OCCRA
Go to Post Build season is the best time of the year. Better than Christmas because the presents are cooler, and better than new years cause you get to stay up later. - burkey_turkey [more]
Unread 09-10-2018, 08:20 PM
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Dale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud of
Machining aluminum without coolant
Weíre getting the lab cleaned up for this coming season which means itís time to clean our CNC millís coolant system. Itís a Tormach 1100 by the way. This is always a huge mess which brings me to the question.
How bad would it be to mill aluminum without coolant?
We currently just use a constant compressed air stream to keep the chips at bay on our CNC router. Could we do the same with the mill? That way we could just vac them up. Sure the bits wonít last AS long but how big a difference are we talking?
We never machine steel on the mill, itís alway aluminum.
Also, how about the cold saw? Is coolant really important there?
2018 Championship finalist; 2017 Championship Engineering Inspiration; 2017 PNW Championship Chairmans; 2017 PNW District Finalist; 2016 PNW Championship Chairman's; 2016 Winner PNW District, 2015 PNW Championship Chairman's; 2015 PNW District Engineering Inspiration; 2014 PNW Championship Chairman's; 2014 Championship Innovation in Controls; 2013 Chairman's (Oregon); 2012 Winner (OKC); 2012 Chairman's (OKC); 2012 Woody Flowers (Oregon); 2011 Volunteer of the Year (Oregon); 2010 & 2007 Chairman's (Oregon); 2010 Regional Champions (Colorado); 2009 & 2008 Engineering Inspiration (Oregon); 2005 Rookie Inspiration (PNW)
Unread 09-10-2018, 09:07 PM
asid61's Avatar
asid61 asid61 is offline
Design Simple
AKA: Anand Rajamani
FRC #1072 (Harker Robotics)
Re: Machining aluminum without coolant
Compressed air is the way to go. You can use mist coolant with a simple tank and an air line, but even compressed air alone is quite powerful. We currently run flood coolant but will be upgrading to mist based on our experiences with the droopy Tormach coolant pump.
I can't speak to cutting metal on a cold saw.
EDIT: 115 runs without coolant, just a vacuum. I like spraying some lubricant on there to prevent galling and chips welding to the sides of the cut. A 4mm endmill at 43ipm in aluminum does well when slotting with a 1/16" stepdown. More aggressive stepdowns in thin material (like 1/16" or 1/8") can actually help reduce galling and chips welding to the work.
Team 1072 2017-present
Team 299 2017
Team 115 2013-2016 (student)
2018 Davis Finalists (w/ 6474 and 3880), 2018 Roebling Winners (w/ 3476, 1323, and 1778)
Unread 09-10-2018, 09:18 PM
JamieSinn's Avatar
JamieSinn JamieSinn is offline
Mentor - 1334/1374
FRC #1334 (OT Robotics)
JamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond repute
We currently run only compressed air, 120PSI standard shop air lines.
Admittedly, we also do shallower DOC and don't usually push the IPM above 80.
1334/1374 Control Systems Mentor
Unread 09-11-2018, 12:05 AM
Tom Line's Avatar
Tom Line Tom Line is offline
Don't lay blame. Fix probems.
FRC #1718 (The Fighting Pi)
Actually - it's pretty cool that you're asking this question. Over the last 5 years my workplace has been moving to a coolant-free machining system for mass production.
It is a little more expensive in terms of tooling and you can't hit the bits quite as hard, but the benefits of being able to recycle the aluminum without them being a waste that needs to be cleaned first is a cost savings on the flip side.
So you're saving yourself the hassle, and being green.
Unread 09-11-2018, 12:57 AM
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
Good point. I was just thinking of the hassle of cleaning out the coolant and then dealing with that toxic waste. Being able to recycle the chips is great.
Anyone have experience with using a cold saw on aluminum without coolant?
Unread 09-11-2018, 01:09 AM
Skuke Skuke is offline
AKA: Payton
FRC #0846 (The Funky Monkeys)
Skuke is an unknown quantity at this point
My experience is that milling/turning Al with constant air is ok as long as you have your feed/speed, DOC dialed in. However, coolant will give you a much larger margin of error. Be sure your air source doesn't move away from the tool. Again, you have less margin and you can't afford to lose the air flow.
When you get the parameters too far off, you'll generate too much heat into the part which will affect your tolerances (thermal expansion). You'll start to gall and clog the flutes. That will exacerbate the problem and then break the cutter and possibly trash the part. Your surface finish will probably not be acceptable.
Remember, the chips will carry away most of the heat from the cutting/shearing/friction of the cutter against the stock. Getting rid of the chips (evacuation) is most important. You can do this, as you state, with compressed air, flood, or mist.
I think most of the problems mentioned above are of less importance to a FIRST bot, but I would hesitate to give those parts to a buyer who is paying $$.
re: Cold saw.
As mentioned, you could do it when your speed/feed is correct. However, in saws I'm familiar with, your speed is already determined and you can't really control your feed rate (other than visually and audibly). Coolant creates a giant mess, so we use stick wax liberally applied.
Unread 09-11-2018, 04:36 AM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
I’ll add on to the coolant-free club here. We use our CNC mill without any coolant, just compressed air and a bit of cutting fluid on the part. It’s an educational machine so it’s relatively slow (40 ipm, 2mm DoC, 5mm endmill IIRC) but it works well for us. The cuts are all within a decent tolerance, and we haven’t noticed significant wear on the endmills despite getting a good amount of use. This is true for 6061, 7075, and a bit of 6063 (ugh).
