Go to Post ... hey which end of the robot faces the wall anyways? Oops.... :rolleyes: - dhitchco [more]
Unread 13-01-2012, 15:55
mikegrundvig mikegrundvig is offline
FRC #2410 (Metal Mustangs)
Rookie Year: 2012
mikegrundvig is an unknown quantity at this point
Axis 206 vs. Axis M1011
We have the older Axis 206 camera and are wondering if we should upgrade to the newer M1011 since the image resolution is the same. For any teams that have played with both - is there a noticeable difference between either camera as it relates to imaging?
-Mike
Unread 13-01-2012, 17:03
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
Team Role: Teacher
Rookie Year: 2011
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Axis 206 vs. Axis M1011
If you don't mind spending $160+ go for it. Otherwise if the old Axis still works, don't bother.
Unread 13-01-2012, 18:10
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
-Mike
Both use the same sized 1/4" sensor, and both have the same lens aperture of F/2.0, so there shouldn't be much difference in how they handle badly-lit environments. This shouldn't be an issue, as the FRC fields are usually pretty well-lit anyway.
The 206 had a 4mm lens focal length, compared to the M1011's 4.4mm focal length. This basically means the 206 has a slightly wider angle of view than the M1011. According to the spec sheets, the 206 has a 54° field of view, while the M1011 has a 47° field of view. Because both output 640x480 video, neither are necessarily better or worse, as it all depends on if you want a slightly wider view with less detail, or a narrower view with more detail.
Another difference between them is that the 206 has a manual focus ring you can adjust to focus better on things either closer or farther away. The M1011 has a fixed focus range, but the range is pretty big, and we've never found the image to be so blurry that it was impossible to see a vision target.
Oh, and another really minor thing is that the new M1011 apparently weighs 94g, where the 206 weighs 180g. If for some odd reason you really need to shave 3 ounces on the robot, the new camera does weigh slightly less.
Bottom line: I think the differences between them are pretty negligible.
http://www.axis.com/files/datasheet/...en_1009_lo.pdf - M1011
http://www.axis.com/files/datasheet/...en_0904_lo.pdf - 206
Zip-ties, hot glue, and duct tape.
2008 New York City Regional Champions - (41/555/1989)
2009 Brunswick Eruption 8 Finalists - (1989/56/1807)
2010 PARC XIII Champions - (25/341/1989)
Over The Bump
