Go to Post just thinking about the array of mechanisms awaiting my examination tingles the thinky parts of my brain. - Tytus Gerrish [more]
Unread 08-13-2017, 03:43 AM
jaewon hwang jaewon hwang is offline
FRC #5124
jaewon hwang is an unknown quantity at this point
Methods of strengthening material?
Hi, I've been wondering about how to strengthen the rigidity and raise the resistance of wear of certain materials.
So far, what I've found is that you can strengthen the rigidity of aluminum and certain plastics by using carbon fiber. However, carbon fiber is a very time consuming process and can also be expensive. The carbon fiber itself isn't expensive, however, the machinery needed to spool and thread each part can be expensive.
Has anyone come up with any other solutions? I feel like I've heard of people talk about some sort of vinyl/adhesive where you apply an epoxy after you stick on the vinyl to aluminum/plastic and it hardens, giving the aluminum/plastic extra rigidity.
I've also researched that the carbon fiber vinyl wraps don't actually strengthen the material, but they look cool and reduce some of the wear.
You can also raise the resistance against wear of certain metals such as aluminum and titanium(Really really expensive), by anodizing it. However, anodizing can be hard when you have to put large parts in an electric bath. Are there any other better methods? Maybe a film adhesive? I know that cars sometimes have a film adhesive they apply on the front exterior of the car in order to prevent scratches in the paint.
I also understand that some parts if designed better with structural supports will obviously have more rigidity, but sometimes the weight limit or just the lack of manufacturing tools prevents teams from doing so.
Are there any better alternatives to the conventional materials most teams use?
The debate between aluminum and steel have been somewhat controversial, but what about acrylic? Acrylic's known to shatter. I've seen teams use Lexan or some other sort of plastic, but what do you guys recommend?
Sorry for the wall of questions, but I would be grateful for any advice.
Unread 08-13-2017, 07:14 AM
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #3739 (Oakbotics)
Rookie Year: 2012
cad321 has much to be proud ofcad321 has much to be proud ofcad321 has much to be proud ofcad321 has much to be proud ofcad321 has much to be proud ofcad321 has much to be proud ofcad321 has much to be proud ofcad321 has much to be proud of
Re: Methods of strengthening material?
With regards to anodizing, try looking online for local companies that do anodizing professionally. Go in and explain what it is you do. You may find that they're willing to do a few parts as a donation to you. We managed to get a company this year to do our gearbox plates (purely aesthetics) and have now since formed what is hopefully, a lasting relationship.
Unread 08-13-2017, 07:49 AM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
Rookie Year: 2012
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
This post might interest you.
Acrylic is definitely a no-go because it shatters very easily. Polycarbonate is much stronger than acrylic, but if you're looking for stiffness then you're looking in the wrong place. PC is good for light-weight mechanisms and out-of-frame extensions that need to be flexible to withstand hits.
I wouldn't really be worried about wear in FRC robots as long as your robot is designed well. FRC robots will very rarely see 100 hours of use never for more than 5 minutes at a time, which is nothing compared to machines in industry that run constantly for years. Aside from wear on rubber parts and tread (and battle scars), the most wear your robot should get is maybe a bit of rust on steel parts over the years. Anodizing makes parts look nice, but for FRC it's not really required.
Overall, I would say the best way to increase the rigidity of your mechanisms is to design the parts better. I would venture to say that there are very few (if any) designs for FRC that would need to be made from non-standard materials for rigidity or wear purposes (whether you want to for other reasons is a different story). If you aren't a powerhouse team looking to optimize every little detail, there are probably better uses of your team's time and resources than experimenting with non-standard materials.
