Go to Post this is a TEAM effort...teach them something. Who knows, with a little luck, you might just learn something yourself! - Nuttyman54 [more]
Unread 13-01-2012, 14:13
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
Team Role: Mechanical
the man is on a distinguished road
Main Breaker
Ok I have been wondering this for a while now. The main breaker is set up for 120 amps at 48 volts. Does the voltage matter in this aplication? Or will it still trip at 120 amps at 12 volts?
Every day is a new adventure!!!
Unread 13-01-2012, 14:16
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Re: Main Breaker
The voltage is a maximum rating, the breaker will trip at 120Amps at 48Volts or less.
Jason
Unread 13-01-2012, 14:22
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Re: Main Breaker
The main breaker is a bimetallic device with extremely low resistance across it when closed. Since it does not go directly to ground, the voltage it drops between main leads and breaker output is equal to the current being passed times the resistance of the breaker - notice that this number is the same regardless of input voltage (unless you exceed the maximum voltage rating of the breaker, at which point insulators become weak conductors and you are no longer guaranteed a broken circuit). As a result, the breaker is dependent entirely on current flow, and will break at 120 amps regardless of input voltage (again, with the caveat that it must be within its operating region to guarantee this).
Since it's bimetallic, it trips based on heat - this leads to an interesting phenomenon many teams are aware of (but shouldn't take advantage of). Since the bimetallic strip represents a thermal mass that doesn't change temperature instantaneously, it is possible to get more current than rated through the breaker for short bursts of time - however, this does weaken the metal strip and will make it easier to trip on subsequent runs.
I hope this is helpful.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 13-01-2012, 14:25
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Re: Main Breaker
As I have just learned from Chris_Is_Me, the main breaker is good for more than 120A in a time-dependent relationship. Check out the spec sheet:
http://team358.org/files/electrical/120aMainBreaker.pdf
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 13-01-2012, 18:01
the man's Avatar
AKA: Jacob Overla
FRC #4004
Re: Main Breaker
Cool. Thanks, I wasn't sure.
