheering
Rookie Year: 2013
marcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond repute
Looks like a solid design! Don't forget about wires when you're placing your cims. It looks like they may need to go a little further from the edge of the wheel just to be safe, but hard to say without CAD. Your lightening is decent, but it could use a bit of work on improving strength. There are a couple spots where I would add more struts, but I tend to be pretty conservative with lightening so you may be fine. I hate the wasted space with the sprocket, but it is kind of necessary with the length of the Cims. An interesting tradeoff here is using 3 minicims, but that also has its own problems like more pdp ports, weight (in pinions fasteners and extended plates), and height among others. Maybe you could fill some of that wasted space with an encoder mount just so its conveniently in the gearbox, or maybe some of that space can be taken up with shifting. I've tried over and over, and with shifting you can't get much better packaged than the WCP flipped cim, but it's interesting to see how you've retained this nice package without shifting.
Great job on the design!!!
Here are some quotes that drive me and my team to be successful: (some are mine, some are borrowed, and the list will continue to grow)
"Once you've concluded that it isn't a code problem, it isn't an electrical problem, and it isn't a mechanical problem, after all that blaming you now have a culture problem."
"Precedence is no excuse for being wrong."
"Aesthetics are great, but not at the expense of functionality."
"An entire team rallied around a potentially wrong decision is better than half a team rallied around the right one. And if that potentially wrong decision ends up being the right one, that unified team will be successful."
My views do not necessarily represent the views of my team or any other groups I am affiliated with.
Unread 08-11-2017, 06:26 PM
Lidor51's Avatar
Lidor51 Lidor51 is offline
Mentor & Coach
AKA: Lidor Kaplan
FRC #1577 (Steampunk)
Lidor51 will become famous soon enough
Thanks both of you Ari and Peter for the 0.003" tip.
Peter, we're pretty confidence about the speed, but if we see we need lower ratio so we will go with 3.5" wheel.
We're planning to add an encoder mount in the final version.
2012 Driver & Progammer.
2013 Team Captain & Driver.
2014-Present Mentor & Coach.
Steampunk 1577, Israel.
Facebook Instagram Youtube Website
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