Studying MechE at the Technion - Israel Institute of Technology
2017-present: Technical Mentor FRC 5987
2017-present: CSA for FIRST Israel
2012-2016: Member FRC 423 Captian, Programmer (LabVIEW), Electrical, CAD, Manipulator, Chassis, Business, Outreach (everything)
Last edited by AriMB : 08-13-2017 at 08:26 AM. Reason: accidentally wrote "right" instead of "wrong"
Unread 08-13-2017, 08:16 AM
Chris is me's Avatar
\_(ツ)_/
AKA: Pinecone
FRC #3929 (Atomic Dragons); fmr. FRC #228 (GUS) & FRC #2791 (Shaker)
In general, new designers in FRC focus way, way too much on material and not enough on changing geometry for strength. Making a piece thicker, changing the profile to something more rigid (e.g. replacing flat plates with c-channel or tube), increasing the size of the cross section (replacing small-diameter solid axles with large-diameter hollow ones), etc. are all easy ways to get strength without really changing the material or how much weight is used.
It's hard to talk about this stuff in the "generic case", so it would help to have some examples to work from.
In general, if you're running into the limits of the strength of your material in FRC, either the material is completely inadequate for FRC (acrylic) or you've done something very wrong in the design.
Mentor: 3929 (2018-?)
Mentor / Drive Coach: 228 (2016-2017) - 2016 RIDE Winner (with 1058, 6153)
Consultant Person: 2170 (2017)
College Mentor: 2791 (2010-2015) Build Photos - 2013 WPI Regional Finalists (with 20, 3182), 2012 BAE Finalists (with 1519, 885)
Student: 1714 (2009) - 2009 MN 10K Lakes Regional Winners (with 2826, 2470)
Unread 08-13-2017, 01:58 PM
marcusbernstein's Avatar
marcusbernstein marcusbernstein is offline
Baseball hat kid
AKA: Marcus Bernstein
FRC #1836 (Milkenknights)
Team Role: Team Spirit / Cheering
Rookie Year: 2013
marcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond repute
This summer, one of the the things my team has experimented with is Carbon Fiber! Despite my initial hesitation, it wasn't as time consuming and grueling as I had imagined. Alyssa, who was once the carbon master on 2485 ran a workshop with us, and it took us a few hours to cut our sheets/let the eposy set, and another few hours the next sunday (you could do the next day) after it cures to cut out the final shape and stuff like that. We didn't actually need a machine to spool the carbon as we just bought a long length pre-woven and some other smaller stuff per Alyssa's reccomendations. While The Milkenknights will not be making every part in Carbon Fiber next year, its pretty clear that using the Carbon is totally feasible. That said, Carbon is a nice alternative when you want to trade some extra work for weight. In many cases, using thicker material will do the trick for much less time and other resources and the Milkenknights will likely go that route in most cases for a hypothetical 2018 game.
Unless your bot is really hurtin for weight, I wouldn't risk using those weaker materials or devote resources to things like carbon fiber *
A few exceptions to that would be 2015 can grabbers,
2011 massive arms, and anywhere else something needs to be super strong and light.
* All depends on your teams resources like money, manpower, machines, etc.
Here are some quotes that drive me and my team to be successful: (some are mine, some are borrowed, and the list will continue to grow)
"Once you've concluded that it isn't a code problem, it isn't an electrical problem, and it isn't a mechanical problem, after all that blaming you now have a culture problem."
"Precedence is no excuse for being wrong."
"Aesthetics are great, but not at the expense of functionality."
"An entire team rallied around a potentially wrong decision is better than half a team rallied around the right one. And if that potentially wrong decision ends up being the right one, that unified team will be successful."
My views do not necessarily represent the views of my team or any other groups I am affiliated with.
Unread 08-13-2017, 06:06 PM
DonRotolo's Avatar
Standing on their shoulders
FRC #0832
You are touching upon one of the fundamental issues of engineering: Stronger, lighter, and not expensive.
The short answer is: It's not always easy, but anything can be done.
The longer naswer is that it really depends on the exact usage a part will get.
Two trivial examples: If two parts rub against each other, therefore are subject to wear, to reduce wear you can add a low-friction material between them, and that will reduce wear. "Low-fricthion" can be oil, grease, teflon, or even paper.
If Part "X" needs to to resist bending from a load "Y" placed upon it, there is an optimal shape and size for a given material that will do that. This can be determined experimentally (make smaller and smaller X until it fails, then go back tot he last one that didn't fail) or theoretically (do the engineering math).
