OCCRA
Go to Post When you come down to it, FIRST is about people inspiring other people; STEM and the robots are just the subject matter. - RyanCahoon [more]
CD-Media
Unread 11-10-2017, 10:41 AM
rafi's Avatar
rafi rafi is offline
FRC #0449 (The Blair Robot Project)
Team Role: CAD
Rookie Year: 2016
rafi is just really nicerafi is just really nicerafi is just really nicerafi is just really nicerafi is just really nice
Find the Speed Limit of a Piston?
I've looked into it and it seems that the maximum speed of a piston is proportional to the incoming flow rate, the bore area, the pressure, and the load ratio. I found some data sheets backing this up made by SMC Pneumatics, but on my team we use Bimba pistons and solenoids not made by SMC, so the data sheets don't directly apply. I cannot find this sort of data on Bimba's website.
How would I go about calculating or at least getting a good approximation of a piston's maximum speed?
Unread 11-10-2017, 10:47 AM
Chris is me's Avatar
on a break
AKA: Pinecone
no team (formerly FRC 3929, 228, 2791)
Re: Find the Speed Limit of a Piston?
Adding complication to this is that the resistance to motion in the piston depends on what it's attached to, and for almost any linkage will vary at different points of travel. This resistance, especially if you are going over-center, will cause motion to slow, allowing more pressure to build than an ideal unconstrained piston would allow for.
In the most extreme example that easily comes to mind, you could pre-charge a piston by firing the solenoid while the output is mechanically constrained, and then release that constraint in order to produce a stored energy release with very high speed.
Sort-of looking for a new team in or near Chicago; PM me if you have a lead.
Mentor: 3929 (2018)
Mentor / Drive Coach: 228 (2016-17) - 2016 RIDE Winner &
Consultant: 2170 (2017)
College Mentor: 2791 (2010-15) Build Photos - 2013 WPI Finalists, 2012 BAE Finalists
Student: 1714 (2009) - 2009 MN 10K Lakes Winners
Unread 11-10-2017, 11:06 AM
rafi's Avatar
Team Role: CAD
Rookie Year: 2016
I've heard a lot of tips on how to make the piston faster, but is there any good way to approximate how fast the piston will go? Even if it's through experimentation in one setting, and then applying that information to another setting.
It's understandable if there is no good way to estimate, I would just like to know if someone out there has a good method of estimating a piston's maximum speed.
Unread 11-10-2017, 12:04 PM
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
Team Role: Teacher
Rookie Year: 2011
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
There are a LOT of factors. If you want to go by best-case scenario (no load), you can do a little physics.
Force = (Pressure)*(bore area)
Acceleration = Force/(piston mass)
Vmax = sqrt(2*acceleration*(stroke length))
This assumes there is no decrease in system pressure as the cylinder fills with air, there is no friction in the cylinder, there is no load on the rod, etc.
And I'd do all this in metric units.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 11-10-2017, 12:40 PM
rafi's Avatar
Team Role: CAD
Rookie Year: 2016
This is what I used to think was the maximum velocity of the piston, but the charts I linked above indicate that the flow rate and bore diameter also have a significant impact on the piston's max speed (greater than what would arise from the increase in time to be fully pressurized initially). I believe it has something to do with how the piston would not "want" to speed up faster than some scalar multiple of the flow rate/bore area because if it extends faster than that, there just isn't that much "push"? This seems kind of handwavy, and I wish to make it less so, but I believe there is something along those lines happening.
Unread 11-10-2017, 12:57 PM
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
CYLINDER!
"Champions are champions not because they do anything extraordinary but because they do the ordinary things better than anyone else." óChuck Knoll
Unread 11-10-2017, 01:05 PM
GeeTwo GeeTwo is offline
Somebody Else
AKA: Gus Michel II
Rookie Year: 2013
Originally Posted by IndySam View Post
CYLINDER!
Ah, but in most applications the cylinder is essentially stationary, and it is the piston which moves. [ducks]
[Quoting brennonbrimhall]: We design a new robot every year, but we can't forget that we also design a new team every year as folks come and go.
Unread 11-10-2017, 01:10 PM
on a break
AKA: Pinecone
CYLINDER!
We are specifically discussing the moving portion, which is a piston.
Nice try.
Mentor: 3929 (2018)
Unread 11-10-2017, 01:23 PM
IndySam's Avatar
Nice try.
Nobody in industry that I have ever met will say "I wonder how fast the piston in that cylinder will move?"
Now if you said "I wonder how fast the end of that rod will move" you might be correct.
