Go to Post Ah, the FIRST Community, aka The Land of Little Patience :) - Jessica Boucher [more]
Unread 13-01-2012, 13:17
The Crop? The Crop? is offline
FRC #3475 (The Crop?)
Rookie Year: 2011
The Crop? is an unknown quantity at this point
MOLEX Power Connecters
Our team is trying to explore our possibilities, and by doing so we wanted to know if we could purchase and use MOLEX power connecters on our robot.
Unread 13-01-2012, 13:19
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Rookie Year: 2007
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
Re: MOLEX Power Connecters
Are you asking the legality?
Unread 13-01-2012, 13:21
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It might depend on what part of the robot you plan on using them on, whether or not they're allowed, read the rules carefully. But generally you can add connectors. It's pretty common for teams to use connectors on the wires from the speed controllers to the motors, for example, to allow quickly changing a motor or doing work on the transmissions.
The Anderson Power Pole connectors are popular for this
http://www.andersonpower.com/product...onnectors.html
They can be paired, in different orientations, and are available in several colors and sizes.
Unread 13-01-2012, 13:25
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
I generally talk teams out of easily available Molex connectors for use on FRC robots. They are finicky for crimping, spread open with repeated use and you need special types if using for motors due to the high currents.
Al
WB9UVJ
www.wildstang.org
________________________
Rookie Year: 2011
cool thanks
Unread 13-01-2012, 13:27
Chexposito's Avatar
AKA: Expo
FRC #1730
Rookie Year: 2007
i would say this is true for motors, but would you say this is still true for sensors? we have used similar connectors in the past with our sensors that needed a quick detach ability, with no problems
Unread 13-01-2012, 13:28
Rookie Year: 2011
well we planned on using the industrial grade ones. similar to those in vending machines
Unread 13-01-2012, 13:35
Unsung FIRST Hero
Rookie Year: 1996
I have seen teams use these for sensors and other low current applications. They seem to be OK but still suffer problems. I use them when I want a connector but will rarely take it apart. i.e. in a power supply connector. However, we stock an abundance of Power Product connectors and PWM style connectors (Molex also makes a connector family like these that are great) We use either of these for applications for sensors, pneumatic solenoids, data.
Crop, do you have a link or picture of the connector you are planning on using?
Al
WB9UVJ
www.wildstang.org
Unread 13-01-2012, 13:40
Rookie Year: 2011
http://www.surplussales.com/computer...connect-3.html This is what we were thinking. We're going to have drawers of electronics; the main power distribution/crio/battery on the bottom, motor controllers next, ect. We would like to be able to remove the drawers and have them interconnect by the molex connectors.
Unread 13-01-2012, 13:48
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Molex is a company that makes a variety of connectors. Are you thinking about the ones inside desktop computers? If so, I don't think they're rated for particularly high currents, or very many insertion cycles.
Unread 13-01-2012, 15:32
MrForbes's Avatar
AKA: Jim
Wow, I haven't seen Jones connectors since I worked on tube gear....
You might want to think about keeping the wiring simple, and easy to access, and not moveable. There's really no need to add more potential problem areas.
Unread 13-01-2012, 19:12
Rookie Year: 2011
Well due to space limitations, we are forced to have multiple electrical boxes.
Unread 13-01-2012, 23:24
DonRotolo's Avatar
Back to humble
FRC #0832
OK. Just make it so they don't have to be removed. Each connector is a problem waiting to happen, and power loss already happening.
Those are Jones plugs, and are not used much any more. Can you guess why?
Unread 16-01-2012, 07:30
Unsung FIRST Hero
Rookie Year: 1996
Crop,
While the Jones plugs are an alternative, I would like to suggest (strongly recommend) that you rethink your design. We use Power Poles for interconnect but only to make exchanging devices easier. Every additional connector you add is a potential failure point and a drop in the possible current you can feed to a motor. I highly recommend to teams to place speed controllers close enough to the motors they are driving that the supplied motor wiring can be directly connected to the output of the speed controller. Remember that the PWM connection doesn't care how long it is, CIM motor wiring does. Please remember when choosing connectors that they have to withstand the stall current of the motor they are feeding or the load they that are supplying. In the case of the CIM that is 133 amps. I haven't seen a Jones plug capable of that current that I can remember. Of course you can use multiple pins but that brings it's own set of problems.
Al
WB9UVJ
www.wildstang.org