There is no easy answer - "Just wrap all parts in zirconium foil" - because each and every part is unique in its requirements. You don't need an engineering degree, but some level of understanding of Statics & Dynamics, and Materials, will answer most of your questions.
Sorry it's not easy.
Unread 08-13-2017, 06:59 PM
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Rookie Year: 2011
Mk.32 has a reputation beyond reputeMk.32 has a reputation beyond reputeMk.32 has a reputation beyond reputeMk.32 has a reputation beyond reputeMk.32 has a reputation beyond reputeMk.32 has a reputation beyond reputeMk.32 has a reputation beyond reputeMk.32 has a reputation beyond reputeMk.32 has a reputation beyond reputeMk.32 has a reputation beyond reputeMk.32 has a reputation beyond repute
The classic engineering conundrum since 'stiffer' means more brittle. Why glass is very stiff but when it does get pushed hard enough instead of flexing it shatters into a million pieces. Same concept on why acrylic is horrible for robots, an impact and you are gonna have acrylic everywhere.
Polycarb is a bit more so the other way it's fairly flexible so when it does take an impact it bends instead of breaking but it's sometimes more flexible then you want for a lot of robot parts. Plastics like ABS/Delrin/UHMW are in the middle of the stiffness vs strength area.
Aluminum (6061 and 7075 mainly) is a great balance between stiffness and overall strength. Generally pretty sturdy and will flex before snapping. As it seems you already understand geometry and proper design is usually more important then whatever fancy material you can find or dream about. This is something most FRC folks learn the hard way as the hivemind generally is "add more material". It's hard but getting comfortable understand loading is one of the key aspects of design.
For example this year we used a combination of bolted together aluminum to frame basic structure of the robot but then welded on supports and gussets to increase stiffness in the directions we wanted to. Made it easy to mill all the parts and have the kids bolt them together square. Which then meant the welded on pieces can be simply clamped on and the welder lays the bead. And we can run thin 1/16 wall instead of 1/8.
Carbon fiber has the best stiffness to weight ratio, period. Why it's used in aircraft and drones a lot. Since well they can't fall apart and but still be light enough to fly efficiently. But work with carbon fiber has a lot of issues in the FRC world. You can by per-weaved sheets or even sheets with epoxy already embedded in them (call prepreg needs to be stored in a fridge). But simply taking an aluminum structure and warping it in carbon fiber + coating it in a layer of epoxy isn't gonna give you the strength you want in the ways you want. The team this year moved away from it and it saved a good deal of time and effort. But using carbon fiber plates as covers, or using carbon fiber tubes for rollers and such did work out very well on some mechanisms.
You can post some designs on CD and get some quick pointers from the various more experienced folks to if you are practicing design over the fall/summer.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 08-14-2017, 01:03 AM
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
There's always the option of changing your alloy and/or temper. (Cue metallurgical debate.) That being said, that's a "procurement" solution, and probably not what you're looking for.
Material selection 101:
Define what exactly you are looking for this material--we'll call it "unknownium" for now--to do.
Are you looking for:
  • Stiffness?
  • Toughness?
  • Strength (and in which direction)?
  • Wear resistance (and why would it be wearing)?
  • Fatigue resistance?
  • Ductility?
  • Ease of working?
  • Light weight?
Different materials have different answers to each of these questions, and even the same material may have slightly different answers for different applications.
If you want better wear resistance, though... May I suggest a couple of extra washers at the pivot/fastening joints? Sounds like you want a little bit of air in between two pieces. The other decent alternative is a sacrificial coating that will wear out, tell you it's worn out, and be replaced.
Past teams:
2003-2007: FRC0330 BeachBots; 2008: FRC1135 Shmoebotics; 2012: FRC4046 Schroedinger's Dragons
Unread 08-14-2017, 09:19 AM
Type's Avatar
Type Type is offline
AKA: AJ
FRC #3452 (GreengineerZ)
Team Role: Mechanical
Rookie Year: 2016
Type is a splendid one to beholdType is a splendid one to beholdType is a splendid one to beholdType is a splendid one to beholdType is a splendid one to beholdType is a splendid one to beholdType is a splendid one to behold
Just to back some of this up, my team had an arm that a Bosch Seat motor would rotate using a milled down hex shaft. The arm wasn't that big or heavy, but at the beginning of season we used 7075 aluminum for it. We noticed a slight twist so we replaced it with stainless (Alloy unknown). That was too strong of a material and it ended up destroying our gearbox from not having the ability to flex. We made a new set of shafts using 6061 (us not watching the alloys when purchasing) and those twisted to a breaking point about every match.