Unread 11-10-2017, 01:34 PM
Deke Deke is offline
FRC #0085
Rookie Year: 2013
Deke is a glorious beacon of lightDeke is a glorious beacon of lightDeke is a glorious beacon of lightDeke is a glorious beacon of lightDeke is a glorious beacon of lightDeke is a glorious beacon of light
It depends on the upstream pressure drops. You'll lose pressure the longer the line is, any corners where the air has to turn, and any diameter changes. Once you have the effective area of the feed figured out (the big constraint in this question) you can apply Bernoulli principles. The compressible nature of air will complicate things, non compressible hydraulics are easier to calculate.
Unread 11-10-2017, 03:10 PM
Somebody Else
AKA: Gus Michel II
Rookie Year: 2013
I did actually model this for a pneumatic boulder launcher in 2016. I never did reduce this to a repeatable process, but essentially we had shortened up all of our tubing so that it was a very short run from (~60psi) tank to solenoid valve to cylinder. IIRC, the solenoid valve was directly plumbed to the tank, and there was about a 2" piece of tubing to the cylinder. The airflow rate was modeled using a single round orifice with an online calculator. I then figured out an equivalent mass (inertia) and weight (steady back force) for the piston/rod/arm/boulder and tweaked until I found the initial acceleration, then stepped the whole thing forward in time using the amount of air that had already flowed, calculating pressure, accelerating and moving the boulder, letting more air in, and around the cycle for steps of a few milliseconds*. Once I used the correct hole size (the size of the ports into/out of the valve), I was able to predict launch ranges to within about 20%. There's probably an easier way to do this using Cv rather than the orifice diameter.
* I started with about 2 or 3 ms steps, but gradually lengthened them as the pressure's rate of change in the cylinder went down.
Edit: One thing I took away from the exercise was that your pressure in the cylinder will be much less than your supply. In the cases I looked at, maximum power and speed came when the pressure in the cylinder was about 10-13psi. This means that (for the sizes I was looking at) I needed a cylinder of at least twice the diameter of that which would lift the load slowly in order to maximize the speed.
Unread 11-10-2017, 03:17 PM
Unsung FIRST Hero
Chief Robot Inspector
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Everyone,
The speed at which the piston will move is dependent on the volume of air moving into the space behind the piston. This is limited by the size of the tubing feeding the actuator. Larger diameter actuators will naturally move slower than smaller diameters. While the volume changes as the piston moves, you can calculate the incremental movement. For instance, if an actuator had a 1 sq inch piston surface area, and the tubing allowed 1 CFM flowrate, it would take 1/1728 (the volume in inches)= .000578 minutes or about 10 micro seconds to move the piston 12 inches. This calculation does not take into account the air being forced out in front of the piston nor does it account for external forces or the friction of the piston rod or piston seal(s). It also does not compensate for the change in pressure through the tubing, the flowrate for the pressure regulator, etc.
Al
WB9UVJ
www.wildstang.org
________________________
Knowledge is power. Power UP!
Unread 11-10-2017, 05:00 PM
FRC #0085
Rookie Year: 2013
These variables are what you'll need to match a particular application, but if you just want free state results, what Al calculated will get you close.
Edit:
Example, what will move faster, a cylinder with 60 psi and no load with 3/8" tubing, or the same cylinder with 40 psi with a 30 pound load and fed with 1/4" tubing? Flow rate changes depending on multiple factors, you can't assume the same flow rate for everything.
Unread 11-10-2017, 05:52 PM
s_forbes's Avatar
s_forbes s_forbes is offline
plz give me red dots
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
In 2016 we made a catapult launcher. We wanted to find the ideal geometry for the catapult, but to model it we had to know the flow rate of our solenoid valves. To find this flow rate, we set up a test where we bolted a large cylinder (2" bore, 24" stroke - a common size!) to a table, plumbed the pneumatics, and recorded the extension in high speed to see how fast it moved.
The solenoid we used was this one, and it was attached directly to the cylinder. Several air tanks at 60 psi were plumbed in line right before the solenoid to allow the air to travel the shortest path possible.
Here is the footage we recorded. Doing the math, it worked out to 470 cubic inches per second of air flow. If you know the volume of the cylinder you want to fill up (in cubic inches), divide by 470 and you will get approximately how long it will take to extend (assuming you use the same solenoid valve and pneumatics layout).
  #15   Spotlight this post!
Unread 11-10-2017, 06:49 PM
noah.gleason's Avatar
noah.gleason noah.gleason is offline
Rookie Year: 2016
noah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond reputenoah.gleason has a reputation beyond repute
Originally Posted by s_forbes View Post
Link's not working for me.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