As far as the cold saw, I’ve never used coolant with a saw on aluminum. A miter saw with a non-ferrous metal blade will do pretty much everything you need. You can use a bit of cutting fluid or blade wax but it isn’t really needed. With the tolerances we expect a saw to hold for an FRC application, thermal expansion isn’t a big factor.
Edit: To be clear, I’m not recommending running the cold saw without coolant. I just think a cold saw is overkill for FRC and a miter saw makes a lot less mess.
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
Unread 09-11-2018, 05:15 AM
carpedav000's Avatar
carpedav000 carpedav000 is online now
FF: TSIMFD
AKA: David Carpenter
no team (Lincoln Tech)
carpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond repute
It really depends on what kind of cut you are making. If you are just face/side milling stock down to size, it will be more than okay to use no coolant whatsoever or just mist coolant. If you are making deeper cuts (for aluminum Iíd say anything over 0.5Ē) into the material, it would definitely be wise to use flood coolant to avoid chip buildup on the tool or on the part, as this can ruin your endmills very fast. I personally have ruined a brand new carbide endmill by milling a slot in material without using coolant.
It isn't shiny enough.
Unread 09-11-2018, 07:08 AM
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
You could use alcohol, it cleans itself Just be careful not to mist it.
2018 | Gracious Professionalism x3, Asheville Winners, NCCMP Finalists, NC District - 3rd Rank
2017 | Industrial Design, Gracious Professionalism, NCCMP Winners, NC District - 1st Rank
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Rank
Unread 09-11-2018, 07:29 AM
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik has a brilliant futureRob Stehlik has a brilliant futureRob Stehlik has a brilliant futureRob Stehlik has a brilliant futureRob Stehlik has a brilliant futureRob Stehlik has a brilliant futureRob Stehlik has a brilliant futureRob Stehlik has a brilliant futureRob Stehlik has a brilliant futureRob Stehlik has a brilliant futureRob Stehlik has a brilliant future
When we got our CNC router it came with a Unist mister. It basically sprays a fine mist of light oil. A small cup sized reservoir lasts all year. I was so impressed with how well it worked, I put misters on nearly all of our machines (mill, lathe, chop saw). They aren't cheap, but they are so much cleaner than coolant. We tried a conventional coolant setup on our CNC mill, but in a school where machines sit idle for long periods of time, the coolant was always evaporating and getting fouled. Admittedly for heavier machining the mister doesn't clear chips as well as flood coolant, but the reduced mess makes it so much better.
I would love to cut aluminum dry, but in my experience dry cutting has always been a gamble. Sometimes it works fine, but things go wrong very quickly when chips start to stick to the tool.
Unread 09-11-2018, 08:28 AM
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
Eric Scheuing has a reputation beyond reputeEric Scheuing has a reputation beyond reputeEric Scheuing has a reputation beyond reputeEric Scheuing has a reputation beyond reputeEric Scheuing has a reputation beyond reputeEric Scheuing has a reputation beyond reputeEric Scheuing has a reputation beyond reputeEric Scheuing has a reputation beyond reputeEric Scheuing has a reputation beyond reputeEric Scheuing has a reputation beyond reputeEric Scheuing has a reputation beyond repute
I'd also recommend having some fans set up for alcohol (if you don't have any sort of air-circ already) to help clear fumes.
2005-2007 || Bobcat Robotics 177
2015-2017 || MechaRAMS 999
2017-20?? || Elm City Robo Squad 558
Unread 09-11-2018, 09:04 AM
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond repute
I would keep the coolant on the cold saw, those blades are not cheap! The cold saw blades are HSS typically, and have a coating to prevent galling as they pass through the metal. Without cooling you would destroy this coating quickly.
We run very high tooth counts blades for aluminum, 250-280 alternating, 3mm width. One of my favorite tools, very accurate, straight, & clean cuts on any aluminum shaft or section.
Unread 09-11-2018, 09:07 AM
Andy A. Andy A. is offline
Getting old
FRC #0095
I run an 1100 in my shop without flood coolant (the stock pump seized up years ago from lack of use). I have a koolmist style mister setup that I'll use for harder materials, like stainless and titanium, but I generally don't bother with it for aluminum or mild steel unless I'm really trying to nail a finish or I'm new to the tool/material/program. Nine out of ten times I pull the pickup tube out of the coolant and use it as an airblast.
The 1100 is a low enough power machine, and modern CAM is so good, that it's hard to overheat even HSS tools or the part when cutting aluminum at proper feed rates. So the problem you're left with is evacuating chips to avoid recutting, something an airblast generally does just fine.
Unread 09-11-2018, 06:34 PM
SpruceyBrucey's Avatar
SpruceyBrucey SpruceyBrucey is online now
FRC #0885 (Bruce Force Trauma)
Rookie Year: 2015
SpruceyBrucey has a spectacular aura aboutSpruceyBrucey has a spectacular aura about
I don't see a issue with it, the only problem you might have is if you're using a coated carbide end mill, it'll wear the coating right off it.
Unread 09-11-2018, 06:44 PM
sanddrag sanddrag is offline
On to my 18th year in FRC
FRC #0696 (Circuit Breakers)
Here at IMTS I'm watching Datron machines cutting aluminum without coolant. I believe they may be running a mister though.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