Long story short, alloys can make a huge difference in the strength, while weighing nearly the same.
3452- Lead Builder/ Pit Boss
*My posts do not reflect the opinion of my team*
Unread 08-14-2017, 01:13 PM
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Rookie Year: 2013
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
I'm intrigued by this statement. Also, it sounds like material choice wasn't your root problem. Do you know what was really causing the failures?
"It's taking longer than expected, which was to be expected."
Unread 08-14-2017, 05:11 PM
danieltcalkin's Avatar
danieltcalkin danieltcalkin is offline
AKA: Celebrimbor
FRC #4910 (East Cobb Robotics)
Team Role: CAD
Rookie Year: 2015
danieltcalkin has a spectacular aura aboutdanieltcalkin has a spectacular aura aboutdanieltcalkin has a spectacular aura about
Dimpled eyes!! Our robot last year had a ton of them... for that reason!! (Also, it makes the robot look super cool) But basically, you cut a circle into a flat plate, and bend the rim of the hole. It adds a third dimension to the plate, making it more durable... also you are cutting material, making it lighter. We used this extensively last year... it saved us from the 120 pound limit.
Heres our robot:
Basic example:
Building Good Humans since 2013
Unread 08-14-2017, 06:55 PM
Type's Avatar
AKA: AJ
Rookie Year: 2016
The issue was due to using a worm drive gearbox on this arm. When our drivers weren't careful, they would hit things, causing a sudden stress on the arm, breaking a couple teeth off the gear. Once those couple teeth were gone, it never functioned correctly under load (arm attached to the shaft).
Unread 08-16-2017, 05:36 PM
Jonah Sachs's Avatar
Jonah Sachs Jonah Sachs is offline
FRC #0694
Rookie Year: 2014
Jonah Sachs is an unknown quantity at this point
This does fit under the design of parts, but do not underestimate the effect that properly choosing the alloy of metal that you use for a part can have. You can buy alloys of aluminum that are comparable to the strength of steel and much lighter, but they are expensive. Our team decided to use 7075 aluminum for our climber axle, and that let us run it nearly the length of the robot with only minimal support. Running finite element analysis in Solidworks or a similar program is a great way to get an idea of how some materials will react to different stresses, and can aid with your decision.
Unread 08-16-2017, 08:30 PM
AriMB's Avatar
FRC #5987 (Galaxia)
Rookie Year: 2012
Just FYI, all of the hex axles sold by AndyMark and Vex are 7075 except for churros. We also had our climber axle all the way across the chassis with minimal deflection.
FEA is good to a point, but it can sometimes give you a false sense of confidence. It's hard to estimate the forces in play in an FRC robot, especially before you've seen the game play out. FEA can be useful for ruling out ideas, but I'd be careful using it to "rule in" ideas without making sure you've got a good factor of safety.
  #15   Spotlight this post!
Unread 08-16-2017, 08:43 PM
messer5740's Avatar
messer5740 messer5740 is offline
AKA: Matt
FRC #5740 (Trojanators)
Team Role: Leadership
Rookie Year: 2015
messer5740 is a splendid one to beholdmesser5740 is a splendid one to beholdmesser5740 is a splendid one to beholdmesser5740 is a splendid one to beholdmesser5740 is a splendid one to beholdmesser5740 is a splendid one to beholdmesser5740 is a splendid one to beholdmesser5740 is a splendid one to behold
I have seen teams weld beads into a very thin piece of sheet metal, and although it added little material to the metal, it greatly increased its strength. I think the metal was either 1/16in aluminum or 1/32. Either way, that's very thin!
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: Quarterfinalists at Greater Pittsburgh Regional and Buckeye Regional
2017: Dean's List Finalist
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
